#1 2017-04-23 07:27:48
batmore
HOWTO: upgrade Devuan (stable) to the latest Linux kernel
This is a tutorial to upgrade the existing kernel to the latest version, or a version you select
Getting and compiling a Linux kernel need not be hard or complex.  The following tutorial is long, but not difficult.
This tutorial assumes -
  • you've installed ( or upgraded to) Devuan
  • you are compiling the kernel on the machine that will use it. Other configurations are do-able, just not part of this tutorial
  • you are compiling a i386 or amd64 system. This tutorial doesn't cover other architectures
  • you have a userid installed on the base system, if you are going to use userid 'root' then skip the 'setup sudo' part
  • you know the 'root' password
  • you are ok with Grub. Grub update is completed by the 'make' install step. Tutorial uses only this method
Task list -
  • Setup 'sudo' so that you can do Administrator level work without being 'root'
  • Edit  apt-get  'sources.list'  to comment out the CD-ROM source, or move the cdrom definition to last place in the file
  • Use apt-get to install the several prerequisites
  • Make a directory for the linux source files
  • Use   git   to clone the Linux branch (all of it to start)... roughly 3 GiB
  • Check latest linux version
  • Checkout the latest linux kernel version, or checkout a specific version
  • Get a copy of the kernel config from your current linux install
  • Use 'menuconfig' to prep the kernel .config file
  • Use 'make' to compile the kernel
  • Use 'make' to compile the various modules and to install everything
  • Reboot   to effect the new kernel
  • Check to see that your machine is using the new kernel version
  • Party !!
Detail task steps -
Switch User (su) to root to add your userid to "Sudo"  so that you can do Admin work without being administrator
  Open a Terminal window/screen, at prompt type
    su
   and press [return/enter key], then provide root password  (default devuan pswd is:  toor )
Add  'Sudo' to your userid
    visudo        then press [return/enter key]
   Add your userid (ie:  bkm )  just below the entry for "root"  with same priviliges, etc..
     root    ALL=(ALL:ALL) ALL
     bkm     ALL=(ALL:ALL) ALL
   Press control-x to exit, select  "Y"  when prompted to save changes, then [enter]  key to exit
Back at root prompt, type in
     exit
Edit  sources.list  to comment out the CD-ROM source, or move the line with the definition to last place in file
     sudo nano /etc/apt/sources.list
     Comment out (place a hash symbol  #  at beginning of line) "deb cdrom:..."
     Ctrl-x, then "Y" to save and exit
Use apt-get to install these several software prerequisites.
    sudo apt-get update
    sudo apt-get install  libncurses5-dev build-essential  libssl-dev libelf-dev git  bison flex
      press "Y" at  "Do you want to continue? [Y/n]"  prompt
Make a directory for the linux source files, then change directory into your new source directory.
    mkdir ~/src
    cd ~/src
    git clone [url]https://github.com/torvalds/linux.git[/url]
Check latest linux version, cd into the git linux directory
    cd ~/src/linux
    git tag -l              (that"s a lower case "L"  for list )
  check the listing for the highest level version, remember that 4.11 comes after 4.1
Checkout the latest linux kernel version after reviewing the git tag list (above)
    git checkout -f
   OR if you want/know of a specific version then ie:
    git checkout v4.11-rc6
Get a copy of the kernel config... from our current linux install
     cp /boot/conf*  ~/src/linux/.config      (note the  .config )
Validate the .config  using  'menuconfig'
    make menuconfig
  once in 'menuconfig'   (text based kernel config menu) then use arrow-keys to select <Exit>
   select <Yes> at the save .config prompt
Kick off the kernel compile, use 6 job threads to do the compile
    make -j 6
Kick off the kernel modules prepare, then install the modules
    make modules_prepare
    sudo make modules_install install
After the kernel is compiled, the large number of modules is installed, and GRUB2 is updated, then reboot to move to the new kernel version.
    sudo reboot
Once the reboot occurs you"ll see the GRUB boot menu,
  and if you do nothing (for the 5 seconds you"re allowed) then the latest kernel version will be used to boot the machine
Check to see if the machine is using the new kernel version
  Open a terminal session and at terminal prompt, type in:
  uname -a
  you should see something like...
     "Linux devuan 4.11.0-rc4+ #1 SMP Thu Mar 30.. x86_64 GNU/Linux"
Party!!
Appendix
  - maintaining your Linux kernel, housekeeping...
         - assumes you start where you left off (above)
To go a bit further, you might want to customize your kernel a bit, or to recycle and compile another kernel.  Some helpful tips.
Gather information about your machine, helps when you want to customize your kernel.  The more you know about your machine, the finer you can tune it.
List and capture machine specific information. Run these commands, then store/print the output for reference.
  List PCI information
   lspci   >  myMachine.info
  or   lspci -v              for more verbose information
  List USB information
   lsusb   >>  myMachine.info
   or    lsusb -v          for more info
   List CPU info
   lscpu   >>  myMachine.info
List Modules loaded and running on your machine
   lsmod  >>  myMachine.info
Print out the    myMachine.info       file and keep for reference.
Clean or Reset your kernel build environment.
Change to your Linux source directory, list the current kernel version, then save your existing .config file to something meaningful... ie: your kernel version!
   cd ~/src/linux
   uname -a
   cp .config .config-4.11-rc2
Clean up and reset the kernel build env.
    make clean
    make mrproper
Copy your saved kernel configuration to  .config
    cd ~/src/linux
    cp .config-4.11-rc2  .config
OR list the current /boot/configs and copy the one you want.  ie: latest
    cd ~/src/linux
    ls -la /boot/config
    cp /boot/config-4.11-rc2 .config
Get the latest kernel updates from https://github.com/torvalds/linux.git
   git fetch
List out the kernel versions.... remember 4.1, 4.11, 4.2...
   git tag -l
Checkout the latest kernel version  (reset the master head) or select a specific kernel version (see way above).
   git checkout -f
Use steps below to  'make menuconfig' to validate the kernel .config
Now compile your kernel... and reboot.
Tune your kernel   .config
Should you want to start tuning your kernel (shrinking it to the smallest possible size with the most flexibility) then you must modify the kernel .config   file by using the  'make menuconfig'  utility.  This is where your earlier inventory of machine hardware (above) is important.
Ensure you've saved off your build environment .config or use the instructions above to make a copy of the exiting /boot/configxxx file.
An easy way to make a succinct kernel configuration, based on the currently loaded kernel modules
    cd ~/src/linux
    make localmodconfig
   check the listed modules against your machine inventory list (the myMachine.info listing).
   Firmware for USB, networking cards, or wifi things are where most problems occur.
   If it's ok with you then update your '/etc/apt/sources.list' for  contrib and non-free  repositories.
   firmware-linux-free comes with the standard install, but other firmware installs such as: firmware-linux, firmware-linux-nonfree,     firmware-iwlwifi, firmware-ralink, firmware-realtek, and many others, are in the 'contrib' and 'non-free' repositories.
The 'make'  wizard will ask you to decide on the fate of new/updated modules.
For new or modified modules you'll be prompted to decide [Yes/No/Module/New] (New):  or similar.  Typically the default is in parens ie: '(New)', and that is probably a safe selection...select [enter] key for default option.
ie:
* PCI GPIO expanders
AMD 8111 GPIO driver (GPIO_AMD8111) [N/m/y/?] n
BT8XX GPIO abuser (GPIO_BT8XX) [N/m/y/?] (NEW)
   go thru each module prompt till you're at the shell prompt again, then use   'make menuconfig'   (way above) to validate it.
Explore your kernel .config file
Explore your kernel .config via the 'make menuconfig'  menu.
Remember to refer to your previously printed/saved machine info and make intelligent decisions on what to remove, what to leave in.
cd ~/src/linux
make menuconfig
<exit> and <save>  to effect the .config changes, then use 'make' to compile your new, tuned kernel.  Reboot to enact it.
If your new, tuned, kernel doesn't boot
  Don't panic... we have the previous kernel remember?
Reboot again, and at the restart Kernel Selection menu then use the arrow keys to select the 'Advanced...' options and select a previous kernel.
#2 2017-05-01 15:20:33
joril
Re: HOWTO: upgrade Devuan (stable) to the latest Linux kernel
Thanks for your guide! I have a question though: does Devuan/Debian ship with vanilla kernel? No custom patches?
#3 2017-05-01 20:07:54
batmore
Devuan RC currently ships with standard kernel.  On my machine...
  Linux devuan 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1+deb8u2 (2017-03-07) x86_64 GNU/Linux
Kernel as provided by Debian. So no "custom" patches that Devuan put in (that I'm aware of...).
#4 2017-05-02 08:53:25
joril
I see... I think the original package is this one. The page mentions "linux_3.16.39-1+deb8u2.debian.tar.xz" which seems to contain patches collected by Debian against the vanilla kernel. I think this answer my question, thanks smile
#5 2017-05-06 14:53:16
angus71
Hi batmore!
This was my first "selfmade" kernel...  smile
Thanks to you it was relatively easy. I'm now running on kernel version 4.9; until now no
problems occured.
Very nice HOWTO!
Cheers
EDIT:
I forgot to mention, but
make menuconfig
did not work for me, so I tried
make nconfig
that way I could configue my kernel.
I did some searching, for menuconfig I obviously need the packages "ncurses-devel" or "libncurses5-dev";
those I did not find in the repositories. sad
Now I get on systemstart a failure-message on screen like "cpu freq kernel modules could not be loaded".
Otherwise everything seems to work well.
When I got time, I will start a new post!
Greetings
#6 2018-03-20 20:21:48
batmore
I've updated the list of resources/prerequisits to install for make:  removed  module-init-tools, and added   bison and flex
#7 2018-06-02 18:41:44
untimly
This is a very useful tutorial and I have a couple of updates/suggestions. Since kernel version 4.14 (I believe) the package "libelf-dev" is also required to compile. And with the package "debhelper" installed you can instead use
make -j 6 deb-pkg
to create a set of .deb packages to install, rather than using the make install steps. This makes it easier to copy your newly built kernel to other computers, or to uninstall it.
#8 2018-06-03 04:23:53
batmore
You are so right... I missed that library.  I'm glad you mentioned it, and I've updated the list of prerequisites.  I've not tried the "debhelper" deb-pkg route yet, so I'm off to give that a shot to see what it gains.
great catch.
#9 2018-08-05 14:14:49
groog.17
Hi everyone! May be not the right thread, but does anybody know where is the info regarding Devuan kernel rebuilding how-to? Can't find anywhere.
#10 2018-08-07 19:07:51
batmore
If you're refering to the production Devuan kernel, and how it's built, etc.. then I recommend going to  relay chat  https://webchat.freenode.net/    #Devuan    and ask the question there... maybe from FSmithRed.
#11 2018-08-18 15:32:01
mikel
Sorry but with the next line:
I have the error: ".config is not a directory" and I must step this. After I finish all the others steps all is OK but the ~/src directory is empty. It's ok?
Thanks in advance,
Mikel
#12 2018-08-19 00:48:15
duane
That error means you have more than one config* file in /boot, so the shell doesn't know which to use. You'll want to use something like:
cp /boot/config-4.9.0-7-amd64 ~/src/linux/.config
That version is the correct one for my ascii installations. You need the version that matches your current kernel, which you can see by typing:
uname -a
#13 2019-05-20 20:56:35
Dutch_Master
Way back before Devuan existed I'd build my own kernels. So much so, I created a script for it:
#! /bin/bash
# Small script for building a new 3.x kernel on Debian and derivatives
# Written by <private>
# Version: 1.0 @ May 6, 2014
# Requires minor editing for latest stable kernel version
# The make install and mkinitramfs steps requires root permissions.
# This script is released under the GPL: http://www.gnu.org/copyleft/gpl.html
# Preparing your system:
# First, we'll install the build environment with some extra's to aid configuration of the new kernel
apt-get install build-essential libncurses5-dev wget tar
# To keep things tidy a new directory for the kernel is created. Remove or comment out both lines if you don't want this.
# If you comment these line out or remove them, the kernel will be downloaded and installed in the current working directory.
mkdir ~/kernel
cd ~/kernel
# Getting the source and preparing it for use:
# edit these lines to represent the latest (longterm support) stable kernel from the kernel.org team
wget -q https://www.kernel.org/pub/linux/kernel/v3.x/linux-3.12.18.tar.xz
tar -xvf linux-3.12.18.tar.xz
cd linux-3.12.18
# Configuring the new kernel:
# Run manually if this part fails and accept all defaults, then comment out the next line with a # in front.
# Alternatively, use "make oldconfig" but this will ask a lot of questions you'd need to answer individually.
# Provided you have installed the correct packages, you can also use the "make xconfig" tool if you're working
# in a graphical environment.
make menuconfig
# Building the kernel and putting everything in place to use:
# This is the part that does the actual work:
make && make modules && make modules_install && make install && mkinitramfs -o /boot/initrd.img-3.12.18 3.12.18
# The last portion of the above line should be edited if another kernel version is used!
# Now you need to update your bootloader to add the new kernel. Most Linux distributions now use Grub2 by default.
# If yours uses the old Grub or Lilo, comment out this line and configure/run manually.
update-grub
# After you've done that, and checked thoroughly twice, it's time to reboot into your new kernel.
exit 0
As you've noticed, this is aimed at the 3.x series kernel, I guess with minor editing this script can also be used for new 4.x and perhaps even the upcoming 5.x series kernel. Unless the tool-chain or its syntax has significantly changed since, I haven't had to build a kernel in several years, due to using a (cutting-edge) source-based distro. (Funtoo, in my case) This script was also intended as a teaching tool for those wishing to compile their own kernels but hadn't tried yet, hence the copious amounts of comments. wink
HTH!
[edit: I've also found an earlier, undated version of this script, dealing with a 2.6.38 kernel (that's telling! wink ) last modified Spring 2011... tongue  [/edit]
#14 2021-04-14 18:54:25
Sailor17
Hi everyone
Does anyone managed to compile a version 5.X Kernel in Devuan?
I've just installed Devuan Desktop in VirtualBox. But somewhere with an Kernel Update around 4.3.X and 4.8.X the Guest Addition Tools failed to run out of the box. Even with the suggested Kernel module compilation. It seams to be not a Devuan problem because of the same issue in Ubuntu. 18.X, 20.X, Debian 20.X, Raspberry Desktop.
So I would like to try a Kernel 5.10.30 and see if it works and to have a more recent Kernel version..
I was following the instruction on the Debian page:
"4.5. Building a custom kernel from Debian kernel source" at
https://kernel-team.pages.debian.net/ke … tasks.html
Which is almost identical with the above described process. Unfortunately I struggled in configuration using nconfig with error message:
/bin/sh: 1: flex: not found. See below.
root@devuan:/usr/src/linux-5.10.30# make nconfig
  UPD     scripts/kconfig/nconf-cfg
  HOSTCC  scripts/kconfig/nconf.o
  HOSTCC  scripts/kconfig/nconf.gui.o
  HOSTCC  scripts/kconfig/confdata.o
  HOSTCC  scripts/kconfig/expr.o
  LEX     scripts/kconfig/lexer.lex.c
make[1]: *** [scripts/Makefile.host:9: scripts/kconfig/lexer.lex.c] Fehler 127
make: *** [Makefile:603: nconfig] Fehler 2
Any help is appreciated.
This is also an important step for me to learn compile Kernel and Programs, because I'm not willing to use the monstrous systemd distributions and like to contribute in development with Devuan. My be we start to continue this documentation with Major Kernel Updates.
Best regards Hans
#15 2021-04-14 19:49:50
Yes, compiled linux-libre-5.9.9 some time ago:
http://packages.gnuinos.org/gnuinos/pool/main/l/linux/
Best regards Hans
That's right, you need to install both flex and bison. But..., what's the problem installing flex?
#16 2021-04-18 19:48:55
batmore
All,
I ran thru this install/config steps by installing Devuan 4.0 Chimera Alpha Desktop as the base and then installing/compiling the v5.12-rc7 linux kernel.
it worked well, yielding the below changes... please note.
Aitor is right, need to install FLEX to make this work.  What issue/error did you see when installing flex?  Or any of the other essentials software?
Also, the essential install list needs to include  'bc'
so updated full list of needed essential installs is -
   sudo apt-get install  libncurses5-dev build-essential  libssl-dev libelf-dev git  bison flex bc
Just so everyone is aware, the size of the linux branch is ~8 GiB
If you can't install or get the menuconfig to work then the nconfig works just fine and yields the same result.
And, after you get this working, then do try the "debhelper" deb-pkg that Untimely suggested. It's very good that it will generate a .deb (and associated) files that you can transport/copy  to another Devuan install, and just install the .deb package to update everything.
Also, yes, I'll come back on occasion when major Devuan builds change or major Linux kernel changes to run thru this with latest builds to validate it still works, or if not post updates.
cheers all.
#17 2021-07-04 12:21:30
bai4Iej2need
Hi
I try to compile my own (hopefully slimmer) kernel now, but I miss the point . At
make menuconfig / oldconfig / localoldconfig / xconfig. 146 options are shown from tab completion, but these are not.
which packages provide these make targets ?
I need to reduce kernel size and weed unneeded out.
broken by design :
#18 2021-09-10 03:26:21
batmore
When you use the MAKE script, it will accept a number of options...  if you type    make  -?    or    make  -help   then you can use the TAB completion to list a number of different configurations for the    make     script.
e.g.
Configuration targets:
  config      - Update current config utilising a line-oriented program
  nconfig         - Update current config utilising a ncurses menu based program
  menuconfig      - Update current config utilising a menu based program
  xconfig     - Update current config utilising a QT based front-end
  gconfig     - Update current config utilising a GTK based front-end
  oldconfig   - Update current config utilising a provided .config as base
  localmodconfig  - Update current config disabling modules not loaded
  localyesconfig  - Update current config converting local mods to core
  silentoldconfig - Same as oldconfig, but quietly, additionally update deps
  defconfig   - New config with default from ARCH supplied defconfig
  savedefconfig   - Save current config as ./defconfig (minimal config)
  allnoconfig     - New config where all options are answered with no
  allyesconfig    - New config where all options are accepted with yes
  allmodconfig    - New config selecting modules when possible
  alldefconfig    - New config with all symbols set to default
  randconfig      - New config with random answer to all options
  listnewconfig   - List new options
  olddefconfig    - Same as silentoldconfig but sets new symbols to their default value
  kvmconfig   - Enable additional options for guest kernel support
  tinyconfig      - Configure the tiniest possible kernel
Each of these options provide a differnt set of interfaces to select options for a user to explore.
I typically use   make menuconfig
so that have an easily traversed menu based interface to select, or not, certain Kernel Modules or characteristics.
I select these with some thought and then compile the kernel.
Sometimes it works out great.
Other times it does not.  In those cases I revert back to the previous kernel option and try again.....
In any case, I explore the differing options using the menuconfig, or the nconfig, or other  HELP  > TAB options....
Or I create my own CUSTOM .config by selecting various options using  'make menuconfig'  and then editing the .config file with a text editor.
All of those options (146?)  are available for you to explore.  They are various ways to present the various kernel interfaces and/or options... or to limit them.
Part of the fun/beauty is exploring the kernel options given what your hardware/software supports when defining what to use for the kernel, and what to leave out.... that is what 'Tuning' the kernel is all about.
To be safe, select the     make menuconfig     or the     make nconfig     options.... and then just exit out to format the .config for that  next  command =  make
#19 2021-09-10 03:36:42
batmore
Also, now that I think about it...
You can select     make localyesconfig       or    make localmodconfig     options which will only compile or make available those options/modules that exist for your 'running' machine state.
In other words you will create a .config that has only those modules that are currently running on your machine.
This make a great, small, compact kernel based on what is running currently...
But, beware!
This might not include certain firmware that is needed for your machine to run successfully.
Often the network card, or other hardware driver is not included, and after you compile/reboot.... your machine might complain or not start successully until you modify the .config to include that firmware or driver.
#20 2021-12-02 17:53:30
batmore
Notes from going thru this guide following the Chimeara stable upgrade.
1. I did a fresh install of Devuan Chimeara using the netinstall.iso install image, downloaded and burned to USB thrumb drive.  This is a non-UEFI install and I installed the default Xfce4 desktop.  That all went well.
2. I did an update and then full-upgrade to the installation
3. To upgrade to the latest Linux Kernel, 5.16-rc3 I followed the guide steps above, and needed to do two changes.
    a. I copied the previous /boot/config-5.10.0-9-amd64  to  my ...src/linux/.config  and changed the CONFIG_SYSTEM_TRUSTED_KEYS="debian/certs/debian-uefi-certs.pem"  to CONFIG_SYSTEM_TRUSTED_KEYS=""   else the   make    fails
    b. I needed to install       apt install dwarves         as a prerequisit tool to get the  make  to finish successfully.  make  failed with  'pahole not installed...'
4. after a successfull   make ,  make modules_prepare,  sudo make modules_install  install     then I rebooted.
Whoot, whoot!   system booted into  Linux kernel  5.16-rc3
bkm@optiplex:/boot$ uname -a
Linux optiplex 5.16.0-rc3+ #2 SMP PREEMPT Thu Dec 2 07:11:06 PST 2021 x86_64 GNU/Linux
