#1 2023-07-01 13:52:34
bill.p
[SOLVED] No wifi on Acer Aspire 3
I've just installed Chimeara on my new(ish) Acer Aspire 3.
It hasn't set up wifi - when I ran the install it would only recognise the wired connection, so I completed the install with that.
I want to get WiFi working for use around the house and elsewhere, but it hasn't set anything up for it.
I tried putting an entry in /etc/network/interfaces, just:
   allow-hotplug wlan0
   wlan0 inet dhcp
and rebooted, but still ip address just shows the loopback and eth0 connections.
Any suggestions?
The machine came with Win 11 on it, and when I did the Windoze setup it didn't see wifi either, but when I had completed setup I was able to turn on
Wifi and connect without any problem.
#2 2023-07-01 14:30:27
Re: [SOLVED] No wifi on Acer Aspire 3
   allow-hotplug wlan0
   wlan0 inet dhcp
Any suggestions?
Short answer from my mobile:
   iface wlan0 inet dhcp
Your line is incomplete.
#3 2023-07-01 14:42:11
bill.p
Sorry, switching between machines.
Line is as you suggest:
#4 2023-07-01 16:05:02
First thing to check is if the wlan adapter requires firmware.
#5 2023-07-01 17:21:49
Would like to add: lspci may give a hint to the needed firmware.
And for new'ish hardware, daedalus might be an option. It will become the new stable in the near future anyway.
#6 2023-07-01 18:18:53
bill.p
Extract from lspci -v
0000:02:00.0 Network controller: MEDIATEK Corp. Device 7663
    Subsystem: Lite-On Communications Inc Device 3801
    Flags: fast devsel, IRQ 255, IOMMU group 13
    Memory at 6003000000 (64-bit, prefetchable) [disabled] [size=1M]
    Memory at 6003100000 (64-bit, prefetchable) [disabled] [size=16K]
    Memory at 6003104000 (64-bit, prefetchable) [disabled] [size=4K]
    Capabilities: [80] Express Endpoint, MSI 1f
    Capabilities: [e0] MSI: Enable- Count=1/32 Maskable+ 64bit+
    Capabilities: [f8] Power Management version 3
    Capabilities: [100] Vendor Specific Information: ID=1556 Rev=1 Len=008 <
    Capabilities: [108] Latency Tolerance Reporting
    Capabilities: [110] L1 PM Substates
    Capabilities: [200] Advanced Error Reporting
how do I know if additional firmware is required?
#7 2023-07-01 19:58:00
Look at the boot messages or check the syslog for the phrase "missing firmware".
BTW, here is a tutorial: https://tutorialforlinux.com/2021/06/15 … tallation/
That talks about firmware. You will need to enable non-free in Chimaera's sources.list.
#8 2023-07-01 22:57:40
I guess for an mt7663 you'll need to install firmware-misc-nonfree, possibly from chimaera-backports/non-free, unless version 20210315-3 in chimaera/non-free is enough.
Typically kernel modules that need firmware will say so into dmesg and/or syslog.
#9 2023-07-02 12:27:00
bill.p
OK, installed firmware-linux-nonfree and firmware-misc-nonfree, still no wifi entry in 'ip address'. What next?
#10 2023-07-02 12:42:15
soren
You may need to reboot.
#11 2023-07-02 12:46:15
bill.p
Yes, I did. Now no 'missing firmware' entries on syslog, apart from ones before the reboot.
#12 2023-07-02 13:36:42
what's the output of
# rfkill
(install it if you don't have it)
#13 2023-07-02 13:40:04
Have you got a network manager running?
#14 2023-07-02 14:28:45
bill.p
$ sudo rfkill
[sudo] password for bill:
ID TYPE      DEVICE              SOFT      HARD
0 wlan      acer-wireless  unblocked unblocked
1 bluetooth acer-bluetooth unblocked unblocked
2 bluetooth hci0           unblocked unblocked
and
yes, NetworkManager claims to be running - the network icon on the panel just shows the wired connection.
#15 2023-07-02 14:46:35
bill.p
The NetworkManager appears to have the details for my wifi, not sure how, /etc/NetworkManager/system-connections/Wi-Fi\ connection\ 1.nmconnection contains:
[connection]
id=Wi-Fi connection 1
uuid=779db10d-3968-4372-aa75-fa2753fee9f9
type=wifi
permissions=
[wifi]
mac-address-blacklist=
mode=infrastructure
ssid=ChateauPenketh
[wifi-security]
key-mgmt=wpa-psk
psk=??????????            (psk obscured for security, but correct)
[ipv4]
dns-search=
method=auto
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
[proxy]
#16 2023-07-02 15:03:18
bill.p
Further digging:
# nmcli connection show
NAME                UUID                                  TYPE      DEVICE
Wired connection 1  ce8605fe-de1f-4ce6-97d9-3f6e4c51fbfc  ethernet  eth0
Wi-Fi connection 1  779db10d-3968-4372-aa75-fa2753fee9f9  wifi      --
and
# nmcli radio wifi
enabled
I've got used to Ubuntu which never required any of this digging around, so I'm not familiar with the various commands.
#17 2023-07-02 21:07:22
Sorry, I only use traditional ifupdown for my networking, and since you mentioned editing /etc/network/interfaces I thought you did the same.
By the looks of it the kernel recognizes the hardware. I would have thought the boot-up log would mention that hardware and which firmware gets loaded. At least there should be some mt7663* module loaded. You may check that with lsmod.
Surely someone that uses NetworkManager may have further ideas.
#18 2023-07-03 07:31:24
bill.p
Ahhh, modprobe mt7663 says module not found!
#19 2023-07-03 07:46:52
bill.p
synaptic search for mt7663 only pulls up firmware-misc-nonfree which I've installed, but that only provides firmware in /lib/firmware/mediatek.
Which package might contain the module?
#20 2023-07-03 08:43:22
bill.p
Progress: found references to mediatek chips needing 5.12 kernel, with suggestion to install the xanmod kernel. Managed to do that:
# uname -r
6.1.37-x64v4-xanmod1
I now find wlan0 exists in 'ip address' but NetworkManager, show it with 'not managed'
Deleted the references to wlan0 in /etc/netwprk/interfaces and restarted NetworkManager and wifi has connected!
Thanks for all the help!!
