#1 2020-08-20 10:37:16
matze72
Network and other problems after upgrading from ascii to beowulf
After ugrading from ascii to beowulf I came across some problems, for some I could find solutions or workarounds on my own, for some not.
But let's start with the main problem:
1) After the upgrade I did not have internet access any more. It turned out that no dhc clinet is runing. After I added the following lines to /etc/interfaces
auto eth0
iface eth0 inet dhcp
dhclient is running after booting, but I still have to restart connman with the following command to get access to the internet:
service connman restart
How can I fix this?
2) During booting the boot process stops for some minutes at Starting MTA. Is there a possibility to avoid this?
3) There must be change in the firejail profile file firefox-common.profile that caused problems with my firefox installation. is there a way to download the ascii version of that file to make a comparison?
4) The directory /usr/sbin was not part of the PATH variable any more, at the moment I use the following command as root after boot:
export PATH=/usr/sbin:/sbin:/usr/local/sbin/:$PATH
How can I define this permanently?
Do I have to include this in .bashrc in the root home directory or is there a system wide configuration file?
5) After the upgrade I do not have the possibility any more to send the computer into "sleep mode" with obsession-logout, does anybody know a reason for that?
Can this be caused by the upgrade hint to downgrade upower because of a bug (and I followed that hint)
#2 2020-08-20 11:28:12
Vernon
Re: Network and other problems after upgrading from ascii to beowulf
auto eth0
How can I fix this?
My /etc/network/interfaces file for connman looks like this
 This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug eth0
Note that  BOTH the contents and the path to your interfaces file are different.
No, you need to include a dash after su whenever you want the sbin directories in you PATH.
su -
#3 2020-08-20 11:39:42
larsH
Hi
Hi no. 1 Is connman added to your startup. If not use "update-rc.d connman enable" to add it.
No 4. The behavior of logging in as root has changed. So you have to use "su -" to login with full path. This to prevent the root user to damage the system on purpose. I find this myself a bit stupid. But so be it
Thats what I can help with for now
Have a nice day
Lars H
#4 2020-08-20 13:18:44
matze72
@Vernon:
Sorry the path was a typo, indeed my interface-file is at /etc/network/interfaces.
Do you think the "allow-hotplug" is making the difference, or have you additional files in your interfaces.d-directory?
Mine is empty.
I will try the allow-hotplug.
Thanks,
matze
#5 2020-08-20 13:31:03
matze72
@Lars
I used sysv-rc-conf to define the following:
service        1      2     3     4     5      0     6       S
connman       [ ]    [x]   [x]   [x]    [x]   [ ]    [ ]    [ ]
I believe that this should do the same as update-rc.d connman enable, isn't it?
#6 2020-08-20 13:45:20
Vernon
matze72 wrote:
@Vernon:
Mine is empty.
Mine is empty as well.
I don't know if this will make a difference. I can only say that this is what was in my  /etc/network/interfaces file when I used connman. Note that when I used connman, the boot process would hang until DHCP timeout if I did not have an Ethernet cable plugged in.
Good Luck!
#7 2020-08-20 13:55:47
larsH
Hi
It should. But if you did make a mistake it does not work. FYI My install does not have sysv-rc-conf installed by default. So I am using the old ways to set or delete symlinks (service blabla enable/disable). Is sysv-rc-conf broken in some way in beowulf ??
Have a nice day
Lars H
#8 2020-08-20 14:18:53
matze72
@Vernon
No, allow-hotplug did not make the trick. Nothing changed.
Ethernet cable is also plugged in all the time.
@Lars
I have not the impression that sysv-rc-conf is broken.
And I did this when I still used ascii and did not change it.
I also have the impression that first connman is started and then the networking service, is there an easy way to check this?
I guess it is somewhere in the init scripts at /etc/rc.... , can I just adapt the names to force a different order?
For example change K01connman  to K09connman to make sure that the connam service is started after K07networking is starting the networking service, or can I break something doing so?
#9 2020-08-20 14:42:25
larsH
Hi
Now I am not the most experienced expert in this, as I only using one machine and not trying to fix things that are not broken ;-)). Just tried it once with devuan and a couple of times in gentoo. What I would do was checking services running with "service networking status"  and "service connman status". Then disable them, reboot, and enable them again with network first and connman after that. And I would use "the service blabla enable" command for that. As far I know it is the recommended way to do it (except for manually making the links)
Hope this is to some help ;-))
Have a nice day
Lars H
#10 2020-08-20 14:43:06
Vernon
Do an ls -l1 /etc/rc* | less -S and see if there is a link to a connman startup script. Note that startup script links begin with the letter S whereas shutdown script links begin with the letter K
Yes, but links beginning with the letter K are shutdown scripts.
#11 2020-08-20 16:55:42
Remove connman and use ifupdown instead, that's the program that uses /etc/network/interfaces. Make sure the networking service is enabled though.
Black Lives Matter
#12 2020-08-20 18:06:22
larsH
Hi
Agree with Head_on_a_Stick. ifupdown is what i use myself. But does other know if connman is buggy ??
Have a nice day
Lars H
