#1 2026-05-24 00:18:21
mknoop
excaliber odd /etc/hostname file
I recently reinstalled a copy of devuan_excaliber_6.1.1_amd64 on a virtual machine and discovered that the /etc/hostname file says debian-stable, and the /etc/hosts file has the line
127.0.1.1            debian-stable
It was trivial to fix  but was this intentional or just an oversight?
I can't find any package containing these file names using dpkg --search, so I can't file a bug report.
#2 2026-05-24 00:43:51
Re: excaliber odd /etc/hostname file
I believe it's the base-files package, totally harmless, alter as you see fit, I change it to reflect Vuu-do and it actually doesn't get over-written on updates.
#3 2026-05-24 08:14:10
mknoop
I did a dpkg --listfiles base-files, and the offending files were not there.  I think the files may be created by the system installer.
#4 2026-05-24 13:36:21
rbit
Setting the hostname is the 3rd screen of the installer as documented here https://www.devuan.org/os/documentation … installing
You can set it to whatever you want.
#5 2026-05-24 23:05:42
mknoop
Again, this is not a major issue, but I am 99% certain I entered devuan-stable on that screen.  Which makes me wonder if the installer is just ignoring the field.
Anyway, I think I am going to stop fussing about this.
