#1 2019-11-29 03:33:36
ezmax
How to setup PHP=>7.1 on Devuan 2.1?
default installation is PHP v7.0.33-0+deb9u6
can i use deb.sury.org repository?
#2 2020-01-02 20:16:26
IdeaFix
Re: How to setup PHP=>7.1 on Devuan 2.1?
You can use sury, but you should edit apt sources file.
Hereis an official description - https://packages.sury.org/php/README.txt
but you may be should make not this code:
#!/bin/bash
# To add this repository please do:
if [ "$(whoami)" != "root" ]; then
    SUDO=sudo
fi
${SUDO} apt-get -y install apt-transport-https lsb-release ca-certificates curl
${SUDO} wget -O /etc/apt/trusted.gpg.d/php.gpg https://packages.sury.org/php/apt.gpg
${SUDO} sh -c 'echo "deb https://packages.sury.org/php/ $(lsb_release -sc) main" > /etc/apt/sources.list.d/php.list'
${SUDO} apt-get update
but this:
#!/bin/bash
    SUDO=sudo
fi
${SUDO} sh -c 'echo "deb https://packages.sury.org/php/ stretch main" > /etc/apt/sources.list.d/php.list'
There is no ascii in deb.sury.org repository.
#3 2020-04-22 07:40:28
IdeaFix
HELP! SOS!
I can not upgrade PHP from sury! It depends now from systemd-tmpfiles  sad
#4 2020-04-22 08:17:39
xinomilo
Unknown
#5 2020-04-22 16:21:02
IdeaFix
Unfortunately (for me) i need 386 builds, and there is only amd64.
#6 2020-05-05 06:38:02
Just fudge it with equivs. Either use the dummy package as-is or build your own that symlinks opentmpfiles.
PHP-FPM from packages.sury.org doesn't really need systemd, some nit just decided to use systemd-tmpfiles because it's there... And be a dick about it when someone tries it where systemd is not installable.
It's probably time to retire the use of that repo if this kind of idiocy is going to continue (and I expect it will), but for now a dirty little one-line shell hack keeps the wheels turning.
Probably a bit late for you I know, but I'll leave it here for reference anyway.
