Pages: 1
Is my second test in a VBox VM. My setup: German language, keyboard, timezone, expert install to cli with sysvinit, luks encrypted. Manual installation of Cinnamon DE on X11 w/o recommends to reduce the usual bloat and to get a system with that sw I like and need. I am using my notes so the result is mostly reproduceable.
Installer: no comments
German language in DE wasn't set: fixed.
Time zone not set: problem still present. There is a discussion ongoing on github LinuxMint/Cinnamon #13922. Fixed locally by installing ntpsec.
Call up of several graphical applications on the DE only worked once (bug #972): solved by adding accountservices to cinnamon as a dependency (upstream).
syslog-ng installed now, solves bug #973. I have to have a look at logrotate on the next ISO.
So far so good, no further comments.
Ladies and gentlemen, thank you for your work.
Testing the 20260903 iso at first glance shows no new topics. logrotate is present.
I see some strange characters in the terminal (I use xfce4-terminal). I can't remember if I saw them since I run Freia on a VM.
I haven't tried with another terminal. I usually have only one installed.
One question, please, regrading the forum usage. Can I attach images from my local storage to a post?
You could post you screen-dumps or image files here:
https://postimages.org/
and insert the link to your contribution here in the forum.
Good luck
Thank you Andre4freedom for your answer.
Back to strange characters in the terminal, I installed foot terminal and output looks normal: no weird characters. Maybe is related to the xfce4-terminal it self, or xfce4-terminal in a Wayland session. Otherwise, everything looks great from my personal perspective ![]()
The field of study is called "Character Encoding", grounded in the particular mechanisms in use in your circumstances.
I posted my experiences in installing Freia or Devuan 7 from its7.0-202608191935_amd64_netinstall.iso. Since the topic is related with Freia, I decided to post here what I have done this week.
[Background]
I had good impression installing Freia with lxqt several weeks ago, using its June-built netinstall iso on AMD PC with 2 SSDs of Devuan(450GB) and Windows11(125GB) respectively. 2 weeks ago, I started the re-installation of Windows 11 so that I needed to re-install Freia once again. But could not achieve the successful installation. I did not understand why so I repeated the installation this week with my low-end i5 Intel PC(4GBx2 with 320GB SSD), purchased via auction. This test result might be caused by my cooling-capacity-constraint PC, due to the summer environment. If so, apology.
[Result]
A. Xfce4
The result is getting better day-by-day due to daily system upgrade by Devuan team. Thanks for the hard work! Now it should be OK on Freia but it is not full-version installed, instead. For both of Excalibur and Freia net install iso's, I saw some difference of logoff-menu on xfce-panel. only logoff button is valid on Freia but fully valid for 5 switches on Excalibur. Used to be about 930 items installed but now 1117 items installed after selecting WM options of KDE/Cinnamon,Xfce lxde ... Full install could be more like 1160 or 1165 when I installed via 4GB devuan_excalibur_6.1.1_amd64_desktop.iso. tested yesterday.
B. LxQt
No improvement in my test period, I made multiple successes several weeks ago. I thought by selection of SSH sever option could be helpful while testing on xfce4. But it is not but increasing # of items by 5 or so. The item # installed was 926 and increased 938 items if web server option is on. No effect on the result. On the last test, I installed openbox and obconf, tint2 in addition to lightdm after login or just seeing ">". After rebooting, the system is confirmed if either of SDDM or Lightdm to be used on next login.
I saw nothing with error message of no-session for pid1806 on the screen after reboot then I made right-click by mouse to see openbox window. Obviously nothing from lxqt. After installing synaptic, 1 item of task-lxqt-desktop is x-marked and total installed item # was 1201. <end of report>
Please understand I am not complaning but appreciating your team's hard work. Thanks, Yoshi
PS
I do not use much for Windows 11 on anotter SSD since Virtualbox installed on Devuan! I installed vuudo 5.03 under VB on Windows11, not latest, by the way.
Just a quick follow-up on this. I don't care for the ugly patch I put in the installer, but it might have to stay. The problem was reported upstream to debian, which in turn reported upstream to cinnamon. Here's that report and a couple responses: https://github.com/linuxmint/cinnamon/issues/13997
Pages: 1
