#1 2025-11-07 22:18:28
AlThePal
[SOLVED] Moving from sysvinit to runit
What's the easiest way to move from sysvinit to runit on Excalibur?
#2 2025-11-08 01:32:42
Re: [SOLVED] Moving from sysvinit to runit
apt install runit-init runit-services
reboot
Note: If you installed from a live iso and want to make a new live iso from your system, add live-config-runit to the list of packages to install.
#3 2025-11-08 19:56:37
AlThePal
Thanks for your help!
