Pages: 1
I just installed the latest version of Devuan. I am running the LXDE desktop. I have downloaded waterfox and moved the directory to /opt. I have added /opt to my $PATH with:
export PATH=$PATH:/optto my ~/.bash_profile file and updated $PATH.
Currently, there are two programs, residing in each their folders, one was installed as a .deb file, the other is waterfox. Waterfox still does not appear to be recognized by the system, where as the other program does. I have created a waterfox.desktop file for waterfox, however, my experience with a previous install tells me that this doesn't work if using dmenu with spectrwm, which is my daily driver. It will only work if I include the full path to the binary. I assume that this has something to do with apparmor, but haven't a clue as to what to do, as I have no experience with it.
Can anyone provide some advice, before I start futzing around on my own?
I’ve had a perfectly wonderful evening, but this wasn’t it. - Groucho Marx
... something to do with apparmor, but haven't a clue as to what to do ...
Get rid of apparmor and the rest of that crap?
https://dev1galaxy.org/viewtopic.php?id=5317
https://dev1galaxy.org/viewtopic.php?id=2630
https://dev1galaxy.org/viewtopic.php?id=4329
https://dev1galaxy.org/viewtopic.php?id=4750
As always, YMMV.
OK, thanks for your reply and posting those links. Now I am less sure that it is AppArmor that is the culprit, but there is something that is definitely going on. From the LXDE environment, if I run the following, I get a longer response:
$ simplenote
Checking for beta autoupdate feature for deb/rpm distributions
Found package-type: debWhat is that autoupdate "feature"?
$ waterfox
bash: waterfox: command not foundBoth programs reside in /opt, which is in my path... The binary paths are as follows:
/opt/Simplenote/simplenote/opt/waterfox/waterfoxand
/opt/waterfox/waterfox-binBoth programs appear to have the correct ownership for the /opt directory, so why will one run and the other not?
I am still in the process of getting this set up properly, however I have run through a diagnostic process. The conclusion appears to be that for some reason,
export PATH="$PATH:/opt"also needed to be included in the ~/.bashrc file as well, despite the use of the login manager from the install being used.
Secondly I have also added links:
$ sudo ln -s /opt/waterfox/waterfox /usr/local/bin/waterfoxAND
$ sudo ln -s /opt/waterfox/waterfox-bin /usr/local/bin/waterfox-binI don't understand why it was necessary for a portable app, when it isn't necessary with a .deb program, both installed in the /opt directory.
At least now, waterfox appears in the <ALT> + <F2> LXDE run menu.
The next step will be installing spectrwm and notion to see if waterfox can be run from dmenu in spectrwm and the run menu in notion. I will post again, when I know if this issue is solved or not.
You may want to check that the waterfox* files are executable the latest download of them did not have the executable set for me causing my .desktop file I made to fail when trying to start it. The -bin I did not use still does not have it set as I only put it on the waterfox itself.
zeus@9600k:~$ ls -l bin/waterfox/waterfox*
772 -rwxr-xr-x 1 zeus zeus 790352 Jan 11 07:09 bin/waterfox/waterfox*
772 -rw-r--r-- 1 zeus zeus 790352 Jan 11 07:09 bin/waterfox/waterfox-bin
4 -rw-r--r-- 1 zeus zeus 1350 Jan 11 07:09 bin/waterfox/waterfox-bin.sig
4 -rw-r--r-- 1 zeus zeus 1350 Jan 11 07:09 bin/waterfox/waterfox.sigEdit: And if you want to make certain all of the AI trash is disabled then this snippet from my install notes can help do that for you.
Locked and disabled the AI garbage on both Waterfox and Firefox with the settings in this article.
https://yano.me/2025/10/locking-preferences-disable-ai-firefox/
zeus@9600k:~$ nano bin/waterfox/defaults/pref/local-settings.js
zeus@9600k:~$ cp bin/waterfox/defaults/pref/local-settings.js bin/firefox/defaults/pref/local-settings.js
zeus@9600k:~$ nano bin/waterfox/mozilla.cfg
zeus@9600k:~$ cp bin/waterfox/mozilla.cfg bin/firefox/mozilla.cfgLast edited by RedGreen925 (2026-01-15 17:05:48)
Thanks. Part of my diagnostic process was exactly to make sure that both waterfox and waterfox-bin were executable. Good to see the info for disabling the AI hoi polloi.
Waterfox was acquired in 2020 by Privacy One Group Ltd - the company who also acquired Startpage. That company was a subsidiary of ad company System1... Waterfox was divested three years later, but mud sticks. Personally I don't trust supposed "privacy" focused projects, or their developers, who sell out to advertising companies. There are more than a few articles out there related to this.
but mud sticks.
Especially when the trolls continue to spread the FUD show me one company out there who does not do it. The devs say this relationship is over, as you admit, but the FUD spreaders continue like they always do in their never ending quest to keep the hate going.
@devuan_dk_fan: With "/opt" in $PATH one would expect to find some binaries in "/opt" such as for instance "/opt/binary1" and "/opt/binary2" ... but you seem to expect something else?
Did you ever look into what $PATH is, and how it isused? You find $PATH in many operating systems (although some will name it %PATH% instead). All in all it's part of the magic of running programs without naming them by absolute pathname, but merely naming them with relative path.
Like, with your "/opt" setting, you could type "waterfox/waterfox-bin" as a command to run the binary linked as "waterfox-bin" in the directory "waterfox/" relative to some direcotry in $PATH (namely "/opt").
Perhaps I wasn't clear? I was surprised that despite two programs residing in the /opt directory (simplenote and waterfox) only the one installed as a .deb package (simplenote) showed up in the $PATH. It was necessary to simlink the other (waterfox and waterfox-bin) to /usr/local/bin/ before it appeared in the $PATH. I don't believe that is normally necessary if both reside in the !modified $PATH... /opt
You may need to explicitly add waterfox to the path ?
export PATH=$PATH:/opt/waterfoxLast edited by HardSun (2026-01-16 01:29:10)
Just in regards to simplenote, as its not an official package its hard to determine what is going on there.
I am fairly certain if you run below command on simplenote it should give you a clue to how it starts, my guess is it has a symlink to /usr/bin or similar.
whereis simplenoteLast edited by HardSun (2026-01-16 07:37:47)
I tried
export PATH=$PATH:/opt/waterfoxwith a previous install (Watt OS - Debian 12) and it didn't work either.
$ whereis simplenote
simplenote: /usr/bin/simplenoteWow, you are right.
Hello @RedGreen,
He sold out to a US based ad company, despite all the previous privacy claims. It's not about "hate", that's an oversimplification. I have nothing against him or the project, but if one markets a product on privacy claims, then sells said project to an ad company - I am going to not consider / reconsider using it. If you read his public statement at the time of the sale, it's not at all convincing. System1 registered the Privacy One company for the purpose of acquiring Waterfox and Startpage. The intent there was to hide / obscure the acquisition by System1, a fairly common business practice. It's easy to see why it became independent again - it was a bad move to start with. That's all, I'm not going to further derail the thread...
I tried
HardSun wrote:export PATH=$PATH:/opt/waterfoxwith a previous install (Watt OS - Debian 12) and it didn't work either.
Maybe a symlink is needed? Mozilla's method for manual installation to /opt/ recommends a symlink.
Create a symlink to the Firefox executable:
ln -s /opt/firefox/firefox /usr/local/bin/firefox See link, go down to
Install Firefox from Mozilla builds
Something else just came to mind, is your ~/.bash_profile being sourced correctly?
what does below command say?
shopt login_shellLast edited by HardSun (2026-01-16 09:38:48)
I think you will need to export $PATH in ~/.profile instead. I'm sure ~/.bash_profile is only for login shells.
"It's easy to see why it became independent again - it was a bad move to start with."
Did not stop you from spreading the trash you did though did it, so tell your lie about not spreading the hate elsewhere. Now you try to deny it when being called out for it I am not buying it or the not wanting to derail disscussion BS either, you were perfectly happy to do it with your FUD spreading.
So what is the problem with just putting it in a bin directory in your home? That is what I do with all of these things then create the .desktop file pointing to it.
zeus@9600k:~$ cat .local/share/applications/waterfox.desktop
[Desktop Entry]
Version=1.0
Name=Waterfox
Comment=Browse the World Wide Web
Comment[ar]=تصفح الشبكة العنكبوتية العالمية
Comment[ast]=Restola pela Rede
Comment[bn]=ইন্টারনেট ব্রাউজ করুন
Comment[ca]=Navegueu per la web
Comment[cs]=Prohlížení stránek World Wide Webu
Comment[da]=Surf på internettet
Comment[de]=Im Internet surfen
Comment[el]=Μπορείτε να περιηγηθείτε στο διαδίκτυο (Web)
Comment[es]=Navegue por la web
Comment[et]=Lehitse veebi
Comment[fa]=صفحات شبکه جهانی اینترنت را مرور نمایید
Comment[fi]=Selaa Internetin WWW-sivuja
Comment[fr]=Naviguer sur le Web
Comment[gl]=Navegar pola rede
Comment[he]=גלישה ברחבי האינטרנט
Comment[hr]=Pretražite web
Comment[hu]=A világháló böngészése
Comment[it]=Esplora il web
Comment[ja]=ウェブを閲覧します
Comment[ko]=웹을 돌아 다닙니다
Comment[ku]=Li torê bigere
Comment[lt]=Naršykite internete
Comment[nb]=Surf på nettet
Comment[nl]=Verken het internet
Comment[nn]=Surf på nettet
Comment[no]=Surf på nettet
Comment[pl]=Przeglądaj strony WWW
Comment[pt]=Explorar a Internet com o Waterfox
Comment[pt_BR]=Navegue na Internet
Comment[ro]=Navigați pe Internet
Comment[ru]=Доступ в Интернет
Comment[sk]=Prehliadanie internetu
Comment[sl]=Brskajte po spletu
Comment[sv]=Surfa på webben
Comment[tr]=İnternet'te Gezinin
Comment[ug]=دۇنيادىكى توربەتلەرنى كۆرگىلى بولىدۇ
Comment[uk]=Перегляд сторінок Інтернету
Comment[vi]=Để duyệt các trang web
Comment[zh_CN]=浏览互联网
Comment[zh_TW]=瀏覽網際網路
GenericName=Web Browser
GenericName[ar]=متصفح ويب
GenericName[ast]=Restolador Web
GenericName[bn]=ওয়েব ব্রাউজার
GenericName[ca]=Navegador web
GenericName[cs]=Webový prohlížeč
GenericName[da]=Webbrowser
GenericName[el]=Περιηγητής διαδικτύου
GenericName[es]=Navegador web
GenericName[et]=Veebibrauser
GenericName[fa]=مرورگر اینترنتی
GenericName[fi]=WWW-selain
GenericName[fr]=Navigateur Web
GenericName[gl]=Navegador Web
GenericName[he]=דפדפן אינטרנט
GenericName[hr]=Web preglednik
GenericName[hu]=Webböngésző
GenericName[it]=Browser web
GenericName[ja]=ウェブ・ブラウザ
GenericName[ko]=웹 브라우저
GenericName[ku]=Geroka torê
GenericName[lt]=Interneto naršyklė
GenericName[nb]=Nettleser
GenericName[nl]=Webbrowser
GenericName[nn]=Nettlesar
GenericName[no]=Nettleser
GenericName[pl]=Przeglądarka WWW
GenericName[pt]=Navegador web
GenericName[pt_BR]=Navegador Web
GenericName[ro]=Navigator Internet
GenericName[ru]=Веб-браузер
GenericName[sk]=Internetový prehliadač
GenericName[sl]=Spletni brskalnik
GenericName[sv]=Webbläsare
GenericName[tr]=Web Tarayıcı
GenericName[ug]=توركۆرگۈ
GenericName[uk]=Веб-браузер
GenericName[vi]=Trình duyệt Web
GenericName[zh_CN]=网络浏览器
GenericName[zh_TW]=網路瀏覽器
Keywords=Internet;WWW;Browser;Web;Explorer;
Keywords[ar]=انترنت;إنترنت;متصفح;ويب;وب;
Keywords[ast]=Internet;WWW;Restolador;Web;Esplorador;
Keywords[ca]=Internet;WWW;Navegador;Web;Explorador;Explorer;
Keywords[cs]=Internet;WWW;Prohlížeč;Web;Explorer;
Keywords[da]=Internet;Internettet;WWW;Browser;Browse;Web;Surf;Nettet;
Keywords[de]=Internet;WWW;Browser;Web;Explorer;Webseite;Site;surfen;online;browsen;
Keywords[el]=Internet;WWW;Browser;Web;Explorer;Διαδίκτυο;Περιηγητής;Waterfox;Φιρεφοχ;Ιντερνετ;
Keywords[es]=Explorador;Internet;WWW;
Keywords[fi]=Internet;WWW;Browser;Web;Explorer;selain;Internet-selain;internetselain;verkkoselain;netti;surffaa;
Keywords[fr]=Internet;WWW;Browser;Web;Explorer;Fureteur;Surfer;Navigateur;
Keywords[he]=דפדפן;אינטרנט;רשת;אתרים;אתר;פיירפוקס;מוזילה;
Keywords[hr]=Internet;WWW;preglednik;Web;
Keywords[hu]=Internet;WWW;Böngésző;Web;Háló;Net;Explorer;
Keywords[it]=Internet;WWW;Browser;Web;Navigatore;
Keywords[is]=Internet;WWW;Vafri;Vefur;Netvafri;Flakk;
Keywords[ja]=Internet;WWW;Web;インターネット;ブラウザ;ウェブ;エクスプローラ;
Keywords[nb]=Internett;WWW;Nettleser;Explorer;Web;Browser;Nettside;
Keywords[nl]=Internet;WWW;Browser;Web;Explorer;Verkenner;Website;Surfen;Online;
Keywords[pl]=Internet;WWW;Przeglądarka;Sieć;Surfowanie;Strona internetowa;Strona;Przeglądanie;
Keywords[pt]=Internet;WWW;Browser;Web;Explorador;Navegador;
Keywords[pt_BR]=Internet;WWW;Browser;Web;Explorador;Navegador;
Keywords[ru]=Internet;WWW;Browser;Web;Explorer;интернет;браузер;веб;файрфокс;огнелис;
Keywords[sk]=Internet;WWW;Prehliadač;Web;Explorer;
Keywords[sl]=Internet;WWW;Browser;Web;Explorer;Brskalnik;Splet;
Keywords[tr]=İnternet;WWW;Tarayıcı;Web;Gezgin;Web sitesi;Site;sörf;çevrimiçi;tara;
Keywords[uk]=Internet;WWW;Browser;Web;Explorer;Інтернет;мережа;переглядач;оглядач;браузер;веб;файрфокс;вогнелис;перегляд;
Keywords[vi]=Internet;WWW;Browser;Web;Explorer;Trình duyệt;Trang web;
Keywords[zh_CN]=Internet;WWW;Browser;Web;Explorer;网页;浏览;上网;水狐;Waterfox;wf;互联网;网站;
Keywords[zh_TW]=Internet;WWW;Browser;Web;Explorer;網際網路;網路;瀏覽器;上網;網頁;水狐;
Exec=/home/zeus/bin/waterfox/waterfox %u
Terminal=false
X-MuiltpleArgs=false
Type=Application
Icon=/home/zeus/.local/share/plasma_icons/waterfox.ico
Categories=Network;WebBrowser;
Keywords=web;browser;internet;
MimeType=text/html;text/xml;application/xhtml+xml;application/xml;application/rss+xml;application/rdf+xml;image/gif;image/jpeg;image/png;x-scheme-handler/http;x-scheme-handler/https;x-scheme-handler/ftp;x-scheme-handler/chrome;video/webm;application/x-xpinstall;
StartupNotify=true
Actions=NewWindow;NewPrivateWindow;ProfileManagerWindow;
StartupWMClass=waterfox
[Desktop Action NewWindow]
Name=Open a New Window
Name[ach]=Dirica manyen
Name[af]=Nuwe venster
Name[an]=Nueva finestra
Name[ar]=نافذة جديدة
Name[as]=নতুন উইন্ডো
Name[ast]=Ventana nueva
Name[az]=Yeni Pəncərə
Name[be]=Новае акно
Name[bg]=Нов прозорец
Name[bn_BD]=নতুন উইন্ডো (N)
Name[bn_IN]=নতুন উইন্ডো
Name[br]=Prenestr nevez
Name[brx]=गोदान उइन्ड'(N)
Name[bs]=Novi prozor
Name[ca]=Finestra nova
Name[cak]=K'ak'a' tzuwäch
Name[cs]=Nové okno
Name[cy]=Ffenestr Newydd
Name[da]=Nyt vindue
Name[de]=Neues Fenster
Name[dsb]=Nowe wokno
Name[el]=Νέο παράθυρο
Name[en_GB]=New Window
Name[en_US]=New Window
Name[en_ZA]=New Window
Name[eo]=Nova fenestro
Name[es_AR]=Nueva ventana
Name[es_CL]=Nueva ventana
Name[es_ES]=Nueva ventana
Name[es_MX]=Nueva ventana
Name[et]=Uus aken
Name[eu]=Leiho berria
Name[fa]=پنجره جدید
Name[ff]=Henorde Hesere
Name[fi]=Uusi ikkuna
Name[fr]=Nouvelle fenêtre
Name[fy_NL]=Nij finster
Name[ga_IE]=Fuinneog Nua
Name[gd]=Uinneag ùr
Name[gl]=Nova xanela
Name[gn]=Ovetã pyahu
Name[gu_IN]=નવી વિન્ડો
Name[he]=חלון חדש
Name[hi_IN]=नया विंडो
Name[hr]=Novi prozor
Name[hsb]=Nowe wokno
Name[hu]=Új ablak
Name[hy_AM]=Նոր Պատուհան
Name[id]=Jendela Baru
Name[is]=Nýr gluggi
Name[it]=Nuova finestra
Name[ja]=新しいウィンドウ
Name[ja_JP-mac]=新規ウインドウ
Name[ka]=ახალი ფანჯარა
Name[kk]=Жаңа терезе
Name[km]=បង្អួចថ្មី
Name[kn]=ಹೊಸ ಕಿಟಕಿ
Name[ko]=새 창
Name[kok]=नवें जनेल
Name[ks]=نئئ وِنڈو
Name[lij]=Neuvo barcon
Name[lo]=ຫນ້າຕ່າງໃຫມ່
Name[lt]=Naujas langas
Name[ltg]=Jauns lūgs
Name[lv]=Jauns logs
Name[mai]=नव विंडो
Name[mk]=Нов прозорец
Name[ml]=പുതിയ ജാലകം
Name[mr]=नवीन पटल
Name[ms]=Tetingkap Baru
Name[my]=ဝင်းဒိုးအသစ်
Name[nb_NO]=Nytt vindu
Name[ne_NP]=नयाँ सञ्झ्याल
Name[nl]=Nieuw venster
Name[nn_NO]=Nytt vindauge
Name[or]=ନୂତନ ୱିଣ୍ଡୋ
Name[pa_IN]=ਨਵੀਂ ਵਿੰਡੋ
Name[pl]=Nowe okno
Name[pt_BR]=Nova janela
Name[pt_PT]=Nova janela
Name[rm]=Nova fanestra
Name[ro]=Fereastră nouă
Name[ru]=Новое окно
Name[sat]=नावा विंडो (N)
Name[si]=නව කවුළුවක්
Name[sk]=Nové okno
Name[sl]=Novo okno
Name[son]=Zanfun taaga
Name[sq]=Dritare e Re
Name[sr]=Нови прозор
Name[sv_SE]=Nytt fönster
Name[ta]=புதிய சாளரம்
Name[te]=కొత్త విండో
Name[th]=หน้าต่างใหม่
Name[tr]=Yeni pencere
Name[tsz]=Eraatarakua jimpani
Name[uk]=Нове вікно
Name[ur]=نیا دریچہ
Name[uz]=Yangi oyna
Name[vi]=Cửa sổ mới
Name[wo]=Palanteer bu bees
Name[xh]=Ifestile entsha
Name[zh_CN]=新建窗口
Name[zh_TW]=開新視窗
Exec=waterfox --new-window
[Desktop Action NewPrivateWindow]
Name=Open a New Private Window
Name[ach]=Dirica manyen me mung
Name[af]=Nuwe privaatvenster
Name[an]=Nueva finestra privada
Name[ar]=نافذة خاصة جديدة
Name[as]=নতুন ব্যক্তিগত উইন্ডো
Name[ast]=Ventana privada nueva
Name[az]=Yeni Məxfi Pəncərə
Name[be]=Новае акно адасаблення
Name[bg]=Нов прозорец за поверително сърфиране
Name[bn_BD]=নতুন ব্যক্তিগত উইন্ডো
Name[bn_IN]=নতুন ব্যক্তিগত উইন্ডো
Name[br]=Prenestr merdeiñ prevez nevez
Name[brx]=गोदान प्राइभेट उइन्ड'
Name[bs]=Novi privatni prozor
Name[ca]=Finestra privada nova
Name[cak]=K'ak'a' ichinan tzuwäch
Name[cs]=Nové anonymní okno
Name[cy]=Ffenestr Breifat Newydd
Name[da]=Nyt privat vindue
Name[de]=Neues privates Fenster
Name[dsb]=Nowe priwatne wokno
Name[el]=Νέο παράθυρο ιδιωτικής περιήγησης
Name[en_GB]=New Private Window
Name[en_US]=New Private Window
Name[en_ZA]=New Private Window
Name[eo]=Nova privata fenestro
Name[es_AR]=Nueva ventana privada
Name[es_CL]=Nueva ventana privada
Name[es_ES]=Nueva ventana privada
Name[es_MX]=Nueva ventana privada
Name[et]=Uus privaatne aken
Name[eu]=Leiho pribatu berria
Name[fa]=پنجره ناشناس جدید
Name[ff]=Henorde Suturo Hesere
Name[fi]=Uusi yksityinen ikkuna
Name[fr]=Nouvelle fenêtre de navigation privée
Name[fy_NL]=Nij priveefinster
Name[ga_IE]=Fuinneog Nua Phríobháideach
Name[gd]=Uinneag phrìobhaideach ùr
Name[gl]=Nova xanela privada
Name[gn]=Ovetã ñemi pyahu
Name[gu_IN]=નવી ખાનગી વિન્ડો
Name[he]=חלון פרטי חדש
Name[hi_IN]=नयी निजी विंडो
Name[hr]=Novi privatni prozor
Name[hsb]=Nowe priwatne wokno
Name[hu]=Új privát ablak
Name[hy_AM]=Սկսել Գաղտնի դիտարկում
Name[id]=Jendela Mode Pribadi Baru
Name[is]=Nýr huliðsgluggi
Name[it]=Nuova finestra anonima
Name[ja]=新しいプライベートウィンドウ
Name[ja_JP-mac]=新規プライベートウインドウ
Name[ka]=ახალი პირადი ფანჯარა
Name[kk]=Жаңа жекелік терезе
Name[km]=បង្អួចឯកជនថ្មី
Name[kn]=ಹೊಸ ಖಾಸಗಿ ಕಿಟಕಿ
Name[ko]=새 사생활 보호 모드
Name[kok]=नवो खाजगी विंडो
Name[ks]=نْو پرایوٹ وینڈو&
Name[lij]=Neuvo barcon privou
Name[lo]=ເປີດຫນ້າຕ່າງສວນຕົວຂື້ນມາໃຫມ່
Name[lt]=Naujas privataus naršymo langas
Name[ltg]=Jauns privatais lūgs
Name[lv]=Jauns privātais logs
Name[mai]=नया निज विंडो (W)
Name[mk]=Нов приватен прозорец
Name[ml]=പുതിയ സ്വകാര്യ ജാലകം
Name[mr]=नवीन वैयक्तिक पटल
Name[ms]=Tetingkap Persendirian Baharu
Name[my]=New Private Window
Name[nb_NO]=Nytt privat vindu
Name[ne_NP]=नयाँ निजी सञ्झ्याल
Name[nl]=Nieuw privévenster
Name[nn_NO]=Nytt privat vindauge
Name[or]=ନୂତନ ବ୍ୟକ୍ତିଗତ ୱିଣ୍ଡୋ
Name[pa_IN]=ਨਵੀਂ ਪ੍ਰਾਈਵੇਟ ਵਿੰਡੋ
Name[pl]=Nowe okno prywatne
Name[pt_BR]=Nova janela privativa
Name[pt_PT]=Nova janela privada
Name[rm]=Nova fanestra privata
Name[ro]=Fereastră privată nouă
Name[ru]=Новое приватное окно
Name[sat]=नावा निजेराक् विंडो (W )
Name[si]=නව පුද්ගලික කවුළුව (W)
Name[sk]=Nové okno v režime Súkromné prehliadanie
Name[sl]=Novo zasebno okno
Name[son]=Sutura zanfun taaga
Name[sq]=Dritare e Re Private
Name[sr]=Нови приватан прозор
Name[sv_SE]=Nytt privat fönster
Name[ta]=புதிய தனிப்பட்ட சாளரம்
Name[te]=కొత్త ఆంతరంగిక విండో
Name[th]=หน้าต่างส่วนตัวใหม่
Name[tr]=Yeni gizli pencere
Name[tsz]=Juchiiti eraatarakua jimpani
Name[uk]=Приватне вікно
Name[ur]=نیا نجی دریچہ
Name[uz]=Yangi maxfiy oyna
Name[vi]=Cửa sổ riêng tư mới
Name[wo]=Panlanteeru biir bu bees
Name[xh]=Ifestile yangasese entsha
Name[zh_CN]=新建隐私浏览窗口
Name[zh_TW]=新增隱私視窗
Exec=waterfox --private-window
[Desktop Action ProfileManagerWindow]
Name=Open the Profile Manager
Name[cs]=Správa profilů
Name[en_GB]=Profile Manager
Name[en_US]=Profile Manager
Name[pl]=Menedżer Profili
Exec=waterfox --ProfileManagerIt is rather large as the file I got from the .deb I found had all those languages enabled and got the icon file from a reddit posting.
https://software.opensuse.org//download … e=waterfox
https://www.reddit.com/r/waterfox/comme … _waterfox/
Now this works for me in KDE if the desktop you use does not respect the XDG specification for these things I have no clue how to do it so it works.
@RedGreen925, you're coming across as a foaming at the mouth, emotionally driven, web browser fanboi, and thus leading me to conclude that you're not worth debating with. I have come across this before, where fans of $PROJECT get personally offended if their top favourite software is criticised. That's you.
I posted the facts about Waterfox's acquistion by System1 and it's spinning off as an independent browser three years later. I added my thoughts, to the effect that I wouldn't trust it. If you do, that's up to you. You got offended.
Now you just stop with that sensible talk, we're trying to do things the hard way here. ![]()
Devuan 5 mate-mini iso, pure Devuan, 100% no-vuu-do.
Devuan 6 version also available for testing.
Pages: 1
