#1 2025-10-31 11:41:19
Obmenu
A long time ago, this thread came to my attention:https://dev1galaxy.org/viewtopic.php?id=4897
MiyoLinux posted this:
... #!++ has repackaged obmenu to work on newer systems using python3.
... downloaded the .deb file from my installation of #!++, and I've installed it on Chimaera, Daedalus, and Ceres...it works perfectly ...
I have a live i386 CBPP / #! *.iso which works perfectly well but I cannot find the *.deb file mentioned by MiyoLinux.
Any idea as to how I can get a hold of it?
I want to test it on a Daedalus VM as a possible transition away from XFCE.
#2 2025-10-31 13:23:17
Re: Obmenu
#3 2025-10-31 15:24:01
Re: Obmenu
ralph.ronnquist wrote:
maybe it's from ...
Yes, I'm quite sure of that as it seems (?) to be of their own production.
And it is part of the #! installation, at least for Bookworm.
But I have not seen it available for download or found it within the live i386 *.iso.
Thanks for your input.
#4 2025-10-31 15:35:43
zephyr
Re: Obmenu
Greetings, using obmenu2 on Crowz, try downloading tarbal and distribute files as needed.
https://github.com/0x10/obmenu2
cheers
zephyr
CROWZ
#5 2025-10-31 15:47:02
Re: Obmenu
There is also : https://github.com/keithbowes/obmenu
Not sure what Miyo meant by downloading a .deb from an install unless the package(s) were saved in the cache. But you could try using dpkg-repack on the #!++ install to re-create a .deb package.
#6 2025-10-31 18:03:44
mweishaar
Re: Obmenu
Might be a longshot, but you could email MiYo through the forum: https://dev1galaxy.org/misc.php?email=952
#7 2025-10-31 18:27:46
Re: Obmenu
zephyr wrote:
... obmenu2 on Crowz, try downloading tarbal ...
greenjeans wrote:
Thanks, saw those already.
But I was wanting to have the #! *.deb file to directly install in my upcoming Daedalus test.
And try it out on my Devuan Chimaera i386 1000HE installation.
greenjeans wrote:
Not sure what Miyo meant by downloading a .deb from an install ...
Hmm ...
Exactly that? Maybe ...
I don't have an installation, just a live i386 *.iso and I haven't seen it there.
#8 2025-10-31 18:40:00
Re: Obmenu
MiyoLinux wrote:
Might be a longshot, but ...
I had thought of doing that but decided not to bother the chap with this.
But seeing that I have not made much progress, I just fired a short one asking.
Hopefully he will pitch in.
#9 2025-11-04 09:01:17
yohno
Re: Obmenu
As far as I remember, Head-on-a-Stick maintained it by some time. He continues to release deadbang iso in sourceforge, by the way. The latest version is 13.1.0 hybrid version of trixie.    yoshi
