#1 2021-02-19 14:00:10
[Solved] libpolkit-qt-5-1-1 kept back after ASCII --> Beowulf upgrade
I had been putting off upgrading from ASCII to Beowulf for the longest while but now it is done.
A new upgraded VirtualBox installation is in place and everything seems to be working.
groucho@devuan:~$ uname -a
Linux devuan 4.19.0-14-amd64 #1 SMP Debian 4.19.171-2 (2021-01-30) x86_64 GNU/Linux
groucho@devuan:~$
I did get an unasked for Firefox-ESR, maybe it is part of a metapackage from the ASCII installation?
What I cannot seem to find information on is libpolkit-qt5-1-1 being kept back:
[root@devuan ~]# apt update && apt install -f && apt upgrade
Hit:1 http://deb.devuan.org/merged beowulf InRelease
Hit:2 http://deb.devuan.org/merged beowulf-security InRelease
Hit:3 http://deb.devuan.org/merged beowulf-updates InRelease
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Calculating upgrade... Done
  libpolkit-qt5-1-1
[root@devuan ~]#
Could anyone shed some light on this for me?
Thanks in advance,
#2 2021-02-19 14:51:00
Re: [Solved] libpolkit-qt-5-1-1 kept back after ASCII --> Beowulf upgrade
What happens on
apt full-upgrade
#3 2021-02-19 15:01:55
dice
why not apt update && apt dist-upgrade
#4 2021-02-19 16:18:48
rolfie wrote:
What happens on
apt full-upgrade
This:
[root@devuan ~]# apt full-upgrade
  libpolkit-qt5-1-1
[root@devuan ~]#
Because it is the same thing in/with a different command?
[root@devuan ~]# apt update && apt dist-upgrade
Get:3 http://deb.devuan.org/merged beowulf-updates InRelease [26.0 kB]
Fetched 26.0 kB in 2s (13.6 kB/s)
  libpolkit-qt5-1-1
[root@devuan ~]#
I tried looking at reasons for this:
[root@devuan ~]# aptitude why libpolkit-qt5-1-1
i   backintime-qt4       Depends  backintime-common (= 1.1.24-0.1)
i A backintime-common    Depends  python3-keyring
i A python3-keyring      Suggests libkf5wallet-bin
i A libkf5wallet-bin     Depends  libkf5configwidgets5 (>= 4.96.0)
i A libkf5configwidgets5 Depends  libkf5auth5 (>= 4.96.0)
i A libkf5auth5          Depends  libpolkit-qt5-1-1 (>= 0.112.0)
[root@devuan ~]#
[root@devuan ~]# apt install libpolkit-qt5-1-1
 libpolkit-qt5-1-1 : Depends: libpam-systemd
So then I tried to see if I could install the missing dependency:
[root@devuan ~]# apt install libpam-systemd
Note, selecting 'libpam-elogind' instead of 'libpam-systemd'   <------------  this is the clue?
  libcgmanager0 liblz4-1:i386 libnih-dbus1 libnih1
Use 'apt autoremove' to remove them.
  elogind:i386 libacl1:i386 libattr1:i386 libelogind0 libelogind0:i386 libpolkit-backend-elogind-1-0 libpolkit-gobject-elogind-1-0
Recommended packages:
  libpam-elogind:i386
  consolekit libpam-ck-connector libpolkit-backend-consolekit-1-0 libpolkit-gobject-consolekit-1-0 libsystemd0 libsystemd0:i386
  elogind:i386 libacl1:i386 libattr1:i386 libelogind0 libelogind0:i386 libpam-elogind libpolkit-backend-elogind-1-0
0 upgraded, 8 newly installed, 6 to remove and 1 not upgraded.
Need to get 1414 kB of archives.
After this operation, 2204 kB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
[root@devuan ~]#
Now, seeing that I did an ASCII --> Beowulf dist-upgrade as per the pertinent instructions, why is this happening?
Was something missing in my ASCII?
Did I miss something whiole installing?
Do I have to install libpam-elogind?
Is consolekit no longer used?
I recall it was the one I had to use for the SLiM/XFCE combination.
Thanks you both for your input.
Cheers,
#5 2021-02-19 16:48:46
Andre4freedom
Hello Altoid et all...
I remember this issue from dev ASCII days. Here is a very helpful post:
https://dev1galaxy.org/viewtopic.php?pid=17834#p17834
I use the Cinnamon Desktop which implies the lightdm Display Manager. But, the consolekit and logind question is the same.
Once you resolve the thing in ASCII properly, there is nothing in the way to an
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
sudo apt auto-remove
anymore. I could repeat it on ASCII systems using XFCE4 and Cinnamon systems.
I have followed fred43's instructions to the letter and I was successful.
Good luck.
#6 2021-02-20 00:38:40
dice
  libpam-elogind:i386
Abort.
[root@devuan ~]#
Cheers,
That looks fairly normal to me. That should fix the libpolkit-qt5-1-1 issue, does it?
#7 2021-02-20 01:41:20
Don't know, havent tried.
The thing is that my Beowulf VM, which does not have BackInTime installed, does not have this problem:
root@devuan:~# uname -a
root@devuan:~#
root@devuan:~# apt update && apt install -f && apt upgrade
Get:2 http://deb.devuan.org/merged beowulf-updates InRelease [26.0 kB]
Hit:3 http://deb.devuan.org/merged beowulf-security InRelease
Fetched 26.0 kB in 6s (4455 B/s)
All packages are up to date.
root@devuan:~#
Seems that BackInTime needs this chain to be complete ...
[root@devuan ~]#
[root@devuan ~]#
But then ...
groucho@devuan:~$ aptitude why-not  libpolkit-qt5-1-1
Automatically installed, current version 0.112.0-5, priority optional
The candidate version 0.112.0-6 has priority optional
No dependencies require to remove libpolkit-qt5-1-1        <-----------
groucho@devuan:~$
And ...
groucho@devuan:~$ aptitude why-not libpam-elogind
i   libpolkit-backend-consolekit-1-0 Conflicts libpam-elogind
groucho@devuan:~$
The often unread Release Notes for Beowulf say:
Both slim and lightdm will work with either libpam-elogind or consolekit.
Slim is the default login manager for Xfce. Lightdm is the default for
the other desktops.
If No dependencies require to remove libpolkit-qt5-1-1 it may be worthwhile leaving things as they are for the time being.
It could be that the libpolkit-backend-consolekit-1-0 conflict with libpam-elogind eventually gets sorted out. (?)
Makes sense?
Cheers,
#8 2021-02-20 10:48:08
dice
i dont know i dont use backintime. Ill get on my other machine running beowulf soon and see what happens when i install backintime.
going forward though i believe elogind is the preferred choice over consolekit?
Edit: are you using the lxqt desktop maybe? You didnt say.
I have no issues installing and using backintime-qt4 using my xfce4 partition, polkit for that is gnome.
#9 2021-02-20 11:33:59
dice wrote:
... dont use backintime.
... see what happens when i install backintime.
Thanks.
dice wrote:
... elogind is the preferred choice over consolekit?
Don't know.
dice wrote:
... using the lxqt desktop maybe?
No, the XFCE that came by default with ASCII
groucho@devuan:~$ apt list | grep -i installed | grep xfce4
xfce4/stable,stable,now 4.12.5 all [installed]
groucho@devuan:~$
dice wrote:
... no issues installing and using backintime-qt4 ...
Mine is not Qt:
groucho@devuan:~$ apt list | grep -i installed | grep backintime
backintime-common/stable,stable,now 1.1.24-0.1 all [installed,automatic]
backintime-qt4/stable,stable,now 1.1.24-0.1 all [installed]
groucho@devuan:~$
Thanks for your input.
Cheers,
#10 2021-02-20 11:48:54
dice
Thanks.
Don't know.
groucho@devuan:~$
Mine is not Qt:
groucho@devuan:~$
Cheers,
Looks like you have backintime-qt4 installed ??
Do you use any kde apps ?
#11 2021-02-20 12:37:39
Indeed ...  8^/
What a (quite embarrassed) dick!
Sorry for the slip-up, that's what happens with not enough coffee after a bad night's sleep.
Yes, that's quite evidently backintime-qt4.
Here's all the qt I found:
groucho@devuan:~$ apt list | grep -i installed | grep -i qt
libdbusmenu-qt5-2/stable,now 0.9.3+16.04.20160218-1 amd64 [installed,automatic]
libphonon4qt5-4/stable,now 4:4.10.2-1 amd64 [installed,automatic]
libqt4-dbus/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-declarative/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-designer/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-help/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-network/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-script/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-scripttools/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-sql-mysql/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-sql/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-svg/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-test/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-xml/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt4-xmlpatterns/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqt5core5a/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqt5dbus5/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqt5gui5/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqt5network5/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqt5opengl5/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqt5positioning5/stable,now 5.11.3+dfsg-2 amd64 [installed,automatic]
libqt5printsupport5/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqt5qml5/stable,now 5.11.3-4 amd64 [installed,automatic]
libqt5quick5/stable,now 5.11.3-4 amd64 [installed,automatic]
libqt5sensors5/stable,now 5.11.3-2 amd64 [installed,automatic]
libqt5svg5/stable,now 5.11.3-2 amd64 [installed,automatic]
libqt5texttospeech5/stable,now 5.11.3-3 amd64 [installed,automatic]
libqt5waylandclient5/stable,now 5.11.3-2 amd64 [installed,automatic]
libqt5waylandcompositor5/stable,now 5.11.3-2 amd64 [installed,automatic]
libqt5webchannel5/stable,now 5.11.3-2 amd64 [installed,automatic]
libqt5webkit5/stable,now 5.212.0~alpha2-21 amd64 [installed,automatic]
libqt5widgets5/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqt5x11extras5/stable,now 5.11.3-2 amd64 [installed,automatic]
libqt5xml5/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
libqtassistantclient4/stable,now 4.6.3-7+b1 amd64 [installed,automatic]
libqtcore4/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqtdbus4/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqtgui4/stable,now 4:4.8.7+dfsg-18+deb10u1 amd64 [installed,automatic]
libqwt-qt5-6/stable,now 6.1.4-1 amd64 [installed,automatic]
phonon4qt5-backend-vlc/stable,now 0.10.2-1 amd64 [installed,automatic]
phonon4qt5/stable,now 4:4.10.2-1 amd64 [installed,automatic]
pinentry-qt/stable,now 1.1.0-2 amd64 [installed,automatic]
python-qt4/stable,now 4.12.1+dfsg-2+b1 amd64 [installed,automatic]
python3-dbus.mainloop.qt/stable,now 4.12.1+dfsg-2+b1 amd64 [installed,automatic]
python3-pyqt4/stable,now 4.12.1+dfsg-2+b1 amd64 [installed]
qt-at-spi/stable,now 0.4.0-9 amd64 [installed,automatic]
qt5-gtk-platformtheme/stable,now 5.11.3+dfsg1-1+deb10u4 amd64 [installed,automatic]
qtchooser/stable,now 66-2 amd64 [installed,automatic]
qtcore4-l10n/stable,stable,now 4:4.8.7+dfsg-18+deb10u1 all [installed,automatic]
qttranslations5-l10n/stable,stable,now 5.11.3-2 all [installed,automatic]
qtwayland5/stable,now 5.11.3-2 amd64 [installed,automatic]
vlc-plugin-qt/stable,stable-security,now 3.0.12-0+deb10u1 amd64 [installed,automatic]
groucho@devuan:~$
But ...
Where did qtwayland5 come from?
groucho@devuan:~$ aptitude why qtwayland5
i   virtualbox-6.1 Depends  libqt5gui5 (>= 5.4.0)
i A libqt5gui5     Suggests qtwayland5
groucho@devuan:~$
Suggests should be off by default.
dice wrote:
Do you use any kde apps?
Seems not ...
groucho@devuan:~$ apt list | grep -i installed | grep -i kde
libblockdev-crypto2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
libblockdev-fs2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
libblockdev-loop2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
libblockdev-part-err2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
libblockdev-part2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
libblockdev-swap2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
libblockdev-utils2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
libblockdev2/stable,now 2.20-7+deb10u1 amd64 [installed,automatic]
groucho@devuan:~$
Cheers,
#12 2021-02-20 13:59:25
dice
I think you will be ok upgrading from consolkit to elogind.
#13 2021-02-20 14:17:00
dice wrote:
... think you will be ok upgrading from consolkit to elogind.
Thanks, I'll see about trying to get it done this weekend.
It seems that consolekit is deprecated and maybe on its way out. (?)
See https://bugs.devuan.org/db/42/425.html
Received: (at submit) by bugs.devuan.org; 23 Apr 2020 21:30:02 +0000
Return-Path: <alexispm_stellaluna@yahoo.es>
Delivered-To: devuanbugs@dyne.org
Package: policykit-1
Version: 0.105-25+devuan8
policykit-1 dependency is declared as "logind" instead of "elogind", forcing to use de deprecated (no buster yet) consolekit.    <- my highlighting
Thanks a lot for your input.
Cheers,
#14 2021-02-20 15:07:03
... see about trying to get it done this weekend.
Had an idle half hour while waiting for something, like we are all doing these days.
Upgrade worked, without issues.  =^D
Then I checked to see:
groucho@devuan:~$ apt list | grep -i installed | grep consolekit
groucho@devuan:~$
OK, consolekit is no longer installed.
I went further and found this:
groucho@devuan:~$ apt list | grep -i consolekit
consolekit-dbgsym/stable 1.2.1-8 amd64
consolekit-dbgsym/stable 1.2.1-8 i386
consolekit/stable,now 1.2.1-8 amd64 [residual-config]      <-------
consolekit/stable 1.2.1-8 i386
libconsolekit-dev/stable 1.2.1-8 amd64
libconsolekit-dev/stable 1.2.1-8 i386
libconsolekit1-dbgsym/stable 1.2.1-8 amd64
libconsolekit1-dbgsym/stable 1.2.1-8 i386
libconsolekit1/stable 1.2.1-8 amd64
libconsolekit1/stable 1.2.1-8 i386
libpolkit-backend-consolekit-1-0-dbgsym/stable 0.105-25+devuan8 amd64
libpolkit-backend-consolekit-1-0-dbgsym/stable 0.105-25+devuan8 i386
libpolkit-backend-consolekit-1-0/stable 0.105-25+devuan8 amd64
libpolkit-backend-consolekit-1-0/stable 0.105-25+devuan8 i386
libpolkit-backend-consolekit-1-dev/stable 0.105-25+devuan8 amd64
libpolkit-backend-consolekit-1-dev/stable 0.105-25+devuan8 i386
libpolkit-gobject-consolekit-1-0-dbgsym/stable 0.105-25+devuan8 amd64
libpolkit-gobject-consolekit-1-0-dbgsym/stable 0.105-25+devuan8 i386
libpolkit-gobject-consolekit-1-0/stable 0.105-25+devuan8 amd64
libpolkit-gobject-consolekit-1-0/stable 0.105-25+devuan8 i386
libpolkit-gobject-consolekit-1-dev/stable 0.105-25+devuan8 amd64
libpolkit-gobject-consolekit-1-dev/stable 0.105-25+devuan8 i386
groucho@devuan:~$
So I asked:
groucho@devuan:~$ aptitude why consolekit
i   slim Depends default-logind | logind | consolekit
groucho@devuan:~$
What does this mean in practical terms? eg: for slim which I am fond of.
Thanks in advance,
#15 2021-02-20 15:27:37
dice
~$ aptitude why-not consolekit
i   policykit-1-gnome             Depends   policykit-1
i A policykit-1                   Depends   libpolkit-backend-1-0 (= 0.105-25+devuan8)
i A libpolkit-backend-1-0         Depends   libpolkit-backend-elogind-1-0 | libpolkit-backend-consolekit-1-0
i A libpolkit-backend-elogind-1-0 Conflicts consolekit
why are you using apt list ?
if you want to see what is on your system use dpkg
dpkg -l | grep -i consolekit
#16 2021-02-20 16:47:35
Gives me information of what's installed from the apt repertoire?
I find why and why-not quite enlightening.
OK.
groucho@devuan:~$ dpkg -l | grep -i consolekit
rc  consolekit                             1.2.1-8                             amd64        framework for defining and tracking users, sessions and seats
ii  libck-connector0:amd64                 1.2.1-8                             amd64        ConsoleKit libraries
groucho@devuan:~$
Thanks a lot for the heads-up.
Cheers,
#17 2021-02-20 18:27:21
groucho@devuan:~$
It means slim needs something that provides default-logind or one of the others on that line. If a package depends on libpam-system | libpam-elogind, it'll complain about missing libpam-systemd if neither of those is there. Install libpam-elogind first and anything that wants libpam-systemd will be happy. (See the Provides line below)
$ apt show libpam-elogind
Package: libpam-elogind
Version: 241.4-2
Priority: optional
Source: elogind
Provides: default-logind, libpam-systemd, logind
Depends: libc6 (>= 2.28), libcap2 (>= 1:2.10), libpam0g (>= 0.99.7.1), elogind (= 241.4-2), libpam-runtime
Conflicts: libpam-ck-connector
Breaks: libpam-systemd
Replaces: libpam-systemd
#18 2021-02-20 19:57:10
fsmithred wrote:
... mean in practical terms? eg: for slim which I am fond of.
... slim needs something that provides default-logind or one of the others on that line.
So ...
slim depends on default-logind or logind or consolekit.
Right?
My question was aimed more at the existence of consolekit as a residual configuration component:
groucho@devuan:~$
I see ...
Seeing that the residual consolekit is there after I installed elogind, something will surely break if I remove it, right?
Maybe I am giving the residual aspect of it too much importance. (?)
Cheers,
#19 2021-02-23 12:33:22
groucho@devuan:~$
I'm writing on this again as I have found this in /var/log/slim.log:
slim: waiting for X server to begin accepting connections.
slim: Consolekit::open_session: Unable to open session: The name org.freedesktop.ConsoleKit was not provided by any .service files
slim: falling back to PAM session
groucho@devuan:/var/log$
It would seem that slim is still looking for consolekit in spite of it being replaced by elogind.
Why is that?
I am being able to log in without problems.
Thanks in advance,
#20 2021-02-23 16:29:00
Sorry, I don't know the answer. I see the "not provided by any .service files" a lot, and I just ignore it. I assume it's there to remind us all that we're not running systemd.
Try this:
apt -s remove consolekit
and see what it wants to take with it.
#21 2021-02-23 16:43:58
Why is that?
SLiM has been dead since 2013 so it doesn't support logind sessions correctly.
Use a different display manager. Or no display manager at all, they're just bloat anyway tongue
#22 2021-02-23 16:56:03
fsmithred wrote:
Sorry, I don't know ...
No problem.  8^D
fsmithred wrote:
... see the "not provided by any .service files" a lot, and I just ignore it.
Right.
fsmithred wrote:
... remind us all that we're not running systemd.
Lol ...
fsmithred wrote:
Try this:
[root@devuan ~]# apt -s remove consolekit
Package 'consolekit' is not installed, so not removed
[root@devuan ~]#
Nothing.
Cheers,
#23 2021-02-23 17:01:14
SLiM has been dead since 2013 ...
Still works ...
It's just the entry in slim.log.
... so it doesn't support logind sessions correctly.
I see.
... a different display manager.
I've always liked this one.
... no display manager at all ...
Tried that and had all sort of permission problems.
Si I installed slim and they all went away instantly.
So I'll keep it. 8^P!
Cheers,
#24 2021-02-23 20:42:12
fsmithred wrote:
... it's there to remind us all that we're not running systemd.
Hmm ...
Both the slim 1.3.6-5.1+devuan6 (merged beowulf/main) and 1.3.6-5.2+devuan1 (/merged beowulf /unstable) have default-logind | logind | consolekit as depends.
Depends slim 1.3.6-5.2+devuan1
libc6 (>= 2.14), libck-connector0, libdbus-1-3 (>= 1.9.14), libgcc1 (>= 1:3.0), libjpeg62-turbo (>= 1.3.1), libpam0g (>= 0.99.7.1), libpng16-16 (>= 1.6.2-1), libstdc++6 (>= 5.2), libx11-6, libxext6, libxft2 (>> 2.1.1), libxmu6, libxrandr2 (>= 2:1.2.99.3), debconf (>= 1.2.9) | debconf-2.0, dbus, default-logind | logind | consolekit, x11-xserver-utils, lsb-base
Depends slim 1.3.6-5.1+devuan6
libc6 (>= 2.17), libck-connector0, libdbus-1-3 (>= 1.9.14), libgcc-s1 (>= 3.0), libjpeg62-turbo (>= 1.3.1), libpam0g (>= 0.99.7.1), libpng16-16 (>= 1.6.2-1), libstdc++6 (>= 5.2), libx11-6, libxext6, libxft2 (>> 2.1.1), libxmu6, libxrandr2 (>= 2:1.2.99.3), debconf (>= 1.2.9) | debconf-2.0, dbus, default-logind | logind | consolekit, x11-xserver-utils, lsb-base
I looked to see if it was worth installing the unstable and check slim.log but I'd probably have an issue with libc6 (>= 2.17).
Cheers,
