#1 2025-10-03 21:48:36
hellomello
[SOLVED] How to report "gpg: BAD signature"
I downloaded the daedalus file devuan_daedalus_5.0.1_amd64_netinstall.iso  from two different servers (https servers) and got a Bad signature both times on the file, but I don't know how to put it into the bug reporting system since there is no package name.  I think the bug report system might just kick it out if I report it without a package name.  Is that correct?  If not what package should I use, or how do I report it?  Thanks.
#2 2025-10-03 23:38:15
Re: [SOLVED] How to report "gpg: BAD signature"
See if this fixes it:
 gpg --keyserver keyserver.ubuntu.com --refresh-keys
#3 2025-10-03 23:40:23
Was that "bad signature" for SHA256SUMS.txt.gpg?
Perhaps you need to refresh your pgp store?
gpg --keyserver keyserver.ubuntu.com --refresh-keys rrq@rrq.au
The sha256sum should be 722af7905595d9a1417f48f783d43dd40fe7da7a2e1d7998a8ea47df2d26941b
otherwise the download had errors.
EDIT: yes, fsmithred beat me to it smile
EDIT 2: concerns with the installers can be reported to the virtual project "devuan-installer"
#4 2025-10-04 00:03:46
hellomello
Thank you for the advice.  I have now followed both steps.
The key refresh for key 680B5A1F661ECDBC showed 'not changed'.
The sha256sum of the ISOs match the checksum (722af7905595d9a1417f48f783d43dd40fe7da7a2e1d7998a8ea47df2d26941b).
Since the file is definitely correct, the 'BAD signature' error (from key 680B5A1F661ECDBC belonging to Ralph Ronnquist) indicates a problem with the signature file itself.
I am happy, because I have my ISO, so I can mark this solved unless you'd rather leave it open or if you want more info.
#5 2025-10-04 00:48:57
Perhaps you have it on a windows filesystem that have added ^M characters to the lines?
#6 2025-10-04 01:10:29
hellomello
Yes, WSL2.  That could be doing it.  Thank you for checking that.
