#1 2025-11-24 12:46:27
https_force
How to use the Init system?
When I install a new distro I typically run 'sudo lsof -i' to see what is [Listening] and work to remove any potentially vulnerable network aware applications.
I'm struggling to learn how the init system works. A small guide on how to use the Devuan init for managing daemons would be nice for the following actions:
Do I need to know about runlevels for daemons?
How to Start a service:
How to stop a service:
How to disable a service:
How to enable a service:
What is the correct procedure to follow before 'sudo apt remove <package>' that also has a service module?
#2 2025-11-24 15:07:28
RedGreen925
Re: How to use the Init system?
The runlevels will be in the file that controls the daemon in the /etc/init.d/ directory,
sudo /etc/init.d/service start
sudo /etc/init.d/service stop
sudo update-rc.d service remove
sudo update-rc.d service defaults
Those would be the answers to your next four questions usually you can find the options used with /etc/init.d/service by reading the plain text file it is to see what is available in it. Most times there is a restart option and some of the time a force-reload that can be used as well.
Apt will shut down the service before/during removal as I remember it as never having to do anything special when I have done it, using the --purge option with it when removing will get rid of all of the configuration files installed by the package as well.
#3 2025-11-24 21:31:26
Old but still useful -
https://refracta.org/docs/debian-handbook-wheezy.pdf
Last Debian Administrator's Handbook before systemd.
#4 2025-11-24 23:59:45
Devarch
Yep, most people here do not like to use ai too much ... but ... you can try to ask ai to get some answers.
#5 2025-11-28 13:38:59
unixuser
@fsmithred
Thank you, very nice find
#6 2025-11-29 23:08:48
I often do this when tidying up the start process... for services I use and not everything available, especially for accessability services.
rc-update del sudo default
rc-update add sudo off
rc-update add ssh off
rc-update del ssh default
rc-update del saned default
rc-update add saned off
rc-update add nethack-common off
rc-update del nethack-common default
rc-update del fetchmail default
rc-update add fetchmail off
rc-update add exim4 off
rc-update del exim4 default
.... (plus a whole lot more where I profer to start them myself when required.)
If you type rc-update you'll get a complete list for your system. (I'm using open-rc)
#7 2025-11-29 23:21:21
EDX-0
if ya miss the systemctl heuristics there's this script i call initctl which wraps update-rc.d(8) and service(8) in a familiar way while ya learn the ropes of using those commands.
https://github.com/eylles/devuan-script … er/initctl
#8 2025-11-30 07:15:18
sysv-rc-conf
isn't bad either.
#9 2025-11-30 11:48:31
kapqa
maybe we can simulate this init start thing?
would like to start this program boinc "automatically" at startup.
https://boinc.berkeley.edu/wiki/Stop_or … after_boot
thank you very much.
https://github.com/BOINC/boinc/wiki/Sto … after_boot
