#1 2025-09-10 06:16:21
the_edge123
[SOLVED] Minor issue after upgrading to excalibur
Hello,
My sources.list refers to stable.
During the last update, the packages were upgraded but
/etc/devuan_version
still contains daedalus.
Does it have to be manually updated ?
Fabien
#2 2025-09-10 06:25:43
Re: [SOLVED] Minor issue after upgrading to excalibur
For Devuan stable still is Daedalus. If you want to upgrade to Excalibur, change your sources.list to excalibur instead of stable.
#3 2025-09-10 10:58:33
RedGreen925
It is possible you need to change it manually I did nothing and got it correctly done. The base-files package is responsible for that setting.
zeus@lenovo:~/Downloads$ apt policy base-files
base-files:
  Installed: 13.8+deb13u1devuan1
  Candidate: 13.8+deb13u1devuan1
  Version table:
 *** 13.8+deb13u1devuan1 500
        500 http://de.deb.devuan.org/merged excalibur-proposed-updates/main amd64 Packages
        100 /var/lib/dpkg/status
     13.8devuan1 500
        500 http://de.deb.devuan.org/merged excalibur/main amd64 Packages
zeus@lenovo:~/Downloads$ apt-file list base-files
base-files: /bin
base-files: /etc/debian_version
base-files: /etc/dpkg/origins/debian
base-files: /etc/host.conf
base-files: /etc/issue
base-files: /etc/issue.net
base-files: /etc/os-release
base-files: /etc/update-motd.d/10-uname
snip....
root@lenovo:~# cat /etc/devuan_version
excalibur
root@lenovo:~# cat /etc/debian_version
13.1
root@lenovo:~# cat /etc/os-release
PRETTY_NAME="Devuan GNU/Linux 6 (excalibur)"
NAME="Devuan GNU/Linux"
VERSION_ID="6"
VERSION="6 (excalibur)"
VERSION_CODENAME="excalibur"
ID=devuan
ID_LIKE=debian
HOME_URL="https://www.devuan.org/"
SUPPORT_URL="https://devuan.org/os/community"
BUG_REPORT_URL="https://bugs.devuan.org/"
My sources file.
root@lenovo:~# cat /etc/apt/sources.list.d/devuan.sources
# Devuan 6 excalibur
## The new style method of using repositories to install software.
## This /etc/apt/sources.list.d/devuan.sources is new style and location file
## The /etc/apt/old.style.sources.list contains the same as this.
## https://linuxconfig.org/ubuntus-repository-configuration-ubuntu-sources-have-moved-to-etc-apt-sources-list-d-ubuntu-sources
## Normal excalibur sources
Types: deb
#URIs: http://ca.deb.devuan.org/merged
URIs: http://de.deb.devuan.org/merged
Suites: excalibur excalibur-backports excalibur-proposed-updates  excalibur-updates
Components: main non-free contrib non-free-firmware
Enabled: yes
Signed-By: /usr/share/keyrings/devuan-archive-keyring.gpg
Architectures: amd64
## excalibur security sources
Types: deb
URIs: http://deb.devuan.org/merged
Suites: excalibur-security
Enabled: yes
#4 2025-09-10 11:03:37
Again: You never have upgraded to Excalibur if your sources.list refers to "stable".
#5 2025-09-10 14:46:00
sources file looks good.
((The repos "excalibur-backports", "excalibur-proposed-updates",  "excalibur-updates", "excalibur-security" are probably not existing by now, but will when excalibur becomes stable.))
Assuming you did:
# apt-get update
# apt-get upgrade
# apt-get dist-upgrade
Is there an error message afterwards?
Edit: I got this wrong!
('strike through' does not work on code blocks)
#6 2025-09-10 17:03:16
@RedGreen925 and @delgado:
Have you digested the OP's = the_edge123 input correctly?
/etc/devuan_version
We are on Devuan here, not on Debian. Daedalus = Stable, Excalibur = Testing!!! I am sorry, you are both on the wrong track.
@Fabien: I am pretty sure you do not have Excalibur on your PC. You are on Daedalus still. The output is correct.
You may check with a
cat /etc/os-release
When you want to upgrade to Excalibur, make sure your Daedalus is up-to-date. Then run
apt install usrmerge
Then change your sources.list to excalibur.
Some reading: https://www.devuan.org/os/releases
#7 2025-09-10 18:04:56
Ups!
I read RedGreen925 post and thought it was an update from the OP.
Sorry for the confusion.
#8 2025-09-10 18:46:03
RedGreen925
Oh yeah missed the stable part I only seen the code name and was focused on the "upgrading to excalibur" in the title. My point remains correct for any version you are running the base-files package sets the value in the files that tell you what you are running.
#9 2025-09-11 06:18:35
the_edge123
My bad. I thought I upgraded to Excalibur because almost 300 packages were upgraded in stable.
After checking /var/cache/apt/archives, I can only see deb12 files.
Sorry for the noise.
#10 2025-09-11 08:11:35
You must have omitted upgrading for quite a while.
Nevertheless, good luck for a new approach.
#11 2025-09-11 12:55:18
the_edge123
No, I upgrade every day. I was surprised because, last week, I saw all these candidates to upgrade.
I'm not in a hurry. The system works fine. I'll wait for the transition to stable.
