Pages: 1
This was today in the "news"
sudo (1.9.17p2-7) unstable; urgency=medium
Starting with sudo 1.9.17p2-6, the default /etc/sudoers was aligned with
the example file that upstream ships. This was done to reduce the
differences between Debian and other distributions.This has removed /usr/local/sbin and /usr/local/bin from the
"Defaults secure_path" setting. This may break some local scripts, but
also increases security, since on some systems, /usr/local might be
writable for non-root users and thus executing programs from there might
introduce privilege escalation.If you want to use executables from /usr/local with sudo without giving
the explicit path, consider changing the setting in an /etc/sudoers.d
snippet.-- Marc Haber <mh+debian-packages@zugschlus.de> Sat, 04 Jul 2026 12:57:42 +0200
have not fully understood the implicatoins of change, but suppose it is a benevolent, sensible change.
sudo is one of the first packages that I uninstall on laptops/desktops after a fresh installation.
It is not even meant for the purpose it's being used by most Linux distros, sudo is meant to give limited access to specific commands as root or other restricted user to specific users on a multi-user system, not as a "run everything you want as root" tool on a single user desktop/laptop system.
We have to thank Ubuntu for introducing this misuse of sudo on Linux.
“Either the users control the program – or the program controls the users” Richard Stallman
... as a "run everything you want as root" tool on a single user desktop ...
Not the way I use it, mostly thanks to my learning about it when on PCLinuxOS.
One of the main admins was quite adamant about it.
See: https://pclosmag.com/html/Issues/201205/page11.html
But yes, I agree that a great many people use it in the wrong way.
Mainly thanks to the Ubuntu distribution.
I am, of course, also interested in the implications of the announced change.
What is says is that if you want to use sudo to run a command in /usr/local/(s)bin, you must now give the full path to the command.
What I see is that I do not have to give the full path to run the command with sudo, but maybe that's because I have the full path to the command already in my /etc/sudoers.d/usercommands. So for me, there's no change. Tested this in freia with the version of sudo mentioned above.
Wait, some of you are still using sudo?
Yeah, I have sudo NOPASSWD set for a few commands for one user. That's all.
What is the "proper" way to run admin tasks? For example, what "should" I be using to edit system-wide conf files?
It's linux. There are 10 ways to do anything. Pick one.
If you have a root account, you can su to root to do admin tasks. If you don't have a root account, you need to use sudo to do admin tasks, and in that case, you're probably a member of the sudo group and can do anything with it.
The original intent of sudo was to allow fine-grained permissions for certain users or groups to do a few specific admin tasks rather than give them total root access.
What you should not do is log into a desktop session as root.
... to run a command in /usr/local/(s)bin, you must now give the full path ...
Right, thanks for that.
... have the full path to the command already in my /etc/sudoers.d/ ...
... sudo NOPASSWD set for a few commands.
That is how I have it set up.
I don't know about a proper way, but on a single-user system i've always just used su. I have right-click extensions to edit a file as root, or to open a directory as root if I need to move some files around.
As far as the changes to sudo, what systems would make /usr/local/ writeable for a non-root user? That seems silly.
@Altoid that link was a blast from the past, I remember when Old Polack wrote it, PCLOS was really popular at the time and there had been a steady influx of new users posting "where's muh sudo?". OP was a brilliant guy, don't know if he's still around but I learned a lot from him.
... a blast from the past ...
... when Old Polack wrote it, PCLOS was really popular at the time ...
Quite so ...
... a brilliant guy, don't know if he's still around ...
Yes, I agree.
It seems that there was a fire/accident that took down the servers and a new forum had to be set up.
Apparently some stuff was lost and I cannot log-in or recover my PW.
Will try again when I have time.
Don't understand ...
No reliable off-site back-ups? 8^°
In any case, Texstar [packager/main dev] posted this earlier this year.
Seems he does not have contact information for one of his forum's senior admins. (?)
Go figure ...
my /usr/local/{bin,sbin} are owned by group staff, and group has write permission.
sorry fo the crosspost, but just got this in "news" , again, and not really known what should make of it.
maybe it is of no relevance, after all.
adduser (3.155) unstable; urgency=medium
The GROUPHOMES, LETTERHOMES, SGID_HOME and QUOTAUSER options were
deprecated for a while and got removed in this release.-- Marc Haber <mh+debian-packages@zugschlus.de> Mon, 19 Jan 2026 09:23:49 +0100
thanks.
coming back to the original quesit:
when i use ssh , feel more comfortable to login via user, and proceed from there with "sudo" when needed; rather than as root; is this warranted behaviour or is it better to login as root user?
whenever i use root, have feeling things could break more easily, maybe from experience.
thanks.thanks.
This is, it seems, a matter of some opinion and debate. I'm of the opinion that it's your system and you should use it in the way that works for you, cognizant of the risks you take by doing so. Too many people who speak of open source and "freedom" have far too rigid opinions of how things ought to be done.
I hope that's not a suggestion that all root tasks should be done through the command line only. I want my GUI file browser and text editor with a mouse cursor, right-click, clipboard, and tabs. I'd have given up on Linux long ago if I had to do all the debugging and customization exclusively in the CLI.
Running a single app as root is useful and sometime necessary. Running the entire desktop as root can be unnecessarily risky if you're online or if someone else could sit down at your station and use your computer.
Thanks for that link @Altoid, I hope he's still around somewhere. His avatar used to be a cartoon chicken tapping on keys, I was raising chickens at the time and I had a lil banty rooster that looked a lot like his avatar, so I named him "OP junior" and posted pics frequently and he enjoyed that.
Thanks for that link ...
You're welcome.
... hope he's still around somewhere.
No way to find out, not been able to find a trail to follow.
And if Texstar (of all people) says he has no contact info, it seems to be a dead end.
well here's a simple solution and futureproofing:
first create the file /etc/sudoers.d/sudo_secure_path with these contents
# sudo secure path configuration
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"then to set the correct permissions run
sudo chmod 0440 /etc/sudoers.d/sudo_secure_pathor at your convenience the file and script to copy it and give the permissions is in the devuan-scripts repo under the sudo subdir https://github.com/eylles/devuan-scripts
Pages: 1
