#1 2026-06-09 17:19:35
safari
VPN on Devuan 7
I want to use a free VPN on Devuan 7. I'm trying with Proton VPN. The GUI app is Gnome, so I'm trying with the CLI, but
sudo apt install proton-vpn-cli
yields
Solving dependencies... Error!
Unsatisfied dependencies:
 proton-vpn-cli : Depends: python3-packaging but it is not going to be installed
                  Depends: python3-proton-keyring-linux but it is not going to be installed
                  Depends: python3-proton-vpn-api-core (>= 5.0.0) but it is not going to be installed
                  Depends: python3-click but it is not going to be installed
                  Depends: python3-dbus-fast but it is not going to be installed
                  Depends: python3-proton-core but it is not going to be installed
                  Depends: python3-tabulate but it is not going to be installed
Error: Unable to satisfy dependencies. Reached two conflicting assignments:
   1. python3-proton-core:amd64=0.7.4 is selected for install because:
      1. proton-vpn-cli:amd64=1.0.1-1 is selected for install
      2. proton-vpn-cli:amd64=1.0.1-1 Depends python3-proton-vpn-api-core (>= 5.0.0)
         [selected python3-proton-vpn-api-core:amd64=5.2.4 for install]
      3. python3-proton-vpn-api-core:amd64=5.2.4 Depends python3-proton-core (>= 0.5.0)
         [selected python3-proton-vpn-api-core:amd64=5.2.4]
      For context, additional choices that could not be installed:
      * In proton-vpn-cli:amd64=1.0.1-1 Depends python3-proton-vpn-api-core (>= 5.0.0):
        - python3-proton-vpn-api-core:amd64=5.2.3 is not selected for install
        - python3-proton-vpn-api-core:amd64=5.1.2-1 is not selected for install
        - python3-proton-vpn-api-core:amd64=5.1.2 is not selected for install
        - python3-proton-vpn-api-core:amd64=5.0.1 is not selected for install
      * In python3-proton-vpn-api-core:amd64=5.2.4 Depends python3-proton-core (>= 0.5.0):
        - python3-proton-core:amd64=0.7.3 is not selected for install
        - python3-proton-core:amd64=0.7.0-1 is not selected for install
        - python3-proton-core:amd64=0.7.0 is not selected for install
   2. python3-proton-core:amd64=0.7.4 Depends python3-importlib-metadata
      but none of the choices are installable:
      [no choices]
Indeed apt search python3-importlib-metadata returns nothing.
I managed to install it before but I can't figure out how.
#2 2026-06-09 17:49:53
kapqa
Re: VPN on Devuan 7
this has been shared before,
but you could use the manual approach if the cli is no longer compatible with deuvan<
it used to install before, even though it is for made gnome, but so times it break compatibility.
this approach still function from experience , it is relatively easy to achieve.
https://protonvpn.com/support/linux-openvpn
*how to manually configure openvpn CLI for linux
or
https://protonvpn.com/support/wireguard-linux
i prefer use openvpn since it seem less invasive but sometime on a distro had problem installing openresolv so could resort to thiw wireguard.thing
#3 2026-06-09 17:58:57
StinkyEmptyAfterlife
Re: VPN on Devuan 7
I'll go ahead and link my post on the same topic, where the links provided got my VPN up and running. Might want to download a few conf files because sometimes one of the servers is slow or down: https://dev1galaxy.org/viewtopic.php?id=8021
#4 2026-06-09 18:25:07
safari
Re: VPN on Devuan 7
Thanks. That did work, in that I can now connect to individual servers. Would still be interested in a fix for the proton app.
#5 2026-06-09 22:43:09
dzz
Re: VPN on Devuan 7
python3-importlib-metadata is not in testing/unstable repos but the stable version installs here on Devuan Freia..
https://packages.debian.org/search?suit … b-metadata
#6 2026-06-09 23:24:18
Re: VPN on Devuan 7
Also https://pkginfo.devuan.org/python3-importlib-metadata
-- more directly devuan focussed.
#7 2026-06-12 15:03:17
safari
Re: VPN on Devuan 7
I've been pointed towards Stable packages a couple of times now. I wonder why these are not present in the Testing repos if they're fine to install? How does one install Stable packages on Testing?
btw Proton have fixed their firefox VPN extension so one can now install that, at least for web browsing
