#1 2026-05-07 01:49:58
BonerNimrod
Setting up automatic updates (or something close to it).
I had recently installed Devuan for the first time on a used laptop, and essentially put, I would like to set up a way to automatically update the system and any installed packages. I'm mostly coming off from Mint, did dabble in Debian last year, but I'm mostly used to how the former handled updates through it's manager, and perhaps prefer it. So far, I have both Gnome-package-manager and unattended-upgrades installed. From what I remember, I think used package manager the most on Debian. I only discovered unattended-upgrades late into my foray, but I don't believe I had it set up to know if it did work for me. Also, I learned it mostly does security updates. What would be the best way to set up, at least, a manager that would notify me from time to time, and let me review what updates I would need to install on my machine? I would like to have something similar to Mint's manager, but I can try and learn about other alternatives. I'm not afraid of the terminal, but it is a bit inconvenient to type the commands and remember to do it every now and then. I appreciate any replies, I'm new here.
#2 2026-05-07 15:47:11
Re: Setting up automatic updates (or something close to it).
This was put together by a few of us in the devuan community a few years ago. It still works - I'm using it in excalibur. It checks for updates and gives you a notification in the panel.
https://get.refracta.org/files/packages … sr_all.deb
See /etc/default/update-notifier for settings.
And now, looking at that file myself, I'm reminded that it can do more than just notify you. Here's an excerpt.
# Set the default action for clicking on the notification icon.
# Valid choices:
# "none" or commented to only see a list of available upgrades.
# "terminal" to run the upgrade in a terminal
# "gui" to run the upgrade in synaptic package manager.
FRONTEND="none"
Edit: Source is here: https://git.devuan.org/fsmithred/basic-update-notifier
#3 2026-05-07 23:36:29
BonerNimrod
I'll give it a try, thanks. I assume this would take care of only the packages shown on Synaptic, and any new versions of Devuan, correct?
#4 2026-05-07 23:59:04
It should work with whatever is in your apt sources and do the same as using apt or apt-get to update and upgrade.
#5 2026-05-08 14:57:13
PedigreeCat
I use a simple script that runs via cron. It requires absolutely no maintenance, which is why I installed it on my wife's laptop wink
Here is the content of the script:
#!/bin/bash
#if not root, run as root
if (( $EUID != 0 )); then
    sudo $0
    exit
fi
echo
echo ">> Looking for updates."
apt update --fix-missing
echo
echo ">> List of upgradable packages"
apt list --upgradable
echo
echo ">> Upgrading..."
apt -y full-upgrade --fix-missing --fix-broken
echo
echo ">> Making cleanup..."
apt -y autoremove
apt clean
apt autoclean
apt purge -y $(dpkg -l | awk '/^rc/ { print $2 }')
echo
echo ">> Flatpak updates..."
flatpak update -y
echo
echo ">> Done."
echo
If you're interested in a more advanced tool, check out topgrade:
https://github.com/topgrade-rs/topgrade
Murphy was an optimist...
#6 2026-05-08 21:17:25
BonerNimrod
Seems interesting. Got no experience with cron scripts, unfortunately, but Topgrade does look tempting. Might help me with flatpaks and appimages, from the looks of it. Thanks.
#7 2026-05-09 08:05:58
PedroReina
You will not find a better occasion for learning than scratching your own itch. Don't be daunted, cron scripts on Debian and Devuan are easy to set up. Pick your tutorial, start with something easy... and take off. Friendly advice smile
#8 2026-05-09 08:31:11
PedigreeCat
It's not too difficult. Save the contents to a file, such as sysupdate.sh, and set its execution permissions:
# chmod a+x sysupdate.sh
Then move the file to the /usr/bin directory:
# mv ./sysupdate.sh /usr/bin
Next, edit the cron configuration file:
# nano /etc/crontab
and enter the command to run the sysupdate.sh script:
0 21 * * * root /usr/bin/sysupdate.sh
This entry means that cron runs the script every day at 21:00 as root. Of course, you can change the script’s execution time to whatever you need.
Alternatively, instead of messing with editing crontab, after having granted the script execute permissions and moving it to /usr/bin, you can make a symbolic link in the /etc/cron.daily directory
# ln -s /usr/bin/sysupdate.sh /etc/cron.daily
and the script will be executed once a day.
That’s it. The script runs on its own, updates the repositories, installs new package versions, and cleans the system of old or unnecessary versions. For system-critical packages, changes take effect after the system reboot. This isn’t a problem for me, as I’m not a fan of keeping the system run for months.
In the script itself, you can block, for example, updates to Flatpak applications if you don’t have them.
The section at the very beginning of the script (5 lines below the #!/bin/bash line) is for systems with sudo and forces the sudoers to enter their password when the script is run manually by the user. In Devuan, you can ignore this and run the script manually with the command
su -c sysupdate.sh
#9 2026-05-09 13:57:41
BonerNimrod
Seems easy enough. I can add other entries into it as well, like Appimage Package Manager?
#10 2026-05-09 14:17:40
PedigreeCat
I've never used the AppImage Package Manager, but if you can set it up to run unattended, then by all means, go for it.
Also, from what I’ve read in the Topgrade documentation, this program can handle everything that the sysupdate.sh script does, as well as AppImage (and much more).
You can then add Topgrade to your cron schedule instead of the sysupdate.sh script.
And if you need to run Topgrade manually as an ordinary user, you can execute it with the command:
su -c /usr/bin/topgrade
