#1 2018-08-11 04:46:33
charli
Desktop without icons
Hello everyone, I installed devuan 2.0 and when I start the computer in most of times you do not appear the icons on the desktop.
As it did not appear, load mate 1.20, but the problem persists.
What I can do.
#2 2018-08-11 23:08:39
ChuangTzu
Re: Desktop without icons
For Xfce: go to Settings/Desktop Settings/Icons/Appearance/Icon type/change from none to your preference
For Mate: I think its in dconf/mate/background/toggle show-desktop-icons
#3 2018-08-26 10:24:57
charli
Hello, after a while looking, changing hard drive, CD drive and etc, he found the error.
It's the software, for some reason it does not work with my gygabyte z97-hd3 board.
I have another computer with a gygabite z87 and it enters without any problem.
As a result I had to reinstall devues jessie, until they return ascci and modify it and can install it.
I want to thank you ChuangTzu for your hel .ChuangTzu
