#1 2020-06-04 16:34:43
Job
update/upgrade error
Here is sourses.list picked up from the release page
deb http://deb.devuan.org/merged beowulf main
	deb http://deb.devuan.org/merged beowulf-security main
	deb http://deb.devuan.org/merged beowulf-updates main
	deb http://deb.devuan.org/devuan beowulf-proposed main
but I am getting these
root@duala:~# aptitude update
Get: 1 http://deb.devuan.org/merged beowulf InRelease [25.6 kB]
Get: 2 http://deb.devuan.org/merged beowulf-security InRelease [25.6 kB]
Get: 3 http://deb.devuan.org/merged beowulf-updates InRelease [25.6 kB]
Hit https://downloads.iridiumbrowser.de/deb stable InRelease
Get: 4 http://deb.devuan.org/devuan beowulf-proposed InRelease [54.6 kB]
Get: 5 http://deb.devuan.org/merged beowulf-updates/main amd64 Packages [7,396 B]
Fetched 113 kB in 1s (78.1 kB/s)
E: Repository 'http://deb.devuan.org/merged beowulf InRelease' changed its 'Suite' value from 'testing' to 'stable'
E: Repository 'http://deb.devuan.org/merged beowulf-security InRelease' changed its 'Suite' value from 'testing-security' to 'stable-security'
E: Failed to download some files
W: Failed to fetch http://deb.devuan.org/merged/dists/beowulf/InRelease:
W: Failed to fetch http://deb.devuan.org/merged/dists/beowulf-security/InRelease:
E: Some index files failed to download. They have been ignored, or old ones used instead.
I always have issues with Devuan repos.  Hope someone can help me.
#2 2020-06-04 17:07:28
Re: update/upgrade error
Run
# apt update
# apt upgrade
And answer "yes" when it asks.
You should probably remove the proposed-updates repository though, unless you want to test the new bugs.
Black Lives Matter
#3 2020-06-04 18:59:41
Job
While we are here, are there non-free repos and such or these repos covered everything?
#4 2020-06-04 19:29:05
There are non-free and contrib[0] components in the repositories, if you need them just add them to your sources:
deb http://deb.devuan.org/merged beowulf main contrib non-free
deb http://deb.devuan.org/merged beowulf-security main contrib non-free
deb http://deb.devuan.org/merged beowulf-updates main contrib non-free
[0] Containing packages which are open source but which pull in non-free software when installed.
Black Lives Matter
#5 2020-06-04 19:50:18
Job
Merci HOAS...Je vois que tu lis la litterarure Francaise.
#6 2020-06-04 20:12:49
Alas my French is just awful but I do prefer the quote in it's original language.
Black Lives Matter
#7 2020-06-04 20:34:10
PRafael
@Job
Please, follow this solution in
http://kraaima.com/inrelease-changed-it … ble-error/
it worked for me
Regards
Paulo
#8 2020-06-05 15:50:31
Job
PRafael, the solution is actually https://devuan.org/os/packages.  At least it was easier and straight forward IMO.
