#1 2020-06-08 21:06:05
Roger
Aptitude problem
Is there a current problem with http://devuan.org/merged ?
I haven't found any notification anywhere, but there are error messages about files not being downloaded.
#2 2020-06-08 21:30:54
Re: Aptitude problem
That's the wrong URL: http://deb.devuan.org/merged/
And for future reference:
Please always post the full, verbatim error messages rather than a vague description — it's easier for you and less confusing for us.
Black Lives Matter
#3 2020-06-08 21:59:24
Roger
Here is what I get trying to use apt-get update
E: Repository 'http://deb.devuan.org/merged beowulf InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
E: Repository 'http://deb.devuan.org/merged beowulf-updates InRelease' changed its 'Suite' value from 'testing-updates' to 'stable-updates'
E: Repository 'http://deb.devuan.org/merged beowulf-security InRelease' changed its 'Suite' value from 'testing-security' to 'stable-security'
My /etc/apt/sources list refers to "beowulf" not "stable" or "testing" and has worked since the time of the beta release.
#4 2020-06-08 22:03:58
Run
# apt update
# apt upgrade
Then answer "yes" when it asks.
See also http://dev1galaxy.org/viewtopic.php?id=3564
Black Lives Matter
#5 2020-06-08 22:08:41
Roger
Ca va bien. Thanks.
#6 2020-06-08 22:54:02
Roger
As a final comment, which might be useful to others, I do routine updates (usually weekly) using aptitude, which only told me that some files had not been downloaded, without explanation or query. If I had run apt, I would have received more explanation, and the prompts about what to do. As I have been using beowulf for some time, I did not anticipate any difficulties when its status changed officially to "stable".
