#1 2019-08-20 05:42:17
masterpeace
[SOLVED] [newbie] need help with minimal installation problem
hello
a linux newbie here . this is my 5th to 6th month using linux (MX 18.3) . i want to learn more about linux and so i decided to take a journey from MX in my vacation time . my first circle of linux is quite a minority that avoids systemd . it's not that i hate systemd since i don't even encounter that in my first distro ever (MX) . so they advised me to try minimal devuan install .
so i downloaded netinstall.iso first as they advised . the manual told me to burn the iso manually or use dd . since my work laptop (HP 242 G1) don't have dvd drive , so i used dd . but it won't boot . so i googled and tried unetbootin , it boots , but then i encountered firmware problem , it won't load the firmware it keeps asking me for the missing non-free wi-fi firmware even if i placed the firmware on the installation drive (.deb version and the unpacked version from github) . so i then tried to use minimal install version .
while the minimal install works even while encountering that firmware problem , i then encountered second problem . i can't turn my wi-fi on , so i am stuck with the base install . i don't have access to ethernet since i am on my paid vacation , and i am using free hotel wi-fi . what should i do ?
#2 2019-08-20 11:12:26
Re: [SOLVED] [newbie] need help with minimal installation problem
First thing I would do is look behind the furniture for an ethernet outlet.
If you tried the minimal-live iso, it has firmware already installed. Run setnet.sh to configure wireless.
I don't know anything about your model of laptop, but you might want to take a look at this to see if you have any of the same problems: https://dev1galaxy.org/viewtopic.php?id=15
#3 2019-08-21 06:49:20
masterpeace
thanks , dd netinstall.iso finally boot
my bad , i was actually using netinstall version of ascii not the minimal install
it's not that it won't boot , but i automated grub to force start mx linux  (grub.conf : grub_delay:0) or i didn't use conv=sync when dd , the culprit is one of the two .
and setnet.sh won't run , bash unknown command
#4 2019-08-21 13:18:28
setnet.sh is in the live isos, not the installer isos.
I never use conv=sync when I dd a usb stick, so I don't think that was the problem. Sounds like the classic problem of "Computers don't do what you want; they do what you tell them to do."
Glad you got it working.
#5 2019-08-21 13:59:36
masterpeace
it turns out both are the culprit . i red freeBSD handbook which practically giving the potential problem and why ...
my flash drive are 18 yo usb2 4gb , while my hard drive is Crucial M4 SSD , output per flops write are having stark contrast , that's why conv=sync need to be turned on for safety reason .
and uefi grub are practically gives you booting options
dear admins and mods , please mark this as solved and thanks
