#1 2017-06-25 13:19:29
spartrekus
Important failure installation of ASCII using standard Deboostrap.
Hello,
I have installed many times DEVUAN with the following command:
 /usr/sbin/debootstrap --no-check-gpg --include=wpasupplicant    --arch i386 jessie  /target http://auto.mirror.devuan.org/merged/
It is so far impossible to install ASCII with the same method, why? It is not working, shall it work?
 /usr/sbin/debootstrap --no-check-gpg --include=wpasupplicant  --arch i386 ascii  /target http://auto.mirror.devuan.org/merged/
Debootstrap for Debian works, so it shall too for Devuan?
gives:
I: Configuring wpasupplicant...
I: Configuring wget...
I: Configuring tasksel...
I: Configuring tasksel-data...
I: Configuring libc-bin...
W: Failure while configuring base packages.  This will be re-attempted up to five times.
W: See /target/debootstrap/debootstrap.log for details (possibly the package rsyslog is at fault)
#2 2017-06-25 14:20:21
Re: Important failure installation of ASCII using standard Deboostrap.
Error message says "possibly" but there's no doubt about it. You need to exclude rsyslog and include either syslog-ng or busybox-syslogd. When rsyslog for ascii is ready, you can switch back to it. It's also possible to add rsyslog from jessie-backports after the install. I know that works, but I don't know if there are any problems with it. (Tested minimally by me, once.)
You might need to exclude alsa-base, too. There is no such package in ascii.
#3 2017-06-25 14:23:06
spartrekus
here it works on JESSIE !!
I: Configuring apt-utils...
I: Configuring libirs-export91...
I: Configuring libgnutls-openssl27:i386...
I: Configuring iputils-ping...
I: Configuring isc-dhcp-common...
I: Configuring isc-dhcp-client...
I: Base system installed successfully.
Here it does NOT work on ASCII
I have nothing to do. I have to mention it to the development team so that they can fix this bug as soon as possible, because no one will be capable to install devuan ascii.
#4 2017-06-25 14:36:46
spartrekus
In progress. seeems ok!
/usr/sbin/debootstrap --no-check-gpg --exclude=syslog-ng,systemd,busybox-syslogd,rsyslog            --arch i386 ascii  /target http://auto.mirror.devuan.org/merged/
I: Configuring debconf-i18n...
I: Configuring whiptail...
I: Configuring gnupg...
I: Configuring libgnutls30:i386...
#5 2017-06-25 14:44:54
spartrekus
I am now trying with....
/target# /usr/sbin/debootstrap --no-check-gpg --exclude=syslog-ng,systemd,busybox-syslogd,rsyslog            --include=make,wpasupplicant,netbase,login,passwd   --arch i386 ascii  /target http://auto.mirror.devuan.org/merged/
I: Retrieving InRelease
I: Retrieving Packages
I: Validating Packages
#6 2017-06-25 14:47:48
--exclude=rsyslog  --include=<one of the other two sysloggers>
#7 2017-06-25 15:02:26
spartrekus
ok, but ifconfig and netwctl are missing, so I used:
 ip link
and then made sure to have :
auto lo wlp1s0
iface lo inet loopback
iface wlp1s0 inet dhcp
wpa-conf /etc/network/wifi-home.conf
then ifup wlp1s0
#8 2017-06-25 15:12:02
ifconfig is in the net-tools package
If you want wlan0 and eth0 instead of what you have for interface names, add 'net.ifnames=0' to the linux line of your boot menu.
#9 2017-06-25 16:50:49
spartrekus
wlp1s0, wlp2s0, wlan1, and sometimes wlan0,... .very unpredictable depending on the machine...
boot menu, i.e. visible after at /proc/cmdline ?
#10 2017-06-25 17:54:56
Yes. To do it once, press the e key at the boot menu and add it to the linux line.
To make it permanent, add it to the KERNEL_DEFAULT line in /etc/default/grub (where it has "quiet") and then run update-grub.
#11 2017-06-26 04:39:49
spartrekus
grub automatic changes might be dangerous. Long long time I never use it wink
update-grub brrrr
I do not use grub, but I make a boot loader with simple dd and fdisk... you probably never often did that way. It s just faster and more reliable.
ls /devuan-kernel/
boot  modules  network   boatloader.img
I see to past it with:
net.ifnames=0
then, we talk directly to Linus (the kernel).... wink
