Pages: 1
is it possible get wine-devel at Ceres?
how tell me please?
linux/bsd at desktop its sado-mazo game/toy for geeks/nerds with absolutely no warranty and antifool protection ©![]()
no any ideas?
if i try to use debian bookworm winehq repos for install winehq-devel, my devuan ceres apt say that cant resolve some depencies.
no any ideas?
One would be to use the system as intended, bookworm sources are for a bookworm based install. There you will find the proper dependencies need for that software to install. Instead you try to use them on an install that is now four generations further along than bookworm. Which is now old stable with Trixie based system the stable, the Forky being the new testing and the Ceres being the unstable. That is just not going to work if you search the packages you will find the winehq-devel does not exist as that is not a Debian package name that would be winehq-dev if it existed as that is how Debian systems name the development packages. In short you try to do something which is impossible to do, install a bookworm based system if you want to have any hope in hell of it working. Or you could try using the modern versions of the packages and see if those will do what you need, see what it tells you is available for your install.
root@9600k:~# apt-cache search wine
dxvk - Vulkan-based translation layer for Direct3D 8/9/10/11
dxvk-wine64 - Vulkan-based translation layer for Direct3D 8/9/10/11 - wine64 build
dxvk-wine64-development - transitional package
fonts-wine - Windows API implementation - fonts
gnome-colors - set of GNOME icon themes
gnome-wine-icon-theme - red variation of the GNOME-Colors icon theme
innoextract - Tool for extracting data from an Inno Setup installer
libd3dadapter9-mesa - state-tracker for Direct3D9
libd3dadapter9-mesa-dev - state-tracker for Direct3D9 -- development files
librust-winapi-dev - Raw FFI bindings for all of Windows API - Rust source code
libwine - Windows API implementation - library
libwine-dev - Windows API implementation - development files
libwinpr3-dev - Windows Portable Runtime library (development files)
mingw-w64-i686-dev - Development files for MinGW-w64 targeting Win32
mingw-w64-ucrt64-dev - Development files for MinGW-w64 targeting Win64/UCRT
mingw-w64-x86-64-dev - Development files for MinGW-w64 targeting Win64
python3-neo - Python IO library for electrophysiological data formats
q4wine - Qt GUI for WINE
samba-common-bin - Samba common files used by both the server and the client
shiki-colors - set of Metacity/GTK-2+ themes
shiki-wine-theme - red variation of the Shiki-Colors theme
tellico - Collection manager for books, videos, music, etc
tellico-data - Collection manager for books, videos, music, etc [data]
tellico-doc - Collection manager for books, videos, music, etc [doc]
tellico-scripts - transitional package for tellico-data
twine - utility for interacting with PyPI
unmass - Extract game archive files
wine - Windows API implementation - standard suite
wine-binfmt - Register Wine as the interpreter for Windows executables
wine64 - Windows API implementation - 64-bit binary loader
wine64-preloader - Windows API implementation - prelinked 64-bit binary loader
wine64-tools - Windows API implementation - 64-bit developer tools
winpr3-utils - Windows Portable Runtime library command line utilities
nvda2speechd - Bridge between Windows applications and Speech dispatcher
nvdacontrollerclient - Bridge between Windows applications and Speech dispatcher
gemrb - Open-source engine to run Baldur's Gate, Icewind Dale and Planescape: Torment
playonlinux - front-end for Wine
proton-caller - Run any Windows program through Valve's Proton
winetricks - simple tool to work around common problems in Wine
libwinpr3-3 - Windows Portable Runtime libraryOnline
Are you thinking of the wine-development package? This was removed in May: https://bugs.debian.org/cgi-bin/bugrepo … ug=1103851
RedGreen925
abower
Thanks for explain! ![]()
You are welcome. You may want to check out this article on using extrepo I have just read. I was looking at it and it lists the winehq as one that can be installed for a Trixie based system. It is probably soon enough after the transition to stable from testing for it to install on a unstable based system.
https://linuxiac.com/how-to-use-extrepo … ositories/
The page that lists the Trixie repositories.
https://extrepo-team.pages.debian.net/e … index.html
Edit: It can be just as simple as changing the bookworm to trixie in your existing entry then apt update then the install command to see if it will now work for you.
RedGreen925
Interesting i will try, thanks)
And can i have winehq-staging at Devuan?
This posting seems to suggest you can do it on Trixie, so try and see.
Pages: 1
