#1 2020-12-16 18:32:18
nobodyuknow
PulseAudio always resets to mute
The release notes state that it is necessary to comment "autospawn=no" in /etc/pulse/client.conf.d/00-disable-autospawn.conf. Okay, that allows for sound. But there's still a minor bug. I think it happens with every boot, but it might be something a little more subtle, perhaps it happens on the first boot of a day. The volume slider is set all the way to the left, so there is no sound. It's simple to fix, just move the slider to the right, but why doesn't it retain the previous setting?
P.S. In case it matters, this is Cinnamon.
#2 2020-12-16 19:14:41
MiyoLinux
Re: PulseAudio always resets to mute
I don't know if this will work, but there are a couple of things you can try...
1. Open a terminal, and enter alsamixer. If it opens in the terminal, use your arrow keys to move to the right until Automute is highlighted. Then press the down arrow to disable it.
You may have to choose your sound card first by pressing F6...
If alsamixer isn't working on your system, then you can try...
2. When you first boot your computer up...BEFORE adjusting the volume on the panel, open Pavucontrol. Go to Output Devices. If the volume icon is highlighted (muted), press it to unmute it. THEN move the slider beneath it.
Both of those options have always worked for me, but I'm unfamiliar with Cinnamon.
Good luck
#3 2020-12-17 18:01:11
Is the alsa-utils package installed? If so then make sure that the /etc/init.d/alsa-utils init script is enabled — that should save the audio level on shutdown and restore it when the machine is booted again.
#4 2020-12-17 21:28:17
Pix3l
Since I switched to devuan 3, I also experienced this issue, at every startup I need to manually start pulseaudio everytime to make firefox audible.
pulseaudio --start -v
Sick of this, I recompiled the latest version of pulseaudio from source (without systemd support by configure options), and the mute problem (on firefox) solved itself.
This issue was not present in the package for devuan 2, I think the new one is somekind of broken...
#5 2020-12-18 20:37:50
nobodyuknow
@MiyoLinux @Head_on_a_Stick @Pix3l Thanks for the replies.
The problem is global (if that's the right word), as the taskbar volume control is set to zero.
alsa-utils is installed. And I'm not sure what you mean by /etc/init.d/alsa-utils init script being enabled. It's got executable permissions and the contents are not commented out.
Pix3l is correct, the problem was not present before.
#6 2020-12-18 21:46:48
MiyoLinux
Well, the directions that I gave always does away with the global automate on startup for me. Good luck.
#7 2020-12-18 22:41:22
Pix3l
I inspected the devuan 2 and 3 pulseaudio packages, to see how the differs, but apart from some additions in configuration files, I don't see any change in default options.
Also the /etc/xdg/autostart/pulseaudio.desktop, that I think should start automatically the daemon, is there without any differences.
I think the main problem can be the daemon binary itself, and for test I recompiled it from source (14.0), there are also options to avoid systemd entirely, along others things:
--disable-systemd-daemon  --disable-systemd-login  --disable-systemd-journal
The original devaun packages includes some systemd services file under /usr/lib/systemd anyway.
After that, everything work without any problem, pulseaudio starts automatically at every boot.
#8 2020-12-18 23:21:35
@Pix3l: please read the beowulf release notes, the answer you seek is there. Your posts in this thread are off topic.
@Miyo: the automute setting in alsamixer refers to headphones and is not related to the issue described in the OP.
@OP: use sysv-rc-conf to check which services are enabled.
#9 2020-12-18 23:59:51
MiyoLinux
I guess that's why it works for me. I only use speakers that plug into my headphone jack. Hahaha!
Carry on. I'll be quiet now. big_smile
#10 2020-12-19 00:21:46
Pix3l
I think it's inherent, since I try to help it to fix the problem and provide my experiences.
From devuan 2 to 3, this packages seems to went somekind of broken (like many others as I experienced).
The file /etc/pulse/client.conf.d/00-disable-autospawn.conf is not part of the deb package, it's generated by pulseaudio, and even by uncommenting or set to true autospawn, I experienced the same problems.
So, the solution for me was to switch to a next release, and solved...
That's all.
#11 2020-12-19 01:16:48
The file /etc/pulse/client.conf.d/00-disable-autospawn.conf is inherit to the package. Uncompress the debian folder and you'll find it there.
#12 2020-12-19 11:06:42
Please read the first two sentences of the first post in this thread. The OP has already fixed the problem you are experiencing and so does not need your help.
That file is supplied by the libpulse0 package:
dpkg -L libpulse0 | grep autospawn
Or:
$ dpkg -S /etc/pulse/client.conf.d/00-disable-autospawn.conf
libpulse0:amd64: /etc/pulse/client.conf.d/00-disable-autospawn.conf
#13 2021-02-14 12:59:08
MLEvD
Hello my vems, my tvvo cents
Devuan ascii - audio fine
Devuan Beowulf - DATA LOSS
User settings are data, and data loss of any kind is unacceptable
#14 2021-02-14 13:31:18
Another solution (new in devuan 3.1.0 point-release.)
Install debian-pulseaudio-config-override
Description: Debian configuration overrides for pulseaudio
You'll get this automatically if you install a desktop environment from the 3.1.0 installer isos.
(task-desktop Recommends debian-pulseaudio-config-override)
#15 2021-02-16 05:58:41
MLEvD
That did not work.
To reproduce:
Devuan 3.0 or 3.1 mate D.E.
Mate Media installed. Right click sound icon and choose 'Sound Preferences'
Change a setting for input or output device. I like to change input from 'duplex' to 'output only'
On reboot these user sound preference settings are lost.
This is unacceptable.
problem occurs under both sysv and runit
#16 2021-02-16 07:32:07
Danielsan
Unacceptable is your behavior. Did you pay anything for using Devuan that made you believe that having a bug is unacceptable?
Anyway these kind of issues are usually in the .xsession-errors file in your homes, maybe you can find there what is preventing to save your preferences.
#17 2021-02-16 09:48:35
Here's a gratuitous web search result https://www.mycomputertips.co.uk/213
Iit's for Ubuntu but probably works here as well.
The suggestion is to
  • determine the label (XXX)  for the "active profile" by looking for that entry in the pulsaudio configuration file
  • then edit /etc/pulse/default.pa, to add a line like set-card-profile 1 XXX to it
  • and then restart pulsaudio
Probably not ideal for a pointy-clicky minded user.
#18 2021-02-16 12:38:02
MLEvD
Free, in this sense, does not mean it does not cost anyone anything.
We all pay and reporting bugs is acceptable. Rudeness is not, for which I apologise, if that's how it was taken?
Boris Beizer would turn in his grave, notwithstanding his cat.
Tell me, which of your user settings are you happy to have lost, if sound preferences are not important to you?
Heaven forbid your evening goes wrong because your audio comes out of the tv speakers via the hdmi rather than out of the decent stereo via the headphone jack or other networked device.
Just tried it again then looked in .xsessionerrors and sadly there's nothing there to help me. Thank you and if you have any other suggestions I'm all ears?
In the meantime, can anyone here reproduce this bug? I'm all 32-bit here, can someone try on 64 please?
#19 2021-02-16 16:51:21
I can confirm that setting to output only is not saved across reboots. Tested amd64 mate in a qemu virtual machine. This happens to be an install with speech synthesis enabled (screen reader) but that probably doesn't matter.
I can also confirm that /etc/pulse/default.pa does not look anything like the one in the mycomputertips help page.
I don't see any bugs about settings not saved, but there are a couple about crashing mate-volume-control (the Sound Preferences app)
https://bugs.debian.org/cgi-bin/pkgrepo … mate-media
I also poked around in ~/.config/pulse and found 141 binary files. No help there.
#20 2021-02-16 18:11:54
MLEvD
Thanks for that, good to know it's in 64 too, so the other 90% might care!
If it helps, I just removed mate-media and installed pavucontrol. The settings are lost here as well - change from duplex to output only, setting lost on reboot. Perversely happy that pavucontrol isn't the answer, as I don't particularly like it.
I tried mate-volume-control -d but couldn't really make head or tail of it on an 800x600 display.
It's not happening on ascii, or on debian, or anything else that I've got my hands on recently.
Happy to test all night. I built a small wooden stand, pop a frozen meal under it, the eee pc says cool and my supper slowly defrosts.
#21 2021-02-16 22:07:26
That page shows two files where the first is "the pusleaudio configuration file" .. whatever that is, and towards the bottom the excerpt for /etc/pulse/default.pa.
This issue is down at pulseaudio level and not desktop environment level. Clearly the GUI that lets you alter the configuration should have included something to register the new configuration as persistent over reboot. For pulseaudio that "persistence" is apparently implemented via the "default.pa" file.... or files perhaps, if you can have per-user defaults.
#22 2021-02-17 00:04:02
Ah, I didn't see that. Yeah the actual file is farther down the page. That first screenshot is the output of pacmd list-cards
When I run that command, I get "No PulseAudio daemon running, or not running as a session daemon."  So I can't find what the active profile is to put the line in default.pa
ps ax shows that it's running and that the --start option was used, which should make it run as a daemon. That's what the man page says.
There are a bunch of error messages about pulseaudio in the syslog, but they may be related to settings for the screen reader. They're complaining about a run file for user lightdm. I think I should stop here. It may not be a good comparison.
MLEvD, I hope you have better luck. Are you sure you need pulseaudio? Maybe plain alsa would behave better.
#23 2021-02-17 00:25:45
For those who have laptops with HDMI outputs see this guide for setting the non-HDMI output as the default:
https://wiki.archlinux.org/index.php/Ad … sound_card
I'm using "~/.asoundrc" to personalise my sound config for the user.
#24 2021-02-17 05:19:39
MLEvD
I'm doing sychronised multi-room audio with asus eee pc as receiver boxes. Why not rpi? Because eee pc have screens and input attached, and are dust proof, have cases, are portable (own battery!). In addition to music. They also provide wifi, a digital picture frame/show, and anything else you might do with an 800x600 screen.
I read back at the start that one must use pulse or sndio for this avahi magic, alsa is a one horse town. Hopefully I am wrong?
Hack: I *could* just hack the scripts to enforce defaults and policies, but this is something clearly broken compared to the last version of devuan or the contemporary version of debian, so it's possibly an indication of some wider improvement opportunity in the development sphere. It's a very long time since I was a pro tester so forgive my antiquated language please!
#25 2021-02-24 12:32:08
Lord Curzon
I've just installed Devuan Beowulf 3.1 with the Mate desktop and experienced the same issue – the settings are not being saved.  Here's my workaround.
Like me, you might have more than one sink.  Usually, there is only one.  To check, run:
pacmd list-sinks | less
Note the index of the sink that you want to be the default.  Do the same for sources:
pacmd list-sources | less
Make a backup of /etc/pulse/default.pa.  Open the file as root with a text editor, for example:
sudo vi /etc/pulse/default.pa
At the end of the file, there is a two-line option to make some devices default:
### Make some devices default
#set-default-sink output
#set-default-source input
Uncomment the two lines (by deleting the hashes) and set the output to the correct index for the sink and the source.  In my case, it was:
set-default-sink 0
set-default-source 0
If you found the output of pacmd hard to interpret, note that there are only two possibilities if you have two sinks (0 and 1), so you can experiment.  I had three sources, so three possibilites: 0, 1, 2.
Devuan's /etc/pulse/default.pa has an option that restores the default sink/source if changed by the user, which might be part of the problem.  I commented it out:
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
#load-module module-default-device-restore
There's a similar option that restores the volume, which you might want to look at.
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
Hope this helps someone else!
