Pages: 1
Hi there,
I used Debian debootstrap to install Chimaera and Excalibur in directories.
Chimaera works well.
However, Excalibur failed to finalize installation dispute the similar environment.
1 Chimaera
1.1
Download http://deb.devuan.org/devuan/pool/main/ … n1_all.deb
copy file "ceres" to /usr/share/debootstrap/scripts/ as "ceres-devuan"
make the soft links @chimaera @excalibur for "ceres-devuan"
1.2
#sudo debootstrap --include "bash,zsh,wpasupplicant,locales,grub2,wget,curl,dhcpcd5" --arch amd64 chimaera /chroot/chimaera http://deb.devuan.org/merged/ chimaera
Base system installed successfully.
Now I can run
sudo chroot /chroot/chimaera /bin/su -l
It works well.
2 Excalibur
The same soft links @chimaera @excalibur for "ceres-devuan".
#sudo debootstrap --include "bash,zsh,wpasupplicant,locales,grub2,wget,curl,dhcpcd5" --arch amd64 excalibur /chroot/excalibur http://deb.devuan.org/merged/ excalibur
I: Extracting util-linux...
I: Extracting zlib1g...
At this point it suddenly stop.
No errors, but no complete installation neither.
Best regards
You have to exclude a few things and then you can add them later.
https://dev1galaxy.org/viewtopic.php?pid=47276#p47276
It doesn't work from Debian Bullseye.
(I doubt if "--exclude" works on Debian correctly nowadays.)
However, it's possible to debootstrap Chimaera first
and then debootstrap Excalibur from inside chroot Chimaera.
No "--exclude" needed:
#debootstrap --arch amd64 excalibur /loc_chroot/excalibur http://deb.devuan.org/merged/ excalibur
Works fine and the result can be moved back to the Debian host.
If you're installing Devuan from Debian (or the other way around) I would recommend using the --foreign/--second-stage method. This has worked for me in the past, when the standard single-stage method didn't.
#sudo debootstrap --foreign --arch amd64 excalibur /loc_chroot/excalibur http://deb.devuan.org/merged/ excalibur
(the same incomplete installation)
2
As I mention in my previous post - Chimaera first and Excalibur from inside Chimaera - works.
Talking about debugging - Chimaera works and Excalibur is not. So, the issue not on the Debian side but Devuan,
Perhaps you could show the tail end of the debootstrap.log file, for the failing case.
#sudo debootstrap --merged-usr --arch amd64 excalibur /loc_chroot/excalibur http://deb.devuan.org/merged/ excalibur
2025-11-28 19:32:34 URL:http://deb.devuan.org/merged/pool/DEBIAN/main/v/vim/vim-tiny_9.1.1230-2_amd64.deb [775840/775840] -> "/loc_chroot/excalibur//var/cache/apt/archives/partial/vim-tiny_2%3a9
2025-11-28 19:32:35 URL:http://deb.debian.org/debian/pool/main/n/newt/whiptail_0.52.25-1_amd64.deb [24712/24712] -> "/loc_chroot/excalibur//var/cache/apt/archives/partial/whiptail_0.52.25-1_amd6
2025-11-28 19:32:36 URL:http://deb.debian.org/debian/pool/main/z/zlib/zlib1g_1.3.dfsg+really1.3.1-1+b1_amd64.deb [88892/88892] -> "//loc_chroot/excalibur//var/cache/apt/archives/partial/zlib1g_1%
amd64: ok
/usr/share/debootstrap/scripts/excalibur: line 26: [: -eq: unary operator expected
amd64: ok
/usr/share/debootstrap/scripts/excalibur: line 116: merge_usr: command not found2
#sudo debootstrap --no-merged-usr --arch amd64 excalibur /loc_chroot/excalibur http://deb.devuan.org/merged/ excalibur
E: Unmerged /usr is not compatible with excalibur3
no longer available
4.1
http://deb.devuan.org/packages/merged/d … ackages.gz
has no "merge_usr"
4.2
Package: base-files
Version: 13.8+deb13u2devuan1
Essential: yes
Installed-Size: 390
Maintainer: Devuan Developers <devuan-dev@lists.dyne.org>
Architecture: amd64
Replaces: base, dpkg (<= 1.15.0), miscutils
Provides: base, usr-is-merged#sudo debootstrap --include=base-files --arch amd64 excalibur /loc_chroot/excalibur http://deb.devuan.org/merged/ excalibur
I: Extracting zlib1g.../loc_chroot/excalibur/debootstrap/debootstrap.log
/usr/share/debootstrap/scripts/excalibur: line 116: merge_usr: command not foundLast edited by U25 (2025-11-30 11:30:25)
1. please use code block markup for code blocks.
2. what do all those mean? same use case or different use case? successful or failing?
1. code blocks added.
2. same use case, same result:
Debian Bullseye host.
Debootstrap Chimaera works.
Debootstrap Excalibur failed ("merge_usr: command not found")
Which deboostrap version are you using?
EDIT: the reason I'm asking is because "merge_usr" is defined in the "functions" that come with the debootstrap installation, since excalibur.
debootstrap 1.0.123+deb11u1
Right. That's wrong for debootstrapping Devuan. You need to use Devuan's debootstrap for that.
Where did you get that "excalibur" script from?
I mentioned it in the very first post.
Again, Chimaera works well this way. Excalibur failed.
You wish Devuan developers to debug Debian's debootstrap?
Pages: 1
