Pages: 1
HI,
I am relatively new to linux, but am enjoying devuan.
Recently , I turned on my laptop to discover my top right wifi icon has disappeared?
I am still connected to wifi, but have no indication anymore of networks or connections via the wifi icon.
Anyone enlighten me :-)
THanks
pootler
You should try to frame your questions a bit better otherwise its all just guess work.
1. how did you install devuan?
2. what wifi manager you are using ? (example, wicd)
3. what desktop environment or window manager you are using ? (example, xfce4)
welcome to linux and devuan.
“That which is below is like that which is above, and that which is above is like that which is below, to perform the miracles of one only thing.”
-Hermes Trismegistos
This sounds like PEBKAC so please also post your sources:
apt-cache policy
Black Lives Matter
HI,
Thanks for the replies, and the welcome.
I come from a predominantly Windows/Mac background, but wanted to escape about a year ago.
The accessibilty of Linux OS has improved tremendously recently, So I tried a few others ( Mint, Manjarao) until I setled on Duvean.
I dont know enough to choose ''custom install'', so I would have chosen defaults - so I am guessing Xcfe?
Because of the large application store, there is little I am lost for, and although I am pretty rubbish at at terminal, I can get by if required :-)
TBH, I can't quite remember the exact details of install, but it was using an image from the duvean site, and via USB drive - sorry.
I update the build every week, and have had very little problems
Losing this wifi icon is strange- also If I open an app that usually shows in the top bar, it wont show up as usual - I use ''flameshot'' screenshot, but now when I choose it from the applications menu, it will not show in the top bar, so I cannot access the details.
The only items still showing in the top bar are, name, speaker, power, and time.
is there a terminal command/s that will provide the info you are looking for?
Thanks again
pootler
Hi pootler, sounds as though you have the default installation of devuan which i think is xfce4 and should have wicd as the network manager. I cant really help here as i dont use either, i prefer non gtk programs to run the wifi adapter like wpa_supplicant.
Hopefully someone will chime in here for you and get that icon back.
Before i go though, bring up a terminal and type the following and post the output.
wicd-client --tray
here it is
Has notifications support True
Loading...
Connecting to daemon...
Connected.
displaytray True
Done loading.
and the tray icon still does not show up?
maybe post the contents here of ~/.xsession-errors
HI,
No wifi icon in the top bar :-(
your command doesn't give anything?
''sudo: /home/keith/.xsession-errors: command not found''
Probably me.
Cheers
no need to use sudo.
try this if indeed you have that file in the home directory.
cat ~/.xsession-errors > x-errors.txt
Now you should have a file called x-errors.txt in the home directory, open the file with your editor (should be mousepad) and copy and past the contents in your post.
O.K.
I am starting to show my lack of linux knowledge.
output of your command gives me an 18mb text file.
It wont open in mousepad ( ''wrong conversion''? )
it wont open in featherpad ( permission error )
it will open in VIM, BUT this is nearly a thousand pages of text!, not the sort of thing a forum would appreciate!
pootler
rm ~/.xsession-errors
Then log out & back in again and
curl -F 'f:1=<-' ix.io < ~/.xsession-errors
Post the returned URL here.
And I really would appreciate the output of the command I requested in my last post.
Black Lives Matter
HI,
Apologies
ouput for ''cache policy'' command is:
Package files:
100 /var/lib/dpkg/status
release a=now
500 https://linux.teamviewer.com/deb stable/main i386 Packages
release o=TeamViewer GmbH,a=stable,l=TeamViewer,c=main,b=i386
origin linux.teamviewer.com
500 https://linux.teamviewer.com/deb stable/main amd64 Packages
release o=TeamViewer GmbH,a=stable,l=TeamViewer,c=main,b=amd64
500 https://updates.signal.org/desktop/apt xenial/main amd64 Packages
release o=. xenial,a=xenial,n=xenial,l=. xenial,c=main,b=amd64
origin updates.signal.org
500 http://download.opensuse.org/repositori … Debian_9.0 Packages
release o=obs://build.opensuse.org/home:smplayerdev/Debian_9.0,n=Debian_9.0,l=home:smplayerdev,c=
origin download.opensuse.org
500 https://brave-browser-apt-release.s3.brave.com stable/main amd64 Packages
release o=Brave Software,a=stable,n=stable,l=Brave Browser,c=main,b=amd64
origin brave-browser-apt-release.s3.brave.com
500 https://deb.etcher.io stable/etcher i386 Packages
release o=Bintray,a=stable,n=stable,l=Bintray,c=etcher,b=i386
origin deb.etcher.io
500 https://deb.etcher.io stable/etcher amd64 Packages
release o=Bintray,a=stable,n=stable,l=Bintray,c=etcher,b=amd64
100 http://deb.debian.org/debian buster-backports/non-free i386 Packages
release o=Debian Backports,a=buster-backports,n=buster-backports,l=Debian Backports,c=non-free,b=i386
origin deb.debian.org
100 http://deb.debian.org/debian buster-backports/non-free amd64 Packages
release o=Debian Backports,a=buster-backports,n=buster-backports,l=Debian Backports,c=non-free,b=amd64
100 http://deb.debian.org/debian buster-backports/contrib i386 Packages
release o=Debian Backports,a=buster-backports,n=buster-backports,l=Debian Backports,c=contrib,b=i386
100 http://deb.debian.org/debian buster-backports/contrib amd64 Packages
release o=Debian Backports,a=buster-backports,n=buster-backports,l=Debian Backports,c=contrib,b=amd64
100 http://deb.debian.org/debian buster-backports/main i386 Packages
release o=Debian Backports,a=buster-backports,n=buster-backports,l=Debian Backports,c=main,b=i386
100 http://deb.debian.org/debian buster-backports/main amd64 Packages
release o=Debian Backports,a=buster-backports,n=buster-backports,l=Debian Backports,c=main,b=amd64
500 http://deb.devuan.org/merged beowulf-security/non-free i386 Packages
release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=non-free,b=i386
origin deb.devuan.org
500 http://deb.devuan.org/merged beowulf-security/non-free amd64 Packages
release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=non-free,b=amd64
500 http://deb.devuan.org/merged beowulf-security/main i386 Packages
release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=main,b=i386
500 http://deb.devuan.org/merged beowulf-security/main amd64 Packages
release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=main,b=amd64
500 http://deb.devuan.org/merged beowulf-updates/non-free i386 Packages
release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=non-free,b=i386
500 http://deb.devuan.org/merged beowulf-updates/non-free amd64 Packages
release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=non-free,b=amd64
500 http://deb.devuan.org/merged beowulf-updates/main i386 Packages
release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=main,b=i386
500 http://deb.devuan.org/merged beowulf-updates/main amd64 Packages
release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=main,b=amd64
500 http://deb.devuan.org/merged beowulf/non-free i386 Packages
release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=non-free,b=i386
500 http://deb.devuan.org/merged beowulf/non-free amd64 Packages
release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=non-free,b=amd64
500 http://deb.devuan.org/merged beowulf/contrib i386 Packages
release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=contrib,b=i386
500 http://deb.devuan.org/merged beowulf/contrib amd64 Packages
release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=contrib,b=amd64
500 http://deb.devuan.org/merged beowulf/main i386 Packages
release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=main,b=i386
500 http://deb.devuan.org/merged beowulf/main amd64 Packages
release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=main,b=amd64
URL for additional command is
Many Thanks
pootler
Yeah not sure what to make of that .xsession-errors file, lot going on there. Wicd doesnt stand out in it though.
maybe have a look in session and startup and add to application autostart if its not there, log out and log back in again.
also do you have other systemtray icons showing, like volume etc..?
See here for help: https://docs.xfce.org/xfce/xfce4-session/preferences
FYI, see here to learn more about the xfce4 desktop: https://docs.xfce.org/
Thanks Dice
Appreciate your patience and help.
Will investigate further myself.
Having done a lot of troubleshooting for other windows and mac systems, I do understand the difiiculty in communication with 'noobs'
Keep safe.
pootler
p.s as mentioned, I still have name, Speaker volume, Power, and time in tray.
You have several foreign (non-Devuan) repositories active in your system so I would be blaming whichever software you installed from those. That Signal source looks particularly egregious because Xenial (Ubuntu) is not compatible with Devuan.
Try removing any and all non-Devuan software and see if that fixes things.
Note that Devuan has a beowulf-backports repository so you should use that rather than buster-backports (although the packages should be the same apart from the systemd backport).
Black Lives Matter
as head on a stick mentions getting rid of some of the foreign software might help.
a few suggestions in place of smplayer and etcher you could use the smplayer that is already in the stable repos and use gnome-multi-writer in place of etcher.
sudo apt install gnome-multi-writer
sudo apt install smplayer
not sure what you could use in place of teamviewer or signal, they seem to be personal choice or maybe needed for work.
Thanks all
yup - will try and remove non devuan stuff.
Will report back in a few days - laptop occupied for the next three days running particularly long data recovery for an external HDD:-)
Pootler
THanks everyone for al your suggestions!
Sometimes its easier to start from scratch- so I decided to do a fresh install.
I will probably be posting new problems soon :-)
pootler
pootler
Took the words right outa my mouth. I was watching and thinking oh No, He has a frankenstien rewire job with advanced linux commands being thrown at him. Then you got wise, yet still good to know the meaning of commands above.
Not really that much of a frankenstein, just needed to delete those foreign repositories. Replace the buster backports entries with devuans backports and update, upgrade should have fixed it.
Pootler if you want devuan backports just add them like this from the terminal.
echo "deb http://deb.devuan.org/merged beowulf-backports main" | sudo tee -a /etc/apt/sources.list.d/devuan-backports.list
then
sudo apt update && sudo apt dist-upgrade
I don't think that would have removed any foreign packages that were already installed.
Black Lives Matter
I just now looked at the repositories he had listed, and yeah no wonder(opensuse, brave, debian, etc) with all that and any xfce session/session manager updates going on.. lest frankenstein more like a twitchy, dissappearing boxes, desktop panel reloading on every boot. sources.list and understanding what revolves around it is important, I always keep as basic and simple as possible. I use xcfe properly on all my normal end use desktops.
dice wrote:just needed to delete those foreign repositories. Replace the buster backports entries with devuans backports and update, upgrade should have fixed it
ah yes i left out the part about uninstalling the foreign packages first.
Pages: 1
