#1 2021-02-07 02:21:44
pootler
appimages?
HI,
I am using  a reasonably fresh( 2 month) old install of devuan.
I am trying to run an appimage.
It is for an email client - called Criptext.
In ''properties'' for the image, , I have altered the permission to read & write, and also made the image ''executable''
However, no matter what I do , the app will not run upon double click.
Any ideas what I am doing wrong :-)
Thanks
pootler
#2 2021-02-07 05:51:29
szutt
Re: appimages?
Maybe this is due to sandboxing. Try adding --no-sandbox to the launch command. I found that : https://www.reddit.com/r/debian/comment … s_without/
#3 2021-02-07 09:47:50
PedroReina
Re: appimages?
Try to start the file from terminal. May be there are some messsage.
#4 2021-02-07 09:52:26
Re: appimages?
Black Lives Matter
#5 2021-02-07 13:52:28
pootler
Re: appimages?
ok - so far this is what I have :-)
keith@devuan:~/Downloads$ sudo chmod u+x * Criptext-latest.AppImage
[sudo] password for keith:
keith@devuan:~/Downloads$ ./Criptext-latest.AppImage
[11157:0207/134338.395343:FATAL:setuid_sandbox_host.cc(157)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /tmp/.mount_CripteZQiVuj/chrome-sandbox is owned by root and has mode 4755.
Trace/breakpoint trap
keith@devuan:~/Downloads$ ./Criptext-latest.AppImage --no-sandbox
(criptext:11189): Gtk-WARNING **: 13:44:12.306: Theme parsing error: gtk-widgets.css:154:27: The style property GtkButton:image-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.306: Theme parsing error: gtk-widgets.css:155:26: The style property GtkButton:inner-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.306: Theme parsing error: gtk-widgets.css:584:27: The style property GtkButton:image-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.306: Theme parsing error: gtk-widgets.css:585:28: The style property GtkWidget:interior-focus is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.306: Theme parsing error: gtk-widgets.css:586:28: The style property GtkButton:default-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.306: Theme parsing error: gtk-widgets.css:587:26: The style property GtkButton:inner-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.308: Theme parsing error: gtk-widgets.css:1344:25: The style property GtkRange:slider-width is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.308: Theme parsing error: gtk-widgets.css:1345:25: The style property GtkRange:stepper-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.308: Theme parsing error: gtk-widgets.css:1346:34: The style property GtkScrollbar:min-slider-length is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.308: Theme parsing error: gtk-widgets.css:1347:28: The style property GtkRange:stepper-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(criptext:11189): Gtk-WARNING **: 13:44:12.308: Theme parsing error: gtk-widgets.css:1348:34: The style property GtkRange:trough-under-steppers is deprecated and shouldn't be used anymore. It will be removed in a future version
couldn't lock 16384 bytes of memory (libgcrypt): Cannot allocate memory
** Message: 13:44:15.087: Remote error from secret service: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.secrets was not provided by any .service files
{"level":"error","message":"Unhandled Rejection: The name org.freedesktop.secrets was not provided by any .service files","stack":"Error: The name org.freedesktop.secrets was not provided by any .service files","timestamp":"2021-02-07T13:44:22.528Z"}
I have no idea what this means - any advice from experienced users?
THanks
Pootler
#6 2021-02-07 14:01:24
dice
Re: appimages?
If you want my advice, dont use appimages. Use services like tutanota or protonmail and learn how to use gpg to encrypt messages over the net. Ive used tutanota to send encrypted emails that they say are end to end encrypted only for the recipient who uses yahoo is able to fully read the email i sent that was supposedly encrypted.I would be surprised if this cryptext email is actually end to end encrypted.
edit: i guess im just reiterating that the endpoint of end to end encryption is a security risk. Most services offer encrypted tansfer of emails, but if doesn't land at the other end encrypted then it is not truly end to end encrypted imo.
“That which is below is like that which is above, and that which is above is like that which is below, to perform the miracles of one only thing.”
-Hermes Trismegistos
#7 2021-02-07 14:46:59
Re: appimages?
Did you follow that advice?
That dbus service file is provided by the gnome-keyring package
Black Lives Matter
#8 2021-02-07 19:47:12
pootler
Re: appimages?
HI,
Already used Protonmail for a year.
Would rather have my mail stored locally.
Pootler
#9 2021-02-07 20:00:51
pootler
Re: appimages?
So -- how do I alter the permissions for that temporary mount point? - isn't the program aborted , hence the tmp mount point is aborted as well??
Certainly can't find it in the file system---WARNING--- noob.
Cheers
Keith
#10 2021-02-08 11:39:41
Re: appimages?
Just install the gnome-keyring package and see if that fixes things.
Black Lives Matter
#11 2021-02-08 12:19:50
pootler
Re: appimages?
O.K.
that was wierd?
I tried to install gnome keyring using synaptic.
it said in order to install this it had to remove - a long list of stuff?
In fact this list was so long I didn't do it - it even included xfce4  stuff, and other appimages I have that work fine? - whats going on there!
I found the .deb package that I installed instead.
Didn't seem to make any difference.
So went to the link Dice gave about missing libraries.
Tried to install the packages that included the libraries.
I still can't run by double clicking, but if I run from terminal using <--no-sandbox>, it runs.
Now just need to find a way of running from the desktop without having to go into terminal all the time:-)
cheers
pootler
#12 2021-02-08 13:07:08
PedroReina
Re: appimages?
Easy-peasy: edit the .desktop file
#13 2021-02-08 13:10:40
dice
Re: appimages?
I didnt give you a link about missing libraries that was the other dice wink
I would seriously reconsider installing this JavaScript/Electron monstrosity.
#14 2021-02-08 13:25:34
Re: appimages?
Sounds like http://forums.debian.net/viewtopic.php?t=104157
Can we see
apt install --simulate gnome-keyring
Might be best to open another thread about this though.
Black Lives Matter
#15 2021-02-08 20:28:21
pootler
Re: appimages?
my bad :-(
Thing is, I would like to investigate this app - so now I have it working, I'll live with it  to see
Cheers
Pootler
#16 2021-02-08 20:38:34
pootler
Re: appimages?
Can we see
here is the output:
NOTE: This is only a simulation!
      apt needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
Building dependency tree
gnome-keyring is already the newest version (3.28.2-5).
- since I avoided anything catastrophic, I might just leave this - I sense the rabbit hole might be a bit deep for a noob  :-)
pootler
#17 2021-02-08 21:58:25
Re: appimages?
If you are suffering with the "metapackage problem" then you could find most of your desktop removed if you don't pay close attention to package management.
Is anything slated for autoremoval?
apt --simulate autoremove
If that command gives a list of packages then read the link I supplied in my last post and open a new thread if you can't figure out how to fix things. If the command doesn't list anything then just ignore this post.
Black Lives Matter
#18 2021-02-09 22:56:04
pootler
Re: appimages?
looks like I can breathe easy
Cheers
pootler
