#1 2025-11-24 08:21:24
HardSun
Grub Error / Upgrade to Excalibur
Upgraded Daedalus to Excalibur today.
Not sure why this is happening or how i managed to resolve it but the new grub default update puts my machine into a boot loop with a black screen.
Specifically the line in /etc/default/grub
GRUB_DISTRIBUTOR=`( . /etc/os-release && echo ${NAME} )`
Its output...
echo `( . /etc/os-release && echo ${NAME} )`
Devuan GNU/Linux
The fix was to revert it back to lsb-release, devuan excalibur now boots correctly.
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
Its output...
echo `lsb_release -i -s 2> /dev/null || echo Debian`
Devuan
Why would this happen?
Anyone experience this?
#2 2025-12-01 03:43:11
oleg
Re: Grub Error / Upgrade to Excalibur
I'm not sure if this applies to your case, but I also had a black screen due to an unmounted EFI partition.
It was a message that system may no boot:
Setting up grub-efi-amd64 (2.12-9) ...
Installing for x86_64-efi platform.
grub-install: error: cannot find EFI directory.
Failed: grub-install --target=x86_64-efi
WARNING: Bootloader is not properly installed, system may not be bootable
Generating grub configuration file ...
I used https://www.system-rescue.org/Installin … ory-stick/ that able to boot system with wrong efi, then mount
mount /dev/sda? /boot/efi
and ran update-grub
I.e., before the final step of the system installation, one should check  whether efi is mounted.
#3 2025-12-01 04:44:49
HardSun
No it doesn't apply to my case.
If you were installing what devuan install media were you using?
#4 2025-12-01 05:00:25
oleg
I upgraded Daedalus to Excalibur through Internet.
It was working system though efi not was mounted, as now too.
#5 2025-12-01 05:10:01
HardSun
Are you dual or multi booting different linux systems?
It sounds like you may have had the efi mounted to the wrong partition?
My /boot/efi partition was definitely mounted, i was able to chroot into it the upgraded devuan from a live usb and correct the GRUB_DISTRIBUTOR line in
/etc/default/grub and that fixed it. That was the first thing i checked as i was getting a partial grub loading screen and then blackness, then boot loop.
#6 2025-12-01 05:30:20
oleg
Bios finds efi even it's not mounted and probably passes where it is to Linux, but grub installer not take the info into account.
I have the only linux system.
#7 2025-12-01 05:44:26
HardSun
Its either human error or a grub bug im not sure.
Most likely my human error knowing my inexperience wink
Glad you got it fixed oleg.
#8 2025-12-01 06:30:00
wert
Dont put a little bit  more complex "shell snytax"   into that field.
Grub may not have full blown shell snytax parser.
And because it is fragile.
wrt your case: try remove that parenthesis. replace backtits with $( )  proper.
Maybe scope of $NAME problem.
#9 2025-12-01 11:36:03
oleg
I found the apt log in /var/log/apt in a compressed file called term.log.1.gz. It can show what happened while grub-install (or update) was running.
#10 2025-12-01 13:20:59
mostly for future forum visitors looking/searching the term "grub"
advisement from the beginning of the file /etc/default/grub:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
and especially noting the encouragement to visit:
even better, the whole thing:
info -f grub
as always, ymmv.
