#1 2023-04-25 20:58:02
Piriponzolo
Installation problem or GRUB problem?
Hello to everyone.
I'm a novice to GNUINOS and I come from Trisquel which no longer supports the 32-bit architecture. I did the 32bit GNUINOS (Chimaera) installation, but after starting GRUB and logging in, I'm asked for another login and BASH replies "command not found". Is a solution possible? Thanks for the attention.
#2 2023-04-25 22:18:11
Re: Installation problem or GRUB problem?
Hi, if you are using "su" to get root... try "su -" ... some M$CE thinks it's better to change stuff, imho.
..and check the release notes for other upgrades.
#3 2023-04-26 00:55:05
prospero
This probably means that you are already logged in, so what you are getting is a command prompt, not a login prompt.
If you have installed Xfce, you may want to try:
startxfce4
#4 2023-04-26 01:02:33
prospero
Note that there is a specific thread dedicated to Gnuinos: https://dev1galaxy.org/viewtopic.php?id=712.
