#1 2025-09-11 09:50:22
Codalunga
[SOLVED] Suddenly no audio
Hey there folks big_smile
Suddenly I have no audio on my system. It's been working perfectly for months, but then I turned the laptop on this morning and... Silence! I haven't tinkered with the system recently, so not sure what happened there.
How can I check if it's something system-wise or if I need to blame my DE (Trinity Desktop)?
This is the result of
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VB Analog [ALC269VB Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [S22E450]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
Also,
alsamixer
shows device 0 as the default.
Thanks for your help!
EDIT: Well, that was quick. Installing pavucontrol-qt and setting PulseAudio as the current mixer in Kmix did the trick. Leaving this here in case other users encounter the same issue!
#2 2025-09-11 14:17:16
Re: [SOLVED] Suddenly no audio
but what triggered the sudden loss of audio(since it was working perfectly before)?
#3 2025-09-11 14:32:36
Codalunga
Well, that's a good question! lol
I'm not sure really. As mentioned, I wasn't tinkering or anything, nor did I perform any update. I turned the laptop off last night and everything was working, then this morning I was greeted with no audio.
#4 2025-09-29 08:51:48
dgiglio
Same issue. I had switched from pulseaudio to pipewire. At the moment I have to run a script to start the service that exposes audio resources.
If it's your case too, I can provide the script later.
#5 2025-10-02 22:39:23
Tweedlewise
Sometimes when I attempt to listen to a youtube video, my USB headset doesn't work.
Sometimes it will work after a reboot, sometimes messing with the audio control panel gets it working.
(I'm not sure which random mouse click brings it back....)
#6 2025-10-05 08:45:49
Codalunga
After a couple of weeks I have encountered the same issues, even after installing pavucontrol-qt. I have noticed that the issue occurs when my laptop is connected via HDMI to a monitor, and I plug in my AUX headphones. As mentioned by Tweedlewise, it's all very random: a reebot solves the issues most of the time, but sometimes I have to do soma magic with the audio control panel or unplug the HDMI / aux to make it work.
The issue is still solved anyway, and it doesn't bother me that much when it happens big_smile
