#1 2026-04-04 21:11:41
franmm
Plasma-discover don't work out of the box
Good afternoon,
On Devuan Excalibur, Discover (KDE's gui front-end for apt) don't work, showing a message that says that there is no internet connection.
This problem has been seen by some people since a sometime (see https://dev1galaxy.org/viewtopic.php?id=5892 or https://dev1galaxy.org/viewtopic.php?id=7782 or https://www.reddit.com/r/devuan/comment … tl=es-419)
Why this happens and how it can be corrected upstream by Devuan creators?
Sorry as english is not my first language, and I don't know a lot about Linux. Thank you for your patience and time!
#2 2026-04-05 09:04:12
Elyon
Re: Plasma-discover don't work out of the box
"Home" card indeed didn't work here but searching for packages or browsing trought categories did work. Have you tried that?
Thinkpad x280 - Devuan Excalibur 6 - Xfce Desktop Environment - Apt/Appman
#3 2026-04-06 12:54:35
franmm
@Elyon
Next time I test Devuan with Plasma I'll try what you've said, but now I can't as I returned using Devuan with XFCE, on which sound works OOTB. Thanks for the help!
#4 2026-04-15 15:35:00
franmm
@Elyon
Just tried another time to install Devuan with Plasma.
Only 2 categories of Plasma works, and those are "Applications complements" and "Plasma complements". My system is in spanish so I don't know if translations are accurate.
Thing is, I can't see any .deb on Discover, it displays a message "We haven't found anything" at every category (all apps, accesibility, science and engineering, etc...).
#5 2026-10-06 12:34:09
KindlyDoRight
KDE Plasma Discover, packages fix
The solution (provided by rbit) is "shown running" here:
    https://dev1galaxy.org/viewtopic.php?pid=65844#p65844
And rbit's perfectly working shell script is here:
    https://dev1galaxy.org/viewtopic.php?pid=63245#p63245
(I've tested that it works perfectly with Devuan 6 excalibur,
    and it is coded to also work with Devuan 7 freia,
    and Devuan 5 and 4, daedalus and chimaera).
