#1 2025-11-04 15:52:06
Dev1User
Upgrade from Devuan Daedalus 32-bit to Excalibur
Hello!
I was just about to upgrade my current 32-bit Daedalus system to Excalibur. While reading through the release notes, I came across the following problem.
It says:
Reduced support for i386
## Getting Devuan 6 Excalibur
Devuan 6 Excalibur is available for i386, amd64, armel, armhf, arm64, ppc64el and
riscv64 architectures. However, the i386 packages don't include a linux-image. See
https://www.debian.org/releases/stable/ … t-for-i386
for details.
Then I clicked on the link and it says the following:
5.1.2. Reduced support for i386
From trixie, i386 is no longer supported as a regular architecture: there is no official kernel and no Debian installer for i386 systems. Fewer packages are available for i386 because many projects no longer support it. The architecture’s sole remaining purpose is to support running legacy code, for example, by way of multiarch or a chroot on a 64-bit (amd64) system.
The i386 architecture is now only intended to be used on a 64-bit (amd64) CPU. Its instruction set requirements include SSE2 support, so it will not run successfully on most of the 32-bit CPU types that were supported by Debian 12.
Users running i386 systems should not upgrade to trixie. Instead, Debian recommends either reinstalling them as amd64, where possible, or retiring the hardware. Cross-grading without a reinstall is a technically possible, but risky, alternative.
Now I'm wondering if I should even bother with an upgrade if it's hardly supported, or not supported at all? And whether the system will still run smoothly after the upgrade?
#2 2025-11-04 16:23:32
Re: Upgrade from Devuan Daedalus 32-bit to Excalibur
There won't be any more kernels for i386. Debian decision with consequences for Devuan. You may look around for other distros.
There is at least one thread in this forum about this topic: https://dev1galaxy.org/viewtopic.php?id=7124 and I think there was another one.
#3 2025-11-04 17:19:27
Dev1User
But what's strange is the following:
The release notes state:
Devuan 6 Excalibur is available for i386, amd64, armel, armhf, arm64, ppc64el and riscv64 architectures. However, the i386 packages do not include a linux-image. See https://www.debian.org/releases/stable/ … t-for-i386 for details.
When I go to install Excalibur on Devuan, it says: Supported architectures: amd64.
And Excalibur is based on Trixie from Debian. Trixie Debian no longer supports 32-bit architectures. So why does Devuan then state that Excalibur is available for i386?
#4 2025-11-04 21:18:04
Next paragraph in the release notes starts with:
Installer isos and live CDs for amd64 are available for download
And this section:
### Reduced support for i386
There is no i386 installer iso for Devuan 6 Excalibur, following Debian's
choice to remove their official i386 kernel and installer.
And if you look at the debian release notes it explains that you can run 32-bit in chroot or container.
I believe it's still possible to upgrade a 32-bit system. You won't get a new kernel, so if you have the kernel metapackage linux-image-686-pae you might need to remove it first. I'm not sure about that.
You can use a linux-libre kernel if you don't need proprietary (non-free) firmware.
see: https://dev1galaxy.org/viewtopic.php?id=7208
#5 2025-11-05 01:24:38
I can now say that it's still possible to upgrade 32-bit daedalus to excalibur. I just did it.
I removed the kernel metapackage (linux-image-686-pae) and installed usrmerge.
Changed sources.list from daedalus to excalibur.
Installed linux-libre kernel 6.12.57-gnu
Ran apt update, apt upgrade, reboot, apt dist-upgrade, apt autoremove.
done
Rebooted again just to be sure.
#6 2025-11-06 01:09:07
Dev1User
So, can I simply integrate a linux-libre kernel into Devuan, Daedalus, or Excalibur? Do I just need to follow the steps on the website fsfla.org to get a working system? Or is there anything else I need to do?
And what will the sources.list look like? Will I receive updates from Devuan, for example, and kernel updates specifically from linux-libre?
And is linux-libre systemd-free?
Sounds like a lot of work.
Or I could just stick with Daedalus, which is Bookworm and will probably be supported until 2028.
I've been looking around on Distrowatch. The following systems might be options:
1. Gnuinos. Based on Devuan and uses the Linux-libre kernel.
2. Refracta. Based on Debian, Devuan = systemd-free.
3. Fluxuan Linux. Based on Devuan.
4. Loc-OS. Based on antiX, Debian. Also systemd-free.
5. Adélie Linux.
So I should follow the instructions from Devuan - Upgrade to Excalibur: https://www.devuan.org/os/documentation … -excalibur
So you've installed usrmerge and changed the sources.list to Excalibur. And now I have to install the linux-libre kernel first and only then follow the other steps in the Devuan upgrade installation instructions?
I'll test it out. If that doesn't work, I'll take a closer look at the systems from Distrowatch.
Thanks.
#7 2025-11-06 12:08:57
Yes, follow the instructions on the linux-libre site. Install their key, add their sources file, update, install.
You'll still have the devuan sources active and can upgrade packages. The kernel will come from the freesh sources.
Note: I pasted the 'modernized' sources below. It's possible to use the modernized source for freesh along with the older sources.list for the devuan sources. I just tested it and 'apt update' didn't complain.
Here's an example iso of 32-bit devuan with the linux-libre kernel. Refracta is just devuan with some tweaks and different set of packages. This one is old. I need to make new isos and stop calling them Testing.
https://get.refracta.org/files/testing/ … 5_1010.iso
/etc/apt/sources.list.d/devuan.sources (generated by running 'modernize-sources')
# Modernized from /etc/apt/sources.list
Types: deb
URIs: http://deb.devuan.org/merged/
Suites: excalibur excalibur-security excalibur-updates
Components: main
Signed-By: /usr/share/keyrings/devuan-archive-keyring.gpg
/etc/apt/sources.list.d/freesh.sources
X-Repolib-Name: GNU Linux-libre Freesh Repository
Enabled: yes
Types: deb
URIs: mirror://linux-libre.fsfla.org/pub/linux-libre/freesh/mirrors.txt
Suites: freesh
Components: main
Signed-By: /usr/share/keyrings/freesh-archive-keyring.gpg
#8 2025-11-06 21:30:00
Dev1User
@fsmithred
I followed your instructions and then the directions on FSFLA and Devuan. I was able to successfully install the Linux-libre kernel.
I opted for the LTS version and have now installed version 6.12.57-gnu.
I was pleased that it worked. The Excalibur installation was also successful.
However, after booting the system, I saw errors, and when I logged in, the screen displayed "GDBus.Error".
I was able to photograph the following errors during boot:
INIT: version 3.14 booting
INIT: No inittab.d directory found
Using makefile-style concurrent boot in runlevel S.
Starting hot-plug events dispatcher: udevd[   10.992891] udevd[357]: GOTO ´alsa_restore_std´ has no matching label in: ´/usr/lib/udev/rules.d/90-alsa-restore.rules´
[   10.993027] udevd[357]: GOTO ´alsa_restore_std´ has no matching label in: ´/usr/lib/udev/rules.d/90-alsa-restore.rules´
Synthesizing the initial hotplug events (subsystems)...done.
Synthesizing the initial hotplug events (devices)...done.
Waiting for /dev to be fully populated...([   14.667087]: Missing Free Firmware (non-Free firmware loading is disabled)
[   14.667182] radeon_cp: Failed to load firmware "/*(DEBLOBBED)*/"
[   14.667189] [drm:r100_cp_init [radeon]] *ERROR* Failed to load firmware
[   14.667321] radeon: failed initializing CP (-2).
[   14.667331] radeon: Disabling GPU acceleration
[   14.848947] Error: Driver ´pcspkr´ is already registered, aborting...
[   20.710713] udevd[361]: Unknown key identifier ´zoom´
done.
These were the errors. After logging into lightdm, I got to the start screen and saw the following message:
GDBus.Error:org.freedesktop.ConsoleKit.Manager.Error.General: Unable to lookup session information for process '2284'
This number at the end changes constantly after the boot process when I log in again and get to the start screen.
And Daedalus didn't have these errors. Everything worked fine.
I checked and all Linux firmware is installed, including the non-free firmware. I deleted it and reinstalled it. But unfortunately, all without success.
It's a Lenovo T60 laptop. Graphics card is: AMD/ATI RV515/M54 [Mobility Radeon X1400]
If I choose the non-LTS kernel in Linux-libre, the errors will probably still occur, since it's an older system. And the Linux-libre-lts couldn't find any matching kernel headers.
Are these errors occurring because Linux-libre doesn't support non-free firmware? How can these errors be corrected? Is there even a way to do this?
The Linux distributions I described above, and Refracta as well, largely use linux-libre. So they won't provide the solution either, will they?
#9 2025-11-06 23:23:12
It says you're missing free firmware. Make sure firmware-linux-free is installed. If you need non-free firmware, you won't be able to use a libre kernel. Have you tried booting the daedalus kernel? It should still be there.
The alsa error has a fix somewhere else on this forum. Search for alsa_restore and I think you'll find it. It's an easy fix.
Also make sure the video drivers are installed. I'm not sure which you need but there's xserver-xorg-video-amdgpu xserver-xorg-video-ati xserver-xorg-video-radeon
#10 2025-11-07 02:30:51
This never got fixed?
Edited: I came off unnecessarily harsh last night and didn't mean to, was frustrated at the time, sorry about that.
#11 2025-11-07 03:35:50
rbit
That's part of alsa-utils package, which is not forked by devuan.  Is there an open bug report on debian about this?
FWIW, the excalibur installer iso (and I believe the live iso) files patch the 90-alsa-resore.rules file, but an upgrade from daedalus would require manual patching.
#12 2025-11-08 13:36:53
Dev1User
I've tried many things. I set the sources.list to "main". I completely removed all the firmware, including the xserver-xorg-video drivers. I also uninstalled udev, eudev, and lightdm. Afterward, I installed udev, eudev,..., and the xorg drivers again.
I went to GitHub and replaced the contents of the file /usr/lib/udev/rules.d/90-alsa-restore.rules.
I thought Radeon graphics cards were open source. But I can't fix the graphics card error. It always displays the error during boot and asks for non-free firmware.
During the boot process, alsa-restore displays the following:
/value pair in file /usr/lib/udev/rules.d/90-alsa-restore.rules on line 3, starting at character 73 (´,´)
I examined the line described at: https://dev1galaxy.org/viewtopic.php?pid=58587#p58587. I replaced the "c" with a "p". No success.
But the alsa-restore error doesn't really bother me, since the sound works. Even if I delete the contents of the file /usr/lib/udev/rules.d/90-alsa-restore.rules, the sound still works and no message appears during the boot process.
The GDBus error is still there. I thought it would disappear if I used startx. But it's still there.
Despite all the errors, everything actually works quite well. The graphics resolution is the same as with Daedalus. The sound works. But it's still annoying to see the errors and constantly to click away the GDBus error on the start screen.
@fsmithred:
So, unfortunately, I removed the Daedalus kernel. That's why I can't test it anymore.
I'm now using the other kernel from Linux-libre. The non-LTS version: 6.17.7-gnu
Nevertheless, the errors during the boot process are the same.
Starting hot-plug events dispatcher: udevd[   10.468515] udevd[350]: invalid key /value pair in file /usr/lib/udev/rules.d/90-alsa-restore.rules on line 3, starting at character 73 (´,´)
Synthesizing the initial hotplug events (subsystem)...done.
Waiting for /dev to be fully populated...[   13.205434] Error: Driver ´pcspkr´ is already registered, aborting...
[   13.592463] udevd[353]: Unknown key identifier ´zoon´
[   13.942533] Missing Free firmware (non-Free firmware loading is disabled)
[   13.942632] radeon_cp: Failed to load firmware "/*(DEBLOBBED)*/"
[   13.942639] [drm:r100_cp_init] [radeon] *Error* Failed to load firmware!
[   13.942778] radeon: failed initializing CP (-2)
[   13.942787] radeon: Disabling GPU acceleration
done.
Well. I'll reinstall the system soon, when I have enough time, and then see if the errors reappear.
#13 2025-11-12 14:57:35
Dev1User
So, I've now deleted everything and reinstalled Daedalus. No non-free firmware was installed during the installation. All xserver-xorg drivers were installed automatically. Free firmware was also automatically selected.
I'm using Openbox as my desktop environment. The GDBus error is gone. The ALSA error is also gone. But it keeps asking for non-free firmware for the graphics card.
The kernel is Daedalus 6.1.0-40. But everything is actually running smoothly. If I switch to the Linux Libre kernel, the errors will probably be the same. I might do that later today.
These are the errors it's showing me now during the boot process:
INIT: version 3.06 booting
Starting hot-plug envents dispatcher: udevd.
Waiting for /dev to be fully populated...[   14.954343] radeon: firmware: failed to load radeon/R520_cp.bin (-2)
[   14.954357] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[   14.954300] radeon firmware: failed to load radeon/R520_cp.bin (-2)
[   14.954396] [drm:r100_cp_init.cold [radeon]] *ERROR* Failed to load firmware!
[   14.954557] radeon: failed initializing CP (-2)
[   14.954564] radeon: Disabling GPU acceleration
done.
And further down at the bottom there is this message:
Setting up ALSA...warning: ´alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore´ failed with error message ´alsa-lib main.c
or: failed to import hw:29 use case configuration -2´...
done.
It's strange, though, that the drivers for this graphics card are found in the proprietary firmware. I always thought Radeon was more open source than NVIDIA.
#14 2025-11-12 16:11:30
My laptop is an older AMD, and it will indeed run almost fine with free firmware as will most i've tried in Daedalus, but there are some small boot errors like yours and my machine will not suspend properly without the firmware-amd-graphics package.
In Excalibur in tests so far on my old lappy, it has worse errors if I don't have that firmware package as I couldn't get past lightdm without it.
#15 2025-11-13 21:13:27
Dev1User
@greenjeans
But Excalibur is only available for 64-bit computers. Which kernel did you use on your old AMD laptop? Or did you manage to get Excalibur to run on 32-bit as well?
@fsmithred
Does the Linux-libre kernel require usrmerge? Do you know anything about this?
And: If I stick with Daedalus and install Linux-libre, and then try to upgrade to Excalibur without usrmerge, will it work?
Why is everyone suddenly switching to usrmerge? It reminds me of SystemD. Someone makes it the default and everyone jumps on the bandwagon.
#16 2025-11-13 22:35:59
Dev1User wrote:
... everyone suddenly switching to usrmerge?
Easy: from Trixie / Excalibur onwards it is mandatory as per Debian design.
Have a read here:
https://www.debian.org/releases/bookwor … w-required
debian.org wrote:
5.1.14.  A “merged-/usr” is now required
Debian has adopted a filesystem layout, referred to as “merged-/usr”, which no longer includes the legacy directories /bin, /sbin, /lib, or optional variants such as /lib64. In the new layout, the legacy directories are replaced with symlinks to the corresponding locations /usr/bin, /usr/sbin, /usr/lib, and /usr/lib64. This means that, for example, both /bin/bash and /usr/bin/bash will launch bash.
For systems installed as buster or bullseye there will be no change, as the new filesystem layout was already the default in these releases. However, the older layout is no longer supported, and systems using it will be converted to the new layout when they are upgraded to bookworm.
The conversion to the new layout should have no impact on most users. All files are automatically moved to their new locations even if they were installed locally or come from packages not provided by Debian, and hardcoded paths such as /bin/sh continue to work. There are, however, some potential issues:
    dpkg --search
    will give wrong answers for files moved to the new locations:
    dpkg --search /usr/bin/bash
    will not identify that bash came from a package. (But
    dpkg --search /bin/bash
    still works as expected.)
Local software not provided by Debian may not support the new layout and may, for example, rely on /usr/bin/name and /bin/name being two different files. This is not supported on merged systems (including new installations since buster), so any such software must be fixed or removed before the upgrade.
Systems that rely on a “base layer” that is not directly writable (such as WSL1 images or container systems using multi-layer overlayfs filesystems) cannot be safely converted and should either be replaced (e.g., by installing a new WSL1 image from the store) or have each individual layer upgraded (e.g., by upgrading the base Debian layer of the overlayfs independently) rather than dist-upgraded.
For further information, see The Case for the /usr merge and the Debian Technical Committee resolution.
* underlining is mine
Right ...
Now you know why it is the default and the bandwagon is full.  8^°
#17 2025-11-13 22:45:53
I don't think the kernel cares about usrmerge. It might be the base-files package that demands it. You can't upgrade to excalibur without merged /usr and you can't revert the system to un-merged.
Someone thought it was a good idea to rearrange the deck chairs, even though we're all still sitting in them.
#18 2025-11-14 00:25:55
Wisdom and sigline material right there.
Not sure it was ever anything more than a control thing on their part.
#19 2025-11-15 18:16:29
Matlib
I've upgraded one of my VPSes to the new stable, and I'm going to upgrade the other one too. Kernels are still available in the oldstable repository. If they stop releasing kernels I'm going to compile them myself like I used to do for my first 15 years with Linux distributions. Back then stock kernels used to be a disaster.
Other than that everything else seems to work.
The reality is a i686 system uses a lot less memory for some reason.
#20 2025-11-16 15:24:21
greenjeans wrote:
... ever anything more than a control thing on their part.
I respectfully beg to differ.
As it has become quite evident, there has been, is and will be (for the long run) an astounding amount of moolah behind the systemd putsch into the Linux ecosystem, the main objective being to infiltrate it, absorb the distribution that is arguably the major player within it and slowly but steadily proceed to morph it into a totally different OS, not much different than any other MS OS till it no longer has any resemblance to Linux as we know it.
That being the case*, I find it very difficult to think of usrmerge as just a control thing: it is just another part of the process towards their main goal.
* as always, YMMV
With those players, nothing is just anything more.
ie: everything they do has a definite purpose and is linked to everything else that has been done up to now.
#21 2025-11-23 19:36:38
Dev1User
The Sources.list is set to Daedalus.
Kernel is: 6.1.0-41-686
The error messages looked like this:
done.
I have now installed the Linux-libre kernel. I am still using Daedalus in Sources.list.
The kernel is: 6.12.58-gnu.
Now the error messages look like this:
Waiting for /dev to be fully populated...[   12.726339] Error: Driver ´pcspkr´ is already registered, aborting...
[   12.741657] Missing Free firmware (non-Free firmware loading is disabled)
[   12.741741] radeon_cp: Failed to load firmware "/*(DEBLOBBED)*/"
[   12.741748] [drm:r100_cp_init] [radeon]] *ERROR* Failed to load firmware!
[   12.741883] radeon: failed initializing CP (-2).
[   12.741891] radeon: Disabling GPU acceleration
done.
@Altoid:
Yes, I understand. I agree with you that usrmerge is just another step toward undermining the Linux system. First SystemD, then usrmerge, and then something else that will completely destroy Linux. I also read online that they introduced it so that SystemD would have even more control. It also destabilizes the system.
Unfortunately, the big companies dictate the standard, and other Linux systems adopt it and make it their standard, which is really sad. But who can resist these changes for long? Sooner or later, everyone will adopt these standards. What will we do then? Are there any alternative systems left that don't use usrmerge? There were more opponents of SystemD, but with usrmerge, everyone agrees. That's strange.
#22 2025-11-23 21:21:34
Gnostic
What happens if usrmerge is uninstalled?
#23 2025-11-23 21:35:47
g4sra
@Gnostic, You can't its more of an 'action' than an 'app'
#24 2025-11-23 21:58:18
It still says you're missing non-free firmware. Do you know which firmware package you need? If you're going to use a devuan kernel, you can install the non-free stuff. If you use the libre kernel, you can't use the non-free stuff.
If the system doesn't work without the non-free stuff then you can't use the libre kernel.
If the system does work without the non-free stuff, you can ignore the warnings.
#25 2025-11-23 22:41:38
Gnostic wrote:
... if usrmerge is uninstalled?
You may want to take a few moments to read de Debian advisory I previously linked to.
TL;DR:
If you want to avoid this usrmerge thing you will have to stay at Daedalus; the caveat being that it was not a fresh install.
^^^ see above wrote:
... installed as buster or bullseye there will be no change, as the new filesystem layout was already the default in these releases.
... the older layout is no longer supported, and systems using it will be converted to the new layout when they are upgraded to bookworm.
buster = Beowulf
bullseye = Chimaera
bookworm = Daedalus
My Devuan box started off as Jesse and was dist-upgraded sequentially to ascii, Beowulf, etc. and then Daedalus, so it retained the now deprecated layout, but that ended with Excalibur.
To upgrade to Excalibur, I have to previously apply the usrmerge package from the Daedalus repository.
But ....
Should I want to go back to a system without usrmerge, I would have to use the last back-up image from my Clonezilla repository.
It would not be Devuan Excalibur.
Excalibur is a usrmerge'd installation, no way around that.
