#1 2026-04-30 12:23:39
askfor
[SOLVED] Sound issues with Excalibur
I have noticed that there are othe posts realated to the sound issues. However, I am not sure if mine is related to any of the.
In fact there were two problems. The quirky one was about a pin on the hardware interface, related to speakers, not being activated.The problem is solved with help of ChatGPT, and, to be honest, I don't really understand how and why it works,because it is very much hardware related. The sound device I am using is:
Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 01)
It is Realtek chip, far as I can understand. Rather common sound hardware. It works fine with Slackware on the other partition. The solution which worked was to add the following to /etc/rc.local I have modified the script a bit
SDEV="/dev/snd/hwC0D0"
sleep 5
if [ -e $SDEV ]
then
   hda-verb $SDEV 0x15 SET_PIN_WIDGET_CONTROL 0x40
else
   echo "$DEV not found"
fi
alsactl restore
'hda-verb' line is the key. I wish I understand the problem better, but I don't. I hope it might help somebody else with similar issue. Also, I should say that Excalibur was installed from single 'server' CD image (around 650M).Perhaps the installation from some larger image solves the problem somehow.
The second problem is trivial compared to the first one. I have two sound device on the system. The other is HDMI device in the NVIDIA card. It works with speakers attached to the monitor, which I don't have.  So I blacklisted the device :
blacklist snd_hda_codec_hdmi
Also the initrd needs to be updated with update-initramfs. This second issue might be trivial, but till someone might lose hours getting around it.
Either way, the sound works now.
#2 2026-06-14 12:27:47
askfor
Re: [SOLVED] Sound issues with Excalibur
I have installed firmware-intel-sound and it resolved the issue completely. Addition to rc.local is not needed any more.
I have considered this for a while, but my audio chip was not listed among those supported, so I hesitated. I did it anyway in the end and it worked.
I guess it all happened because I installed from minimal 1 CD media.
