#1 2019-10-06 14:09:02
reverber
Odroid HC1 / HC2: Headless Install
First of all, thanks to everyone who got Devuan rolling and keeps it going.
I am trying to get Devuan installed on an Odroid HC2 using the devuan_ascii_2.0.0_armhf_odroidxu4 image. It *seems* to work - mostly. I see that it pulls a DHCP address from the server, and I can ping it successfully.
However, I am unable to ssh to it. Ssh just times out at first, and then after about five minutes, I start getting "no route to host." Ping also dies at this point.
Nmap (while the network interface is up) shows that ssh is filtered.
Complicating things is that this is a headless box, so I cannot see what is going on. Anybody have any suggestions on troubleshooting while I impatiently wait for my UART kit to arrive?
Thanks for your help.
#2 2019-10-06 15:46:55
alphalpha
Re: Odroid HC1 / HC2: Headless Install
maybe you can mount the micro sd on your main computer and modify the /etc/network/interfaces to a static ip and check the ssh server config
#3 2019-10-07 12:19:50
reverber
Thank you.
Everything looks fine as far as I can tell. I used to have Open Media Vault on it, so I know it isn't a hardware failure. OMV seemed like a bit of overkill for a backup solution, so I am going to go lean and use rsnapshot.
I was hoping maybe somebody else had paved the way for me smile.
