Pages: 1
Is that possible to make it work at Devuan with TLP? I heard TLP is better then power profiles daemon.
Try tlp-pd from backports, apparently it provides the same dbus namespace as ppd, which is what kde is after to enable that applet.
I installed it from backports, but don’t know how to make it work with KDE
It appears Devuan does not ship a sysvinit script with tlp-pd (as usual, it's just the Debian package and no attempt was made to ensure it works properly without systemd), so somebody will need to write one.
I don't have any Devuan installs on laptops or any interest in tlp, so that someone isn't me. It should be trivial though, find an init script template and have it start /usr/sbin/tlp-pd after dbus and tlp.
...or just ask your artificial-stupid of choice to convert /usr/lib/systemd/system/tlp-pd.service, this is a pretty good example of something they should be able to do without screwing up.
Ed. Upstream just added an init script.
Grab https://github.com/linrunner/TLP/blob/main/tlp-pd.init, stick it in /etc/init.d as tlp-pd, make it executable, and enable it with update-rc.d.
Then either reboot or start the service manually then logout/login to kde.
Should work, YMMV, etc. Again, I have no desktop Devuan installs. vOv.
Thanks for your input.
What do you think about installing from source?
Script seems to be supporting sysvinit
TLP_SYSV
/etc/init.d
Install directory for sysvinit scripthttps://linrunner.de/tlp/developers/makefile.html
Edit: I installed from source. Archive cointains tlp-pd and now it running but KDE is not talking to it. Any ideas?
patryk@devuan:~$ sudo service --status-all | grep tlp
[ ? ] alsa-utils
[ ? ] hwclock.sh
[ ? ] kmod
[ ? ] mount-configfs
[ ? ] networking
[ ? ] speech-dispatcher
[ + ] tlp
[ + ] tlp-pd
That might be because tlp isn't advertising profiles that match what ppd would offer, or it might be a polkit thing... but those are just guesses. The message has changed at any rate, so kde/powerdevil sees a ppd implementation now, it just doesn't like it.
The only time I've messed with this nonsense is replacing ppd with tuned-ppd on gentoo/openrc... None of which is particularly relevant here.
You could perhaps have a look what tlp-ppd is providing on dbus (e.g. with qdbusviewer) and compare it to ppd.
Ed. What says (as root)
dbus-send --system --print-reply --dest=org.freedesktop.UPower.PowerProfiles /org/freedesktop/UPower/PowerProfiles org.freedesktop.DBus.Properties.GetAll string:"org.freedesktop.UPower.PowerProfiles"?
(aside, the above BS syntax also illustrates why and how very much I hate dbus)
patryk@devuan:~$ sudo dbus-send --system --print-reply --dest=org.freedesktop.UPower.PowerProfiles /org/freedesktop/UPower/PowerProfiles org.freedesktop.DBus.Properties.GetAll string:"org.freedesktop.UPower.PowerProfiles"
[sudo] password for patryk:
Error org.freedesktop.DBus.Error.Spawn.ChildExited: Launch helper exited with unknown return code 1
patryk@devuan:~$ Offline
That's dbus activation failing to start whatever is providing UPower.PowerProfiles (likely because the shipped definitions expect systemd and the "Exec" entry is /bin/false, see /usr/share/dbus-1/system-services/org.freedesktop.UPower.PowerProfiles.service), which implies that it isn't already running, or if it is, it didn't register on the system bus.
Note sysvinit has no service supervision, so it'll say tlp-pd is "started" even if it later exited or crashed. Check that the process is actually alive.
The manual suggests tlp-pd takes a '--debug' flag, that's probably worth a look too.
Process is not alive, because it runs on demand/trigger. But it works. It changes profile when (un)plugging power source.
patryk@devuan:/usr/share/dbus-1/system-services$ sudo service tlp status
--- TLP 1.11.0-alpha.0 --------------------------------------------
+++ System Info
System = Dell Inc. Latitude 5400
BIOS = Dell Inc. 1.4.2
OS release = Devuan GNU/Linux 6 (excalibur)
Kernel = 6.12.95+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.95-1 (2026-07-04) x86_64
/proc/cmdline = root=UUID=a1c43d75-58d7-481e-baf8-5e10fe81c105 ro quiet initrd=boot\initrd.img-6.12.95+deb13-amd64
Init system = sysvinit
Boot mode = UEFI
Suspend mode = [s2idle] deep
+++ TLP Status
tlp = enabled, last run: 14:26:25, 1438 sec(s) ago
tlp-rdw = enabled
tlp-pd = installed, not running
TLP profile = performance/AC
Power source = AC
+++ System Info
Boot mode = UEFI
+++ TLP Status
tlp = enabled, last run: 14:55:26, 8 sec(s) ago
tlp-rdw = enabled
TLP profile = balanced/BAT
Power source = batterypatryk@devuan:/usr/share/dbus-1/system-services$ cat /usr/share/dbus-1/system-services/org.freedesktop.UPower.PowerProfiles.service
[D-BUS Service]
Name=org.freedesktop.UPower.PowerProfiles
Exec=/bin/false
User=root
SystemdService=tlp-pd.servicepatryk@devuan:/usr/share/dbus-1/system-services$ sudo tlp-pd --debug
patryk@devuan:/usr/share/dbus-1/system-services$ sudo tlp-stat --trace
2026-07-27T15:27:23.851627+02:00 devuan tlp-pd: _get_tlp_profile(): Current TLP profile is 'power-saver'
2026-07-27T15:27:23.867819+02:00 devuan tlp-pd: Bus name org.freedesktop.UPower.PowerProfiles is owned by PID 12710.
2026-07-27T15:27:23.868093+02:00 devuan tlp-pd: TLP Profiles Daemon (or another one) is already running, exiting.Last edited by patgaw (2026-07-27 13:27:55)
Guys Chat GTP managed to solve it. It was about autostart order. He created script to restart powerdevil after start.
patryk@devuan:~$ cat ~/.config/autostart/powerdevil-restart.desktop
[Desktop Entry]
Type=Application
Name=PowerDevil restart
Exec=sh -c "sleep 5; /usr/lib/x86_64-linux-gnu/libexec/org_kde_powerdevil"
X-KDE-autostart-after=panel
patryk@devuan:~$ Thank you steve_v
Pages: 1
