#1 2026-06-04 05:23:34
StinkyEmptyAfterlife
[SOLVED] Help! Install failing repeatedly/failing to mount file system ext4
Hello. I attempted to install Devuan 6 on my main PC today. However, the installation failed multiple times. At this point, it isn't getting past the partitioning stage. I had Windows 11 up and running up till this point. Before installing, I tinkered with the BIOS a bit. I disabled and cleared the TPM chip and disabled the "Absolute" tracking system. I am not sure if these changes are relevant, but moving on to the installation... Each time I tried to install I was warned that the intel/sof/sof-tgl.ri firmware was missing. I ignored it as it seemed to be unrelated to the download. The first time through I didn't even manage to get past NW configuration. I had to try again with an Ethernet connection. 2nd time, the installation was almost fully complete, but encountered this:
Configuring shim-signed:amd64
Unable to configure GRUB
Executing 'update-grub' failed
This is a fatal error
After which the installer took me back to the main menu. I had the option to try installing the GRUB boot loader again, but it once again failed. I aborted the install and tried again, but when my PC restarted it took me to some kind of GRUB terminal. I restarted and went to BIOS this time. 'debian' was now above my installation USB in the boot order, but I booted from the installation media manually.
And that's where I'm at now. Partitioning fails every time I try to install. I tried switching the installation USB for a fresh one; no dice. This is the error I keep getting now:
The attempt to mount a file system with type ext4 in /dev/nvme0n1p2 at / failed.
Currently, nvme0n1p2 is a 989GB ext4 partition. So yeah, my computer is a bit unusable right now but at least I can boot from USBs. I could really use some help to fix this and properly install Devuan. I read somewhere that the issue could be that my ext4 partition is corrupted, but I don't know if that is the case for me.
#2 2026-06-04 09:24:05
kapqa
Re: [SOLVED] Help! Install failing repeatedly/failing to mount file system ext4
one safe bet with desktop computer is always to go into BUOS and press F5 or F8 for default setting;
afterwards you can attempt to install Linux in UEFI or Legacy Modo depending on your needs.
found that with Linux the most failsafe has been to install from burned DVD-iso's , but modern .iso not always find enough space on a 4.7-GB-DVD or even 8.5-GB-DVD;
Devaun is here a notable exception; but had bit more problem lately with installing Devuan 6 than before;
you just need make sure that your eventual Windows installation and Linux are installed the same method (UEFI or legacy BIOS), otherwise grub won't see them vis-a-vis.
if you have a newer computer, it will most certainly be with UEFI (even UEFI only);
sometimes Microsoft forces on certain Windows pre-installed OEM-PC Secure-Boot setting, which makes it ab it more difficult to install Linux, but eventually you will succeed.
#3 2026-06-04 12:06:52
Hi there. I do not get the full picture yet, your post is a bit confused.
What is your goal? Replace Win11 completely or a parallel installation to Win11? The steps to take are different. Before going into details, we should clarify this topic.
TPM isn't relevant for the installation of Excalibur.
Personally, I would go and switch off Secure Boot. On some PCs this is called "Other OS". And I delete all SB keys. Don't need them.
What is this "the "Absolute" tracking system"?
This is Audio stuff, you can ignore it until Excalibur is up and running.
You may install w/o network. I often do.
Setting up wifi can be very challening in the installer, depending on the HW used. The better solution: Ethernet normally is no big problem, except for on some exotic chipsets.
Sounds like there is an issue with getting the efi grub installed. That can have several reasons. Maybe a confusion between legacy/efi install?
Some remarks:
Your PC must be an modern UEFI capable system, that means only an installation in efi mode makes sense. Make sure that you have disabled CSM in the bios.
When booting the install media, make sure you boot it in efi mode. The bios should show a prefix like efi or uefi before the name of the device.
For an efi installation you need a FAT32 formatted ESP partition. When you do manual partitioning, the ESP has to be configured in the partitioner as ESP, it does not need to be partitioned. Win leaves a relatively small ESP of a bit more than 100MB. When you do a clean Devuan only install, spend 1024 MiB.
It should be no deal to use /dev/nvme0n1p2 as / with ext4 file system. When its empty, you can have it formatted by the installer without data loss. Just the assignment has to be correct.
Good luck.
PS: Here you can find some reading: https://www.devuan.org/os/install
#4 2026-06-04 15:12:39
rbit
What's the filename of the ISO you're using?
From your description, I'm pretty sure you're using one of the installer ISOs, not the live ISO, but just want confirmation of that.
You mentioned you're using USB for the installer.  How did you copy the ISO image to the USB drive?  The preferred method is to write the ISO directly to the USB block device (for example, using dd).  Multiboot schemes may cause issues with the installer, such as booting it in legacy mode instead of EFI mode.
#5 2026-06-04 17:22:41
First of all, thanks for the help thus far. I'll provide a bit more context than my initial post in this reply. First of all, I am using a laptop not desktop. My plan was/is to completely switch from Windows 11 to Devuan 6. No dual booting. Second, the ISO I am using is "devuan_excalibur_6.1.1_amd64_netinstall.iso". I burned it right onto the USB with BalenaEtcher and I'm booting straight from it. Strangely enough, when I go into BIOS the USB shows up twice but booting the first one brings up the installer (haven't tried the second).
For my BIOS settings, I already disabled Secure Boot but didn't mention it in my first post. The "Absolute" tracking system is to my understanding a feature that helps you get the physical location of your PC if you lost it. I didn't have the relevant software so I saw no reason to keep it enabled.
Now in terms of the EFI/UEFI/legacy stuff, I am not very familiar with those so I might need some more help. I can confirm BIOS is listing my USB as UEFI. My BIOS doesn't have a CSM option. I suppose my PC is UEFI only.
Last thing: to my understanding I should be all clear to fully wipe the drive and try again? Theres an option to do that right in BIOS I just dont want to mess anything up. Also, should I go for manual instead of auto partitioning? One of you mentioned making a 1024 MB partition for ESP.
#6 2026-06-04 18:06:02
UEFI boards do that. If you boot the one without a note/prefix/postfix saying its efi or uefi then you boot the installer in legacy mode. And if you have a brand new laptop it will be uefi only.
Make sure you boot the install stick in UEFI mode.
The easiest way is to use the installer during partitioning, and to write a new GPT to the drive. That makes sure the old stuff is deleted. There is nothing in the bios that could do that.
Then you first create a 1024MiB large partition, assign it to be ESP, and the rest is done by the installer.
Next you create a whatever you like large partition for /, ext4 as file system and mount point /.
Take a read on the webpage I already mentioned, there is a installtion instruction with pictures. But as far as I know it just describes the auto mode. Manual partitioning isn't mentioned in there. Its a bit arkward.
#7 2026-06-04 18:40:17
Alright I reformatted using the installer. I also made sure it's in UEFI mode. Took a look at the page you sent but I seem to be doing everything on there properly. I currently have this:
     1.0 MB FREE SPACE
#1 1.0 GB ESP
      3.2 GB FREE SPACE
#2 1.0 TB f ext4 /
      335.4 KB FREE SPACE
The installer is telling me to make a SWP partition as well. How large should I make that one?
#8 2026-06-04 18:48:13
Well, that one thing I forgot to mention. I am normally putting that into an encrypted LVM together with /.
If you want to use hibernation, make it a bit bigger that the size of the RAM. In old times the saying was twice the RAM, nowadays 1,1 x size of RAM is fine. Your best option is to delete the ext4 partition, first of all create the swap, and then use the rest for /.
#9 2026-06-04 18:56:32
Okay. I went ahead and did 1 GB ESP, 40 GB swap,  ~980 GB ext4. I'm now encountering the same error I got earlier in my post chain:
"Attempt to mount a file system with type ext4 in /dev/nvme0n1p3 at / failed."
#10 2026-06-04 19:34:01
Strange. Have you ticked the format option in the partitioner? I am without any clue what maybe wrong, at least without a better idea about what you have entered. Can you post your settings line by line please? When exactly does this message appear? When leaving the partitioner?
What kind of HW are we talking about? Brand of the laptop and the NVME would be interesting.
I haven't used the 6.1.1 netinstall myself yet, maybe I give it a try in a VM when I have a bit of time.
#11 2026-06-04 20:25:59
kapqa
iut is not directly related, but its a strange world out there!
https://download.lenovo.com/pccbbs/mobi … re_PCs.pdf
tend to download the full devuan iso instead of netinstsall.iso ; it is usually the faster method, provided you have good internet connection; but it should not change your outcome; where netiinst can fail, the full iso could succeed ().
also, automaticl installation for a newcomer should suffice; but to be honest, even after 10+ years of linux use,
have not really understood the mannual partition or how it is done properly;
things seem to change; once there was a big swap, then a small , now it is even done without swap;
then there is the other option lvm-manager etc;
but if you had windows first and want just linux, would go into bios and "safe-delete" the nvme first,
plus eventually delete the secureboot-keys, but it should not be necessary.
good luck + tidiings in your favour.
#12 2026-06-04 20:37:07
Short update: the 6.1.1 netinstall in a VM led to a working cli installation with a similar setup as yours.
Please tell us your work sequence and where the problem finally appears.
#13 2026-06-04 22:01:41
OK, here was my final setup before wiping the drive and trying kapqa's solution:
Partition #1: Formatted with FAT32, use as EFI System Partition, bootable: off, size: 1GB
Partition #2: No existing file system was detected, use as ext4 journaling file system, mount point: /, mount options: defaults, label: none, reserved blocks: 5%, typical usage: standard, bootable: off, size: 989GB
Partition #3: No existing file system was detected, use as swap area, bootable: off, size: 34GB
The install always fails during/shortly after partitioning.
For kapqa, the 3rd party option mentioned in your link is not in my BIOS. I did do a Secure Wipe and tried again with the desktop install (assuming that is what your were referring to). Still no dice. Same error and also the installer usually fails to "detect and mount installation media" once or twice each time now, requiring me to try that step again.
I am a little worried this issue may somehow be with my SSD itself. I found a similar post where the user had to trash the drive and get a new one: https://www.linuxquestions.org/question … 175665606/
And well, SSDs were a lot cheaper in 2019 than they are now sad
#14 2026-06-04 22:11:37
Small update: I just tried to use a Windows recovery stick to atleast bring my PC back to its former state, but the installer isn't even recognizing my SSD.
#15 2026-06-04 22:21:07
kapqa
here it is written
https://unix.stackexchange.com/question … le-and-why
"you must install grub to the bootable partition"
but am not sure were the truth lies on these matters.
you could always try to install first doing the "automatic partitioning"  , and see what changes the partitioner proposes;
and then make the changes you desire if you so like;
#16 2026-06-05 04:16:49
Good news/update! I fixed the issue. Apparently the reason I was encountering issues was because my storage mode in BIOS was set to RAID and needed to be AHCI. Everything is gladly working as intended now smile
#17 2026-06-05 14:58:57
thanks for the update and the solution!
#18 2026-06-06 09:17:58
PedroReina
Maybe the takeaway of this thread could be "check carefully all the options in your BIOS". I' ve always done it, although I don't understand every single item smile
#19 2026-06-06 19:57:26
Yeah definitely, or rather, pay very close attention to the screen that flashes right when booting the install media. There was a brief warning about being "unable to probe AHCI". Almost too fast to read it.
