#1 2026-06-10 09:20:57
chomwitt
Trying excalibur desktop-live.iso in qemu i get a blank screen
Host: Devuan Excalibur
$ qemu-img create -f qcow2 devuan-excal-live-storage.qcow2 10G
$ qemu-system-x86_64 -enable-kvm -m 2048 -nic user,model=virtio -drive file=devuan-excal-live-storage.qcow2,media=disk,if=virtio  -cdrom install-images/devuan_excalibur_6.1.1_amd64_desktop-live.iso
I see the boot menu and i let it boot with its default.
If i choose fail safe it proceeds ok and i login with username : devuan.
@ devuanwiki/Chomwitt
#2 2026-06-10 11:05:56
Re: Trying excalibur desktop-live.iso in qemu i get a blank screen
I get the same result when I use your command. Remove the '-nic user,model=virtio' and it works.
Note: I did not include the '-drive file=...' part in my test, so I don't know if that would also need to be changed. I use raw disk images and don't use virtio. e.g.  -drive file=${image_file},format=raw
#3 2026-06-10 20:51:10
chomwitt
qemu-system-x86_64 -enable-kvm -m 2048   -cdrom install-images/devuan_excalibur_6.1.1_amd64_desktop-live.iso
works again only on failsafe option.
#4 2026-06-11 00:41:03
I don't know the solution, but you could try the options in the failsafe boot one at a time, or eliminate them one at a time until you find the one that makes the difference. I would start with just adding 'nomodeset' to the default boot command. That one is often useful to eliminate black screen.
BETTER SOLUTION:
I used your command and added '-vga qxl' and the desktop comes up.
qemu-system-x86_64 -enable-kvm -m 2048 -nic user,model=virtio -vga qxl -cdrom isos/devuan_excalibur_6.1.1_amd64_desktop-live.iso
Make sure you have xserver-xorg-video-qxl installed.
