#1 2025-09-25 19:21:38
Tweedlewise
[SOLVED] Encrypt USB?
Good day!
I have saved ~93 Gb off of my brother's old PC (Win10?) onto a USB SSD.
As he lives in another state, I would like to encrypt the drive before mailing it.
I'm not sure how to do that.  He will need to be able to decrypt it on a Win11 machine.
Is this possible?
I'm thinking of using a password that is familiar to him.
Regards,
Tweedlewise
#2 2025-09-25 19:49:43
Re: [SOLVED] Encrypt USB?
Veracrypt
#3 2025-09-29 02:08:27
Tweedlewise
Thank you Rolfie!
#4 2025-09-29 22:13:38
Tweedlewise
I have downloaded and opened veracrypt.
But as I understand,, I cannot encrypt the contents existing USB drive?
Veracrypt claims it will format the drive, meaning that I will lose all the data on it.
I suppose I could move the data to a hard drive, encrypt the USB, then move the data back?
#5 2025-09-30 07:11:34
PedroReina
Another possibility: compress all the content in a zip file protected with password and copy that file to the USB. I did not test it myself.
#6 2025-09-30 09:37:22
adding a link mostly for future thread visitors:
https://www.howtogeek.com/6169/use-truecrypt-to-secure-your-data/
yes the link says "truecrypt" but the how-to says "veracrypt" ... who knows why? ymmv.
#7 2025-09-30 16:30:16
To my experience, this only works between Linux and Linux, not from Linux to Windows. There is some incompatibility.
#8 2025-09-30 16:31:02
Thats the way to go.
#9 2025-10-02 22:35:44
Tweedlewise
Oh great, I tried to submit a post, but the website logged me out while I was typing it, and now it is gone.,,
Any way, I moved the data off the USB into a folder I made on /home of my PC.
I then ran Veracrypt,  it created a Volume on the USB drive /dev/sde1 (128 GB)
With formatting it took over an hour.
Now I'm having difficulty moving the sub-directory from /home (86.4 Gb) into the volume I created.
While click on "Select File" I then choose the sub-directory  from /home
When I click on "Open File"  it then opens the sub-directory and lists its contents,
Butt All Files doesn't select all (as far as I can tell the button doesn't even work..)
It just wants me to open a file in THAT sub-directory
I don't understand how to make the /home sub-directory a .hc as the Beginner's Guide seems to suggest.
#10 2025-10-03 16:12:59
Sometimes the command line is better.
Assuming the directory you want to copy is source and the USb drive is mounted on /media/dest
Open a command line window and try cp -rp source /media/dest (this assumes the window will open in /home).
#11 2025-10-09 21:43:34
Tweedlewise
As a "closer" It ended simply,
I opened the file for the encrypted drive in Thunar and in another tab my ./home
clicked and drug the file from /home to the veracrypt drive and it began copying.
It was easy, but not quick, it took hours for the copy to complete.
#12 2025-10-09 21:58:05
Tweedlewise wrote:
... the file from /home to the veracrypt drive ...
... easy, but not quick, it took hours ...
Just curious ...
It is not clear to me what device was used.
ie: a USB SSD of no specified capacity (as you wrote in your OP) or a 128Gb USB stick.
Could you let us know which?
And as a bonus, brand and model of the device you used?
#13 2025-10-10 16:04:24
Tweedlewise
Altoid,
I used a Monster (tm) Overdrive Advanced 128 Gb device that I purchased at Sam's Club maybe a decade ago for around $30. At the time it was the lowest priced USB solid state device at that capacity available. It used the wide USB cable that Samsung used on a Galaxy phone back then.  It has a normal USB Micro connector with a smaller connector right next to it (I think it was to supply additional charging current.)  It is not the conventional thumb drive form factor.
Here is one on eBay:
https://www.ebay.com/itm/224991438513?_ … R5qNzO25Zg
Sorry about the bloated link!
#14 2025-10-10 17:37:28
Tweedlewise wrote:
... Monster (tm) Overdrive Advanced 128 Gb ...
Thanks for the data.
I was wondering about the apparent slow write speed.
But then I realised you did not mention how many hours. 8^°
Glad you sorted it out.
#15 2025-10-10 21:11:06
Tweedlewise
Altoid,
I guess I didn't get it "sorted out" I formatted the drive with NTFS while setting up veracrypt.
But when I connected it to a Win10 laptop, it wasn't recognized.
And just now I reconnected it to my devuan machine and it is not recognized (mounting) either!
Sigh,  maybe i have a 128 Gb SD micro around here I can use...
#16 2025-10-10 23:27:01
Tweedlewise wrote:
... have a 128 Gb SD micro around here I can use...
Sorry to see it did not work out.
Q: is the data you need to send your brother really the type of stuff that needs your using a veracrypt solution?
You may want to consider doing something simpler, more straightforward.
eg:
.tar.gz compression which MS stuff can handle for the directory where all the files are located and then 7zip to encrypt and PW protect.
A strong PW and AES-256 should suffice.  8^°
That ^^^ or something similarly simple.
#17 2025-10-11 20:08:07
perhaps this might assist.
https://www.acme.com/software/securepage/
regardless, have fun!
#18 2025-10-12 09:57:39
zip it into a single file and then encrypt it with gpg. There is gpg for windows.
#19 2025-10-12 23:16:25
pcalvert
Unless you like having problems to solve, I recommend never using Linux to create an NTFS filesystem. If you need to create a filesystem that Windows can read, I recommend using VFAT or exFAT (I'd probably choose exFAT). And if you really need (or want) to use NTFS, use VFAT and then reformat the partition to NTFS using Windows.
Another one is called Luxxle.
