#1 2025-11-04 08:47:38
broadcast9133
[SOLVED] Devuan 6 installation on VMware Workstation stuck
Good day all,
I am installing Devuan 6 on VMware Workstation 17.6.3 using the amd64 desktop image and am stuck on the final stage of installation where it says 'Running late-install-stage2' at the 'Finishing the installation stage' stage. Did not encounter any problems until this stage and the previous version, as well as Debian 13, installs fine.
#2 2025-11-04 11:05:55
kapqa
Re: [SOLVED] Devuan 6 installation on VMware Workstation stuck
you could try Vmware Workstation 25h2 if it makes any difference?
had however no luck with Kubuntu 25.10; it would install but then after login, just black screen.
#3 2025-11-04 12:34:58
broadcast9133
Still not working, same with VirtualBox, the live DVD does work though.
#4 2025-11-04 20:25:08
mclien
just to be sure: is that the point where you have to remove the install medium (guess that is to be done in VM/VirtualBox, too.)
#5 2025-11-04 20:59:52
Just performed an expert installation from the released netinstall on a VBox 7.0.26 efi, encrypted with LVM, no issues. After reboot installed Cinnamon via tasksel.
My conclusion: the media as supplied by Devuan seems to be fine. If you are stuck, I would check the checksums of you download first of all. Or there is a problem with your VMWare and/or VBox installation.
#6 2025-11-04 23:26:51
rbit
I did test the desktop dvd with virtualbox (it works there for me) but not vmware.
Is this an online installation, or offline?
When it gets stuck on the late-install-stage2, are you able to press alt-f4 (or alt + right-arrow 3 times) and report back the last few lines of that output for debugging?
#7 2025-11-05 00:23:06
broadcast9133
Tried the netinstall, it got stuck at selecting which kernels to install.
The checksums in all cases do match.
My host is Windows 11 without Hyper-V or Core Isolation enabled
Going to Alt+F4 here is the log:
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/sda2
Nov  5 00:18:27 macosx-prober: debug: /dev/sda2 is not an HFS+ partition: exiting
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/sda2
Nov  5 00:18:27 20microsoft: debug: /dev/sda2 is not a MS partition: exiting
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/sda2
Nov  5 00:18:27 30utility: debug: /dev/sda2 is not a FAT partition: exiting
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/sda2
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/sda2
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/sda2
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/sda2
Nov  5 00:18:27 83haiku: debug: /dev/sda2 is not a BeFS partition: exiting
Nov  5 00:18:27 os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/sda2
Nov  5 00:18:28 os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/sda2
Nov  5 00:18:28 anna-install: Installing rtc-modules
Nov  5 00:18:28 finish-install: unknown udeb rtc-modules
Nov  5 00:18:28 hw-detect: modprobe: FATAL: Module rtc not found in directory /lib/modules/6.12.43+deb13-amd64
Nov  5 00:18:28 clock-setup: rtc module not loaded
Nov  5 00:18:28 hw-detect: modprobe: FATAL: Module rtc-dev not found in directory /lib/modules/6.12.43+deb13-amd64
Nov  5 00:18:28 clock-setup: rtc-dev module not loaded
Nov  5 00:18:29 clock-setup: hwclock: use --verbose, --debug has been deprecated.
Nov  5 00:18:30 finish-install: info: Running /usr/lib/finish-install.d/10open-iscsi
Nov  5 00:18:30 cdrom-detect: Unmounting and ejecting '/dev/sr0'
Nov  5 00:18:30 finish-install: info: Running /usr/lib/finish-install.d/15cdrom-detect
Nov  5 00:18:30 in-target: Reading package lists...
Nov  5 00:18:30 in-target: Building dependency tree...
Nov  5 00:18:30 in-target: Reading state information...
Nov  5 00:18:31 in-target:
Nov  5 00:19:11 init: starting pid 708, tty '/dev/ttg2': '-/bin/sh'
#8 2025-11-05 02:22:46
broadcast9133
After some troubleshooting, turns out it was because of a hung apt process. Forcefully terminating it will technically reboot, but the installed system retains a fake start-stop-daemon. Replacing it from the dpkg package would make it boot normally.
apt-get update
apt-get download dpkg
dpkg-deb -x dpkg_*.deb /root/real
cp -vf /root/real/usr/sbin/start-stop-daemon /usr/sbin/start-stop-daemon
chmod 755 /usr/sbin/start-stop-daemon
dpkg --configure -a
apt-get install --fix-broken
#9 2025-11-07 13:58:47
BlueDev
Can confirm this fix from broadcast9133 also works on Linux host system running libvirt and qemm.
Also, this solution is MUCH APPRECIATED!
#10 2025-11-11 14:27:34
cranium
The fix given above by Broadcast9133 worked for me as it had got stuck at late stage2 message during ithe nstall on virtualbox. Only one thing though. I had to edit the
/etc/apt/sources.list
file to comment out the first line concerning the cdrom fas I had chosen to use a network mirror. Rebooted afterwards and logged into xfce ok.
#11 2025-11-11 17:40:19
BlueDev
To anyone having trouble getting their excalibur to "wake-up" (come out of suspend mode).  This may be helpful:
https://dev1galaxy.org/viewtopic.php?pid=51609#p51609
    Try the following; in /etc/elogind/sleep.conf.d directory create the file 20-suspend.conf with the following contents
    [Sleep]
    SuspendMode=deep
    and reboot.
Can affirm that this fix worked on my virtual machine installation
#12 2025-12-03 04:53:48
rmrichesjr
I just posted a problem similar to the hung late-install-stage2 problem here: https://dev1galaxy.org/viewtopic.php?pid=60342#p60342
