#1 2021-03-08 19:51:15
[SOLVED] Permissions for script in cron
I have put a script to run fstrim in /etc/cron.weekly/:
groucho@devuan:/$ cat /etc/cron.weekly/dev-fstrim
# trim all mounted file systems which support it
# added 20200315
LOG=/var/log/trim.log
echo "* $(date -R) *" >> $LOG
fstrim -a -v >> $LOG
groucho@devuan:/var/log$
But it is not running, probably because fstrim needs admin credentials to run.
I can run the script as root but that needs my intervention and the idea is that it runs automagically one a week.
What is the proper way to achieve this?
An entry in /etc/sudoers.d for fstrim?
#2 2021-03-08 20:18:43
Re: [SOLVED] Permissions for script in cron
Normally you'd need root permissions to put scripts there, and it will, if executable, run by cron as root.
However, the PATH is a common cause of issues, see e.g. man 5 crontab.
#3 2021-03-08 20:19:20
It's not a permissions issue, it's a PATH issue.
Either set PATH in the script or call the full path to fstrim in the script.
EDIT: gah, too slow...
#4 2021-03-08 21:08:01
ralph.ronnquist wrote:
... PATH is a common cause of issues, see e.g. man 5 crontab.
... it's a PATH issue.
... set PATH in the script or call the full path to fstrim ...
Like this?
Belt and suspenders ...
# added x 20200315
PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin
echo "*** $(date -R) ***" >> $LOG
/sbin/fstrim -a -v >> $LOG
Thank you both for your input.
Cheers,
#5 2021-03-09 16:28:05
Like this?
Well that would work but I would use either/or. If you really want to use both methods then call the full path for date as well.
And for the log you should probably record both stdout and stderr:
/sbin/fstrim -a -v >> "$LOG" 2>&1
#6 2021-03-09 20:26:54
... would use either/or.
... want to use both methods then call the full path for date ...
Yes, makes sense.
Done, will use full path to the script.
... should probably record both stdout and stderr:
Done.
Thanks for the heads up.
Cheers,
#7 2021-03-28 12:31:58
Right ...
That's what I did.
And that same day (2021-03-09) I ran it manually to check if it worked and it did:
On Tue, 09 Mar 2021 14:20:41 -0300:
/var/log: 1.4 GiB (1513295872 bytes) trimmed on /dev/sda5
/home: 47.6 GiB (51058135040 bytes) trimmed on /dev/sda6
/: 8.1 GiB (8655081472 bytes) trimmed on /dev/sda1
But as you can see, nothing has been logged since.
I should have run on the 16th and on the 23rd.
groucho@devuan:~$ cat /etc/cron.weekly/dev-fstrim
# PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin
echo "On $(date -R):" >> $LOG
groucho@devuan:~$
I checked again this morning:
[root@devuan ~]# /etc/cron.weekly/dev-fstrim
[root@devuan ~]# cat /var/log/trim.log
On Sun, 28 Mar 2021 08:46:19 -0300:
/var/log: 1.4 GiB (1473417216 bytes) trimmed on /dev/sda5
/home: 45.4 GiB (48720437248 bytes) trimmed on /dev/sda6
/: 8.1 GiB (8660197376 bytes) trimmed on /dev/sda1
[root@devuan ~]#
As you can see, the script runs and logs as intended.
But cron-weekly is not doing it.
What am I missing here?
Thanks in advance,
#8 2021-03-28 14:15:25
Just to be sure: is anacron is installed?
#9 2021-03-28 14:42:43
... is anacron is installed?
groucho@devuan:~$ apt list | grep -i anacron
anacron/stable,now 2.3-28 amd64 [installed,automatic]
anacron/stable 2.3-28 i386
groucho@devuan:~$
Thanks for your input.
Bst,
#10 2021-03-28 18:34:34
Can we see the output of this command (as root):
# crontab -l
#11 2021-03-28 19:52:45
... output of this command (as root):
# crontab -l
Indeed:
[root@devuan ~]# crontab -l
no crontab for root
[root@devuan ~]#
In case you need it, here's my user's crontab -l:
groucho@devuan:~$ crontab -l
# For details see man 4 crontabs
# Example of job definition:
# .---------------- minute (0 - 59)
# |  .------------- hour (0 - 23)
# |  |  .---------- day of month (1 - 31)
# |  |  |  .------- month (1 - 12) OR jan,feb,mar,apr ...
# |  |  |  |  .---- day of week (0 - 6) (Sunday=0 or 7) OR
# sun,mon,tue,wed,thu,fri,sat
# *  *  *  *  * user-name  command to be executed
# Entries added to keep log files from growing too large
# http://www.daniloaz.com/en/how-to-prevent-the-xsession-errors-file-from-growing-to-huge-size
# Set logfiles to 10Mb and 200 lines max. checking for size every 23 hours
# see https://crontab.guru/every-12-hours
# File size examples:
# 150Mb -> 150000
# 100Mb -> 100000
# 15Mb  ->  15000
# 10Mb  ->  10000
# 1. For /home/groucho/.xsession-errors
0 */23 * * *  [ $(du -k .xsession-errors | awk '{ print $1 }') -gt 10000 ] && tail -200 /home/$(whoami)/.xsession-errors > /home/$(whoami)/.xsession-errors
# 2. For /var/log/boot (bootlogd)
0 */23 * * *  [ $(du -k /var/log/boot | awk '{ print $1 }') -gt 10000 ] && tail -200 /var/log/boot > /var/log/boot
# 3. For /var/log/cron.log
0 */23 * * *  [ $(du -k /var/log/cron.log | awk '{ print $1 }') -gt 15000 ] && tail -500 /var/log/cron.log > /var/log/cron.log
# Back In Time system entry, DO NOT EDIT -> will be edited by the gui:
0 */15 * * * /usr/bin/nice -n 19 /usr/bin/ionice -c2 -n7 /usr/bin/backintime backup-job >/dev/null
groucho@devuan:~$
I add comments to have a reference and keep track of 'how and why'.
Otherwise I forget.  8^/
Before writing this post I came across this:
https://www.cyberciti.biz/cloud-computi … t-working/
Also add the path at the beginning of your script
PATH=/path/1:/path/2
PATH=/sbin:/usr/sbin/:/usr/local/sbin:/bin:/usr/local/bin
But the page it is linked to does not say that the path has to be at the beginning of the script.
In any case, the thing is that /var/log/cron.log does not show the script being run:
groucho@devuan:~$ grep -i /sbin/fstrim /var/log/cron.log
groucho@devuan:~$
#12 2021-03-28 21:20:32
Good. As you might know, anacron is supposed to provide the extended cron function to make sure that the regular scripts are run even if the machine happens to be down at the nominal trigger time. Since the scripts are not run it is possible that this "chain of control" is broken; that cron fails to run anacron or that anacron fails to run the script(s).
The running of anacron is typically set up using the sysvinit start/stop script, once initially at  boot up, and then regularly by cron with the schedule contol script /etc/cron.d/anacron. Afaict looking at my such script, it includes the particual misfeature of not running anacron imperatively but rather making this dependent on the absence of something. (A small-brain idea appearing as attempted solution to cater for a range of possible installation sites other than this one, but not bad enough for the effort of forking the package)
So, if that something is present then your set up does not run anacron as it should and consequently your weekly script won't be run "automatically". Similarly the boot up run of the script only happens at boot up if it's set up so.
If the preconditions for the regular run/start of anacron are there, the next point of call would be to review and confirm anacron local configuration, at both /etc/anacrontab and /etc/default/anacron. And for debugging purposes also add/change the start/stop script so that it makes some output to, say, /tmp/WTF (eg a date stamp) whenever it's run. Further, to speed up the testing cycle you might set it up for daily trimming rather than weekly since the auto-magic is supposedly the same for that (as configured in the typical installed /etc/anacrontab).
#13 2021-03-28 22:30:24
... anacron is supposed to provide the extended cron function to make sure that the regular scripts are run even if the machine happens to be down at the nominal trigger time.
You give me too much credit, I did not know about that.
Thanks for the heads up.  8^)
... possible that this "chain of control" is broken; that cron fails to run anacron or that anacron fails to run the script(s).
I see ...
Ahh ...
Must be why I got this mail from the system a couple of days ago:
From root@devuan Thu Mar 25 23:30:01 2021
Return-path: <root@devuan>
Envelope-to: root@devuan
Delivery-date: Thu, 25 Mar 2021 23:30:01 -0300
Received: from root by devuan with local (Exim 4.92)
	(envelope-from <root@devuan>)
	id 1lPcEb-0006Cr-Jd
	for root@devuan; Thu, 25 Mar 2021 23:30:01 -0300
To: root@devuan
Subject: Cron <root@devuan> [ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi
MIME-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 8bit
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <LOGNAME=root>
Message-Id: <E1lPcEb-0006Cr-Jd@devuan>
Date: Thu, 25 Mar 2021 23:30:01 -0300
Status: RO
invoke-rc.d: -----------------------------------------------------
invoke-rc.d: WARNING: 'invoke-rc.d anacron start' called
invoke-rc.d: during shutdown sequence.
invoke-rc.d: enabling safe mode: initscript policy layer disabled
groucho@devuan:~$
Is this what you are referring to?
I get a bad shutdown every so often.
It's the crap BIOS in my Ultra24, maybe it kicked in at the right time.
... anacron is typically set up using the sysvinit start/stop script, once initially at boot up, and then regularly by cron with the schedule contol script /etc/cron.d/anacron.
Yes: " ... this script is to run anacron at boot so that it can catch up with missed jobs."
... includes the particual misfeature of not running anacron imperatively but rather making this dependent on the absence of something.
What would that be?
The part of /etc/init.d/anacron where it checks for on_ac_power returning a value of '0'?
What else would my workstation run on?
... if that something is present then your set up does not run anacron as it should ...
Surgery time?
Which lines should I comment?
groucho@devuan:~$ cat /etc/init.d/anacron
#! /bin/sh
### BEGIN INIT INFO
# Provides:          anacron
# Required-Start:    $remote_fs $syslog $time
# Required-Stop:     $remote_fs $syslog $time
# Default-Start:     2 3 4 5
# Default-Stop:
# Short-Description: Run anacron jobs
# Description: The first purpose of this script is to run anacron at
#              boot so that it can catch up with missed jobs.  Note
#              that anacron is not a daemon.  It is run here just once
#              and is later started by the real cron.  The second
#              purpose of this script is that said cron job invokes
#              this script to start anacron at those subsequent times,
#              to keep the logic in one place.
### END INIT INFO
PATH=/bin:/usr/bin:/sbin:/usr/sbin
test -x /usr/sbin/anacron || exit 0
test -r /etc/default/anacron && . /etc/default/anacron
. /lib/lsb/init-functions
case "$1" in
  start)
    if init_is_upstart 2>/dev/null; then
        exit 1
    fi
    log_daemon_msg "Starting anac(h)ronistic cron" "anacron"
    if test x"$ANACRON_RUN_ON_BATTERY_POWER" != x"yes" && test -x /usr/bin/on_ac_power
    then
        /usr/bin/on_ac_power >/dev/null
        if test $? -eq 1
        then
          log_progress_msg "deferred while on battery power"
	  log_end_msg 0
	  exit 0
        fi
    fi
    # on_ac_power doesn't exist, on_ac_power returns 0 (ac power being used)
    # or on_ac_power returns 255 (undefined, desktop machine without APM)
    start-stop-daemon --start --exec /usr/sbin/anacron -- $ANACRON_ARGS
    log_end_msg 0
  restart|force-reload|reload)
	# nothing to do
  stop)
    if init_is_upstart 2>/dev/null && status anacron 2>/dev/null | grep -q start
    then
        exit 0
    fi
    log_daemon_msg "Stopping anac(h)ronistic cron" "anacron"
    start-stop-daemon --stop --exec /usr/sbin/anacron --oknodo --quiet --retry=USR1/90/TERM/5/KILL/5
    log_end_msg 0
  status)
    exit 4
    echo "Usage: /etc/init.d/anacron {start|stop|restart|force-reload|reload}"
    exit 2
esac
exit 0
groucho@devuan:~$
... consequently your weekly script won't be run "automatically".
This is what I see within the last 50 entries in /var/log/cron.log:
groucho@devuan:/var/log$ tail -50 cron.log | grep -i anacron
Mar 28 16:30:01 devuan CRON[10380]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
Mar 28 17:30:01 devuan CRON[20351]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
Mar 28 18:30:01 devuan CRON[5177]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
If the preconditions for the regular run/start of anacron are there ...
If I understood correctly (?), they are not.
Is there something I have to do with /etc/init.d/anacron?
Thanks a lot for your input.
BTW: would it be possible to increase the logged-on time out?
#14 2021-03-28 23:08:09
Ok. cron.log shows that it finds and loads and processes the /etc/cron.d/anacron scheduling, which would trigger the start/stop script if
  1. there is an executable /etc/init.d/anacron (script), and
  2. the pathname /run/systemd/system is not a directory (eg doesn't exist)
To verify that you would add the following two lines into the script /etc/init.d/anacron:
exec 2>>/tmp/WTF
date -R >&2
just after the PATH=... line.
That should cause an hourly logging to appear in the file /tmp/WTF, and that file will also contain any other stderr output that the script run generates.
In detail: the exec 2>>/tmp/WTF line associates standard error (for this script run) in append mode with the file, and the date -R >&2 line makes the date program issue a time stamp in RFC 5322 format to standard error. Any further error message from the script will be appended subsequently.
#15 2021-03-29 00:06:21
there is an executable /etc/init.d/anacron (script) ...
It's there, the one I posted.
... and the pathname /run/systemd/system is not a directory (eg doesn't exist)
It doesn't.
groucho@devuan:~$ ls /run/systemd
cgroups-agent  inaccessible  machines  seats  sessions  users
groucho@devuan:~$
... add the following two lines into the script /etc/init.d/anacron:
exec 2>>/tmp/WTF
date -R >&2
... just after the PATH=... line.
#! /bin/sh
exec 2>>/tmp/WTF
date -R >&2
groucho@devuan:~$
Done.
... cause an hourly logging to appear in the file /tmp/WTF, and that file will also contain any other stderr output ...
... the exec 2>>/tmp/WTF line associates standard error (for this script run) in append mode with the file ...
... the date -R >&2 line makes the date program issue a time stamp ...
... error message from the script will be appended ...
Right.
I'll check with /tmp/WTF tomorrow and get back with the results.
Thank you very much for your help.
#16 2021-03-29 16:17:53
Also check if the cron.weekly script is recognised and run:
run-parts --test /etc/cron.weekly
^ That will show a list of the scripts to be run.
#17 2021-03-29 20:34:57
mknoop
From my experience, scripts in cron.* will not run unless the file name ends in ".sh".  Changing the suffix on the filename is one way to turn off the execution for a while.  It looks like you script is named dev-fstrim.
#18 2021-03-29 20:58:02
Here's what happened:
As posted previously, I set up WTF.
exec 2>>/tmp/WTF
date -R >&2
I also copied the script that should run in cron.weekly to cron.daily:
groucho@devuan:~$ ls -1 /etc/cron.daily/
dev-fstrim
groucho@devuan:~$
I monitored it a couple of times before I shut down the box and all I saw was a set of hourly entries such as this one:
groucho@devuan:~$ cat /tmp/WTF
Mon, 29 Mar 2021 16:57:57 -0300
groucho@devuan:~$
The first one was at boot time.
The following one was at the next HH:30 mark and from then on, once every hour.
No errors logged.
Obviously, /tmp/WTF did not survive a reboot.
This morning I booted the box, did some work and went out to get some stuff.
When I returned, all I saw were a set of hourly entries but with no errors logged.
A look at /var/log/trim.log does not show anyhing new:
groucho@devuan:~$ cat /var/log/trim.log
groucho@devuan:~$
From a previous post we know that the script will run if I do it manually:
Tested it again as USER so it won't really run.
groucho@devuan:~$ /etc/cron.daily/dev-fstrim
/etc/cron.daily/dev-fstrim: 7: /etc/cron.daily/dev-fstrim: cannot create /var/log/trim.log: Permission denied
/etc/cron.daily/dev-fstrim: 8: /etc/cron.daily/dev-fstrim: cannot create /var/log/trim.log: Permission denied
groucho@devuan:~$
groucho@devuan:~$ /etc/cron.weekly/dev-fstrim
/etc/cron.weekly/dev-fstrim: 7: /etc/cron.weekly/dev-fstrim: cannot create /var/log/trim.log: Permission denied
/etc/cron.weekly/dev-fstrim: 8: /etc/cron.weekly/dev-fstrim: cannot create /var/log/trim.log: Permission denied
groucho@devuan:~$
Q: why am I seeing it run twice?
... check if the cron.weekly script is recognised and run:
Here they are:
groucho@devuan:~$ run-parts --test /etc/cron.daily
groucho@devuan:~$
groucho@devuan:~$ run-parts --test /etc/cron.weekly
groucho@devuan:~$
It seems that the ownership of the scripts is correct:
groucho@devuan:~$ ls -l /sbin/fstrim
-rwxr-xr-x 1 root root 72808 Nov 27  2019 /sbin/fstrim
groucho@devuan:~$
groucho@devuan:~$ ls -l /etc/cron.daily/dev-fstrim
-rwxr-xr-x 1 root root 236 Mar 29 11:09 /etc/cron.daily/dev-fstrim
groucho@devuan:~$
groucho@devuan:/var/log$ ls -l /etc/cron.weekly/dev-fstrim
-rwxr-xr-x 1 root root 238 Mar  9 14:18 /etc/cron.weekly/dev-fstrim
That's all I have.
What else can I do?
#19 2021-03-29 21:07:58
mknoop
I apologize.  This is the opposite of the truth.  Just ignore me, as you already are.
#20 2021-03-29 21:28:35
mknoop wrote:
I apologize.
... is the opposite ...
... ignore me, as you already ...
No, not ignoring you.
I was checking to find the link to what I had read yesterday about that so you could see it.
Moot point now.
It's the intention that counts.
Thanks for your input.  8^)
#21 2021-03-30 00:25:16
So apparently the anacron start/stop script gets invoked every hour as it should, but it fails to perform.
Add set -x on a line after your added date ... in /etc/init.d/anacron, and then wait for next invocation which now logs the whole script execution to /tmp/WTF. This in particular should have the line:
+ start-stop-daemon --start --exec /usr/sbin/anacron -- -s
Seeing that to be so you would next try to force run the weekly scripts again. First ensure any previous run has completed, with
pgrep -a run-parts
returning nothing, and then use
run-parts --verbose /etc/cron.weekly
to see the new, forced weekly run happening.
#22 2021-03-30 01:02:45
... anacron start/stop script gets invoked every hour as it should, but it fails to perform.
That seems to be the case:
Mon, 29 Mar 2021 17:30:01 -0300
Mon, 29 Mar 2021 18:30:01 -0300
Mon, 29 Mar 2021 19:30:01 -0300
Mon, 29 Mar 2021 20:30:01 -0300
Mon, 29 Mar 2021 21:30:01 -0300
groucho@devuan:~$
Add set -x on a line after your added date ... in /etc/init.d/anacron ...
Here it is:
#! /bin/sh
exec 2>>/tmp/WTF
date -R >&2
set -x
groucho@devuan:~$
... wait for next invocation which now logs the whole script execution to /tmp/WTF.
Right.
... should have the line:
I'll be watching a series and waiting for it.
Should happen before it ends. 8^7
... you would next try to force run the weekly scripts again.
... ensure any previous run has completed, with
pgrep -a run-parts
returning nothing ...
... then use
I'll do that and post back.
Q: if I change the destination from /tmp/WTF to /var/log/WTF, will it survive a reboot and append the in-between boot results?
Thanks a lot for your help.
#23 2021-03-30 01:59:39
Here's /tmp/WTF before shutting down for the day:
Mon, 29 Mar 2021 22:30:01 -0300
+ test -x /usr/sbin/anacron
+ test -r /etc/default/anacron
+ . /etc/default/anacron
+ ANACRON_RUN_ON_BATTERY_POWER=no
+ ANACRON_ARGS=-s
+ . /lib/lsb/init-functions
+ run-parts --lsbsysinit --list /lib/lsb/init-functions.d
+ [ -r /lib/lsb/init-functions.d/20-left-info-blocks ]
+ . /lib/lsb/init-functions.d/20-left-info-blocks
+ FANCYTTY=
+ [ -e /etc/lsb-base-logging.sh ]
+ true
+ init_is_upstart
+ log_daemon_msg Starting anac(h)ronistic cron anacron
+ [ -z Starting anac(h)ronistic cron ]
+ log_daemon_msg_pre Starting anac(h)ronistic cron anacron
+ log_use_fancy_output
+ TPUT=/usr/bin/tput
+ EXPR=/usr/bin/expr
+ [ -t 1 ]
+ FANCYTTY=0
+ false
+ [ -z anacron ]
+ echo -n Starting anac(h)ronistic cron: anacron
+ log_daemon_msg_post Starting anac(h)ronistic cron anacron
+ test xno != xyes
+ test -x /usr/bin/on_ac_power
+ /usr/bin/on_ac_power
+ test 255 -eq 1
+ start-stop-daemon --start --exec /usr/sbin/anacron -- -s    <--- | x |
+ log_end_msg 0
+ [ -z 0 ]
+ local retval
+ retval=0
+ log_end_msg_pre 0
+ [ -t 1 ]
+ FANCYTTY=0
+ false
+ [ -t 1 ]
+ FANCYTTY=0
+ false
+ RED=
+ YELLOW=
+ NORMAL=
+ [ 0 -eq 0 ]
+ echo .
+ log_end_msg_post 0
+ return 0
+ exit 0
groucho@devuan:~$
Well, + start-stop-daemon --start --exec /usr/sbin/anacron -- -s is there.
Is something running?
groucho@devuan:~$ pgrep -a run-parts
groucho@devuan:~$
No.
Forcing weekly scripts:
groucho@devuan:~$ run-parts --verbose /etc/cron.weekly
run-parts: executing /etc/cron.weekly/0anacron
/etc/cron.weekly/0anacron: 12: /etc/cron.weekly/0anacron: anacron: not found
run-parts: /etc/cron.weekly/0anacron exited with return code 127
run-parts: executing /etc/cron.weekly/dev-fstrim
run-parts: /etc/cron.weekly/dev-fstrim exited with return code 2
run-parts: executing /etc/cron.weekly/man-db
/etc/cron.weekly/man-db: 28: /etc/cron.weekly/man-db: start-stop-daemon: not found
run-parts: /etc/cron.weekly/man-db exited with return code 127
run-parts: executing /etc/cron.weekly/rkhunter
groucho@devuan:~$
groucho@devuan:~$
Yes, there we go!
Many instances of not found and Permission denied
Yes, WTF is right.
What's up with this?
#24 2021-03-30 10:27:49
Peculiar. Yes, the run-parts .. command if run as root would avoid the permission errors, but your test shows that the dev-fstrim does get invoked, which is enough of detail.
yes, you can use /var/log/WTF for persistent logging.
Peculiar. How do your /etc/anacrontab and /etc/default/anacron look?
#25 2021-03-30 10:49:23
Peculiar.
Any idea as to what could have caused this situation?
As far as 'permissions' go, I did have a kept back files issue that ended up in upgrading from consolkit to elogind.
See http://dev1galaxy.org/viewtopic.php?id=4130
... your test shows that the dev-fstrim does get invoked, which is enough of detail.
Good.
Here's this morning's first entry in /tmp/WTF:
Tue, 30 Mar 2021 07:15:55 -0300
+ ANACRON_ARGS=-s
+ FANCYTTY=
+ true
+ init_is_upstart
+ [ -t 1 ]
+ [ xlinux != x ]
+ [ xlinux != xdumb ]
+ [ -x /usr/bin/tput ]
+ [ -x /usr/bin/expr ]
+ /usr/bin/tput hpa 60
+ /usr/bin/tput setaf 1
+ [ -z ]
+ FANCYTTY=1
+ true
+ echo -n [....]
+ [ -z anacron ]
+ test xno != xyes
+ test 255 -eq 1
+ log_end_msg 0
+ [ -z 0 ]
+ local retval
+ retval=0
+ log_end_msg_pre 0
+ [ -t 1 ]
+ [ xlinux != x ]
+ [ -z 1 ]
+ true
+ true
+ RED=
+ /usr/bin/tput setaf 2
+ GREEN=
+ /usr/bin/tput setaf 3
+ YELLOW=
+ /usr/bin/tput op
+ NORMAL=
+ /usr/bin/tput civis
+ /usr/bin/tput sc
+ /usr/bin/tput hpa 0
+ [ 0 -eq 0 ]
+ /bin/echo -ne [ ok
+ /usr/bin/tput rc
+ /usr/bin/tput cnorm
+ [ -t 1 ]
+ [ xlinux != x ]
+ [ -z 1 ]
+ true
+ true
+ RED=
+ YELLOW=
+ /usr/bin/tput op
+ NORMAL=
+ [ 0 -eq 0 ]
+ echo .
+ return 0
+ exit 0
Tue, 30 Mar 2021 07:30:01 -0300
+ ANACRON_ARGS=-s
+ FANCYTTY=
+ true
+ init_is_upstart
+ [ -t 1 ]
+ FANCYTTY=0
+ false
+ [ -z anacron ]
+ test xno != xyes
+ test 255 -eq 1
+ log_end_msg 0
+ [ -z 0 ]
+ local retval
+ retval=0
+ log_end_msg_pre 0
+ [ -t 1 ]
+ FANCYTTY=0
+ false
+ [ -t 1 ]
+ FANCYTTY=0
+ false
+ RED=
+ YELLOW=
+ NORMAL=
+ [ 0 -eq 0 ]
+ echo .
+ return 0
+ exit 0
groucho@devuan:~$
... /var/log/WTF for persistent logging.
Right.
Here they are:
groucho@devuan:~$ cat /etc/anacrontab
# /etc/anacrontab: configuration file for anacron
# See anacron(8) and anacrontab(5) for details.
SHELL=/bin/sh
HOME=/root
LOGNAME=root
# These replace cron's entries
1	5	cron.daily	run-parts --report /etc/cron.daily
7	10	cron.weekly	run-parts --report /etc/cron.weekly
@monthly	15	cron.monthly	run-parts --report /etc/cron.monthly
groucho@devuan:~$
groucho@devuan:~$ cat /etc/default/anacron
# Environment File for anacron
# ANACRON_RUN_ON_BATTERY_POWER
# NOTE:
#       For ANACRON_RUN_ON_BATTERY_POWER, settings here only works
#       when you are not using systemd.
#       Please read /usr/share/doc/anacron/README.Debian
#       to see how to adjust program behaviour on AC power.
# If set to "yes", start anacron even when on battery power.  By
# default, the /etc/init.d/anacron script tries to avoid running
# anacron unless on AC power, so as to avoid running down the battery.
# (Things like the locate updatedb cause a lot of I/O.)
# ANACRON_ARGS
# Arguments/options to pass to anacron.
# By default, "-s" is used to ensure serialised job arrangements.
# If you want tasks to execute in parallel when the jobs are due to
# start, do not pass "-s" here.
ANACRON_ARGS=-s
groucho@devuan:~$
