#1 2026-03-18 20:11:03
Devarch
How to pure OpenRC-based Devuan?
Is it possible to install OpenRC on Devuan and use it for init?
Devuan only supports SysVinit, and OpenRC is considered a fake init in this context, similar to runit  (frankeninits). This means that even if I choose OpenRC during installation, the boot process will still be managed by SysVinit.
I've tried to create a pure OpenRC Devuan system but did not succeed. I added init=/usr/sbin/openrc-init to GRUB_CMDLINE_LINUX_DEFAULT in grub. The system starts and shows:
Setting up keyboard layout...done.
Starting swap...done.
Starting early crypto files...nvme01p5 crypt (running)...done.
Checking remaining crypto files...32/131072 files, 53216/54288 blocks
crypt file systems: fsck.fat 4.2 (2021-01-31)
boot:/dev/block/33:212 files, 6948/13682 clusters
done.
Cleaning up temporary crypto files...
Activating local filesystem swaps...if any...done.
Cleaning up temporary Swap, if any...done.
Starting up ArmorLoading applications profiles...done.
Starting Setting kernel variables: systl...done.
Configuring network interfaces...done.
Cleaning up temporary firewall rules...done.
Starting netfilter boot and shadow times into wtmpdb:
ntpd-update-boot.nb
Starting system message bus: dbus.
Starting default runtime cron daemon: elogind.
Starting anacron (hypothetical) service.
Starting rc-modules: bluetooth, network manager.
Starting console command scheduler: crond.
Starting network connection manager: NetworkManager.
Then it gets stuck.
/etc/runlevels/boot is empty. I've tried to fill it with symlinks, but that did not help.
#2 2026-03-20 20:59:33
abower
Re: How to pure OpenRC-based Devuan?
I don't think that's fair about runit. In ceres now 21 packages have native runit integration for their daemons and the runit-services package adds 55 additional services (of which 2 were added today). Most of the services on my laptop are now covered in stage 2.
The single-shot/startup actions (stage 1) are not so well covered but I think some commonality with other inits makes sense for these things.
OpenRC I think is held back by not having a second directory where openrc's own interpreter can be used to override the initscript fallbacks. I suspect that would be a useful improvement for the debian package, although this is guesswork as I don't use OpenRC and don't plan to.
#3 2026-03-21 13:12:24
Devarch
the keyword is "Ceres" smile
I've an impression that openrc scripts are simplier than runit scripts (I don't have experience with runit). One more advantage of openrc is that pipewire can be launched as user services and audio switchs automatically when hardware is changed.
#4 2026-03-25 04:51:42
Mercury
As someone who's gone through quite a bit of keyboard-snapping frustration with runit, I think this isn't an accurate assessment. runit does use sysVinit service scripts to fill in for gaps in support, but it's a genuine init system with a solid core.
#5 2026-03-25 05:14:30
Dutch_Master
I'm aware there's a script that needs to be called manually when converting from SysVinit to OpenRC in Devuan, populating the various levels properly, but I can't recall said script. You should be able to trace it down following the dependency chain in apt.
HTH!
#6 2026-04-08 09:52:03
scottfk
I just switched my RPi 4b to openrc-init.  I had previously moved my Gentoo desktop over to openrc-init following their instructions:  https://wiki.gentoo.org/wiki/OpenRC/openrc-init
The only thing that didn't work for me there was networking.  There I had to add my network interface to the default runlevel, then I was off to the races.
# rc-update add <my interface's start script in /etc/init.d> default
I pre-checked my RPi, and saw that network-manager was already in the default runlevel.  When I rebooted, it Just Worked(tm).
The only thing I did extra was to ensure that my serial console would work (in case networking didn't come up) by adapting the Gentoo instructions:
# ln -s /etc/init.d/agetty /etc/init.d/agetty.console && rc-update add agetty.console default
I literally just did all this, so if my RPi blows up later today I will post an update.
#7 2026-04-13 06:50:23
abower
Devarch,
True, but I have now backported runit-services to Debian trixie, meaning the Devuan excalibur-backports repository gives access to the version of runit-services which is in Devuan Freia, as of today (0.12.0~bpo13+1).
That covers services which got added in Freia's version of runit-services; it does not cover the tiny number of packages which obtained their own native runit scripts in Freia as they would need to have their own individual backports, too.
#8 2026-05-11 19:51:30
JCK
For me it almost worked out of the box including the proper /etc/conf.d/agetty config and the poweroff shim inspired from here https://laskarnix.org/devuan-migrate-fr … enrc-init/.
It probably gets stuck because some leftover sysv style scripts conflicting somewhere, i removed all except for the 6 or so mount*.sh.
#9 2026-05-20 13:46:01
JCK
Some pretty good news, i tested last evening a vm with the latest Freia netinstall iso, selected OpenRC option and after install just added "init=/sbin/openrc-init". The boot process doesn't get stuck anymore, only smaller stuff breaks like connman (works if you restart it), apparmor, an alsa script (works anyway) and a resolveconf script (also gets set by something else). I sometimes get some warnings that "x is the name of a real and a virtual service" so some symlinks need to get cleaned, but they all work.
I can point /sbin/init to /sbin/openrc-init and it also boots, so if someone who knows apt packaging has the time for this, it can be made official quite easily. :-)
#10 2026-05-20 14:24:23
That is good news JCK, and very interesting. I don't have anything to add here but i'm tagging for any future developments, i'm a sysvinit guy, but more options are always better. wink
#11 2026-05-28 18:21:04
gruffs
JCK,
I just made the migration to openrc-init using the guide you posted here. Thank you!
#12 2026-06-24 17:46:46
beate
Did that. Works nicely. But there are things remaining
a) the udev error messages mentioned elsewhere ... on my TODO list.
b) all the rc*d directories from sysvinit. harmless but potentially irritating. can be safely removed after activation of openrc-init and -shutdown stuff.
c) one of them causes a problem: rc.local
In Alpine that directory is used by openrc to add some fine tuning after the runlevel has completed its setup.
I need to use something like this in connection with iwd - configure an AP on wlan0, set up ip forwarding in the kernel and the appropriate firewall rule for masquerading/forwarding.
Four simple commands dependent on iwd up and running. Similar use cases come to mind, e.q. "real" firewalls.
And, honestly, i do not find an "official" place to do that cleanly in devuan (excalibur). Mhmm.
This regard not the script by itself, just the question where to establish it. (/etc/conf.d/iwd will be executed before iwd is set up)
#13 2026-06-28 02:19:39
Here are some  notes on iwd install and configuration for svinit to open-rc script... sysd2v-0.3.sh
## The iwd.service is the systemd service for the iNet Wireless Daemon (iwd), a wireless management daemon developed by Intel for managing Wi-Fi connections on Linux systems.
##  It is designed to be a lightweight, efficient alternative to older tools like wpa_supplicant, offering minimal memory and CPU usage, built-in support for WPA/WPA2 and WPA3, and a command-line interface (iwctl) for managing wireless networks.
##  To use iwd, the service must be enabled and started using the commands sudo systemctl enable iwd.service and sudo systemctl start iwd.service.
## The service is controlled through the iwctl utility, which provides an interactive shell for managing wireless devices, scanning for networks, connecting to Wi-Fi, and viewing connection details.
##  For automatic network configuration, including DHCP and DNS resolution, iwd can be integrated with systemd-networkd or systemd-resolved, though additional configuration may be required for full functionality.
##  For example, if using resolvconf for DNS management, the iwd.service may need to be customized to include RuntimeDirectory=resolvconf and ReadWritePaths=/etc in its [Service] section to resolve permission issues with /run/resolvconf.
# apt install iwd -y
# sh /home/glenn/bin/sysd2v-0.3.sh /lib/systemd/system/iwd.service
# rsync -avh /home/glenn/local/other/backup/backup-etc-sys/etc/init.d/iwd.initd /etc/init.d/
# rsync -avh /home/glenn/local/other/backup/backup-etc-sys/etc/runlevels/iwd.initd /etc/runlevels/
# rsync -avh /home/glenn/local/other/backup/backup-etc-sys/etc/systemd/system/multi-user.target.wants/iwd.service /etc/systemd/system/multi-user.target.wants/
# chmod +x /lib/systemd/system/iwd.service
# chmod +x /etc/init.d/iwd.initd
# service iwd.initd start
# update-rc.d iwd.initd defaults
link to "You could try the sysd2v-0.3.sh conversion script, that might work:" http://www.trek.eu.org/devel/sysd2v/
I hope this helps
