#1 2017-07-02 16:33:53
alsen
Install graphic user interface on Raspberry 3
How and which graphic environment I can install on Devuan Raspberry 3
Thnks
Alberto
Maker and a fun of Devuan
#2 2017-07-03 11:39:55
linijkarz
Re: Install graphic user interface on Raspberry 3
Most likely all of them, though for such underpowered device I'd really recommend something along the lines of Xfce or LXDE.
In the same way as you would on debian.
#3 2017-07-03 18:32:04
alsen
I have do this sequence of command
#apt-get update
#apt-get upgrade
#apt-get install xfce4
all seems downloaded  and installed ok but
#root@devuan:~# startx
mktemp: failed to create file via template '/tmp/serverauth.XXXXXXXXXX': Read-only file system
xauth:  error in locking authority file
xauth:  error in locking authority file /root/.Xauthority
I obtain a read-only file system
any ideas ?
THanks
Alberto
#4 2017-07-03 20:48:39
donpine
IIRC I had the same problem.  I suspect your xserver was not installed.  Try (as root):
apt-get install xserver-xorg
Let us know if this works.
#5 2017-07-04 18:10:42
alsen
Hi donpine,
Yes it works
I have restart from a fresh image of last Devuan image for Raspberry 3
#apt-get update
#apt-get upgrade
#apt-get install xserver-xorg
#startx
But another question .... is missing a good browser ...
Thanks to all
Alberto
#6 2017-09-30 22:13:16
Racoton
YOu can use fluxbox window's manager. It's lighter and its face remove hiccups.
#7 2017-10-01 11:02:26
FOSSuser
With only 1gb ram in a Pi3, Firefox will run, but is slow, depending on websites you visit, it may be worth trying Dillo, but it is a bit quirky to use. smile
