#1 2025-11-08 23:35:03
AlThePal
Running QEMU/KVM with runit
I have converted my Excalibur installation to use runit. This seems to be working well, but I can't get QEMU/KVM to run - I normally use Virtual Machine Manager.
When I try to install libvirt-daemon-driver-qemu it complains:
Solving dependencies... Error!
Unsatisfied dependencies:
 runit-init : Conflicts: sysvinit-core but 3.14-4devuan1 is to be installed
 sysvinit-core : Conflicts: runit-init but 2.2.0-3 is to be installed
Error: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Error: The following information from --solver 3.0 may provide additional context:
   Unable to satisfy dependencies. Reached two conflicting decisions:
   1. sysvinit-core:amd64 is not selected for install because:
      1. runit-init:amd64 is selected for install
      2. runit-init:amd64 is available in version 2.2.0-3
      3. sysvinit-core:amd64 Conflicts runit-init
   2. sysvinit-core:amd64 is selected for install because:
      1. libvirt-daemon-driver-qemu:amd64=11.3.0-3devuan1 is selected for install
      2. libvirt-daemon-driver-qemu:amd64 Depends systemd-container | sysvinit-core
Is there any way I can run QEMU/KVM while using runit?
#2 2025-11-09 13:10:54
Re: Running QEMU/KVM with runit
Two things.
1. You can run qemu without libvirt. I have one system with it and one without and I haven't noticed any difference. Maybe I need to do something different to engage libvirt.
2. File a bug report for libvirt on bugs.devuan.org to adjust the dependencies. (assuming it works with runit)
You could test it by unpacking the offending deb package, adjusting the dependencies in debian/control and repacking the deb. Install it and see if it works. I don't recall the commands for unpack/repack, but it should be easy to find.
#3 2025-11-10 07:04:26
was curious...looked...figured i might as well share the link:
https://www.man7.org/linux/man-pages/man1/dpkg-deb.1.html
#4 2026-02-14 20:17:03
Lorenzo
I just filed a bug in Debian (it seems the package is not forked because it's installable with sysvinit-core)
https://bugs.debian.org/cgi-bin/bugrepo … ug=1127985
let's hope that the maintainer accepts my suggestion for a fix
Lorenzo
