#1 2025-08-12 23:14:48
recklessswing
[SOLVED] Can't even install yt-dlp in Devuan 6, many things are broken
I installed Gnome with SDDM but now, I can only go Gnome Wayland, Xorg won't work. I mistakenly Fedora'd my Devuan. Now it's wayland only, yay
#2 2025-08-12 23:21:00
Re: [SOLVED] Can't even install yt-dlp in Devuan 6, many things are broken
Lol, sorry my friend!
You do know how buggy wayland is right? It's basically the reason the gnome devs love it so much. Everybody wants to get hired at Microshite where making buggy software is literally job #1 to support a billion dollar tech support industry.
#3 2025-08-13 15:14:31
unixuser
what does have yt-dlp with wayland ?
can you post logs of your "broken" stuff ?
I am using excalibur with wayland (sway) since months, I didn't noticed anything wrong and yt-dlp works fine smile
#4 2025-08-13 16:35:47
You simply may need a new version for Debian 13 Trixie.
#5 2025-08-13 20:18:33
recklessswing
@greenjeans here it is:
user@devuan-h310:~$ LANG=C sudo apt install yt-dlp
Solving dependencies... Error!
Unsatisfied dependencies:
 yt-dlp : Depends: python3-pycryptodome but it is not installable
          Depends: python3-requests but it is not going to be installed
          Depends: python3-websockets but it is not installable
          Recommends: ffmpeg
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
   Unable to satisfy dependencies. Reached two conflicting decisions:
   1. yt-dlp:amd64=2025.04.30-1 is selected for install
   2. yt-dlp:amd64 Depends python3-pycryptodome
      but none of the choices are installable:
      [no choices]
user@devuan-h310:~$ LANG=C sudo apt install python3-pycryptodome
python3-pycryptodome:i386 is already the newest version (3.20.0+dfsg-3).
It installs the i386 version instead. Because there is no amd64 version? I don't understand.
#6 2025-08-13 20:34:18
recklessswing
Something seriously broken now. I've tried to install yt-dlp and steam, enabling 32 bit repos. But, it deleted gnome desktop instead. And the bad thing is I can't even reinstall, trying to install KDE now. Nope..
@unixuser, do you use 32 bit libraries? Also can you post your sources.list file? I've added excalibur security and updates repo too.
root@devuan-h310:~# LC_ALL=C apt install task-kde-desktop
You might want to run 'apt --fix-broken install' to correct these.
 steam-launcher : Depends: python3 (>= 3.4) but it is not installable
                  Depends: python3-apt but it is not installable
 task-kde-desktop : Depends: kde-standard but it is not installable
                    Recommends: orca but it is not going to be installed
                    Recommends: gimp but it is not installable
Error: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
root@devuan-h310:~#
#7 2025-08-13 20:41:09
I don't have all those dependencies installed and I don't really have yt-dlp installed, but it runs fine from my ~/bin. I have python3-requests installed, but not the other two you listed with it.
wget https://github.com/yt-dlp/yt-dlp/releases/latest/download/yt-dlp
chmod +x yt-dlp
#8 2025-08-13 20:48:32
recklessswing
Okay I kinda force removed all 32bits packages, it was hard. Now it seems ok. Can you guys post me your sources.list file please? Do you add contrib non-free non-free-firmware anymore?
#9 2025-08-13 21:24:10
RedGreen925
Here is what I use I think it gives all that is available when I look at it on a mirror. It uses a German mirror as I found that to be one of the more reliable ones out there.
root@9600k:~# cat /etc/apt/sources.list.d/devuan.sources
# Devuan 6 excalibur
## The new style method of using repositories to install software.
## This /etc/apt/sources.list.d/devuan.sources is new style and location file
## The /etc/apt/old.style.sources.list contains the same as this.
## https://linuxconfig.org/ubuntus-repository-configuration-ubuntu-sources-have-moved-to-etc-apt-sources-list-d-ubuntu-sources
## Normal excalibur sources
Types: deb
#URIs: http://ca.deb.devuan.org/merged
URIs: http://de.deb.devuan.org/merged
Suites: excalibur excalibur-backports excalibur-proposed-updates  excalibur-updates
Components: main non-free contrib non-free-firmware
Enabled: yes
Signed-By: /usr/share/keyrings/devuan-archive-keyring.gpg
Architectures: amd64
## excalibur security sources
Types: deb
Suites: excalibur-security
Enabled: yes
## Normal unstable sources
Types: deb
Suites: unstable
Enabled: no
I have it installed from what would be the unstable I would think  before I disabled it when Trixie was released.
zeus@9600k:~$ apt policy yt-dlp
yt-dlp:
  Installed: 2025.07.21-1
  Candidate: 2025.07.21-1
  Version table:
 *** 2025.07.21-1 100
        100 /var/lib/dpkg/status
     2025.04.30-1 950
        950 http://de.deb.devuan.org/merged excalibur/main amd64 Packages
#10 2025-08-18 16:06:44
csehszlovakze
My go-to solution is downloading the yt-dlp_linux executable from their github first, renaming it to yt-dlp then just running yt-dlp -U when it becomes necessary. The main advantage of this method is getting rid of the python version mismatch of course, I've seen on an older ubuntu install how changing the system default python3 to something "too new" can wreck apt.
#11 2025-08-22 06:27:21
kapqa
to install yt-dlp manually:
mkdir -p ~/.local/bin
curl -L https://github.com/yt-dlp/yt-dlp/releases/latest/download/yt-dlp -o ~/.local/bin/yt-dlp
chmod a+rx ~/.local/bin/yt-dlp  # Make executable
export PATH="${HOME}/.local/bin:${PATH}"
In order for the command line shell to be able to find these executables, the user's PATH environment variable needs to be extended. This can be done by adding export PATH="${HOME}/.local/bin:${PATH}" to ~/.profile or ~/.bashrc.
now you can update yt-dlp with command
yt-dlp -U
it is recommended to uninstall yt-dlp from repositories since it is not up to date.
#12 2025-08-22 15:56:40
yes, uninstall yt-dlp via apt or synaptic BEFORE manually installing the newest version please.
#13 2025-10-05 09:25:11
Andre4freedom
Thank you, kapqa, you saved my day! And all of you, thanks.
Your procedure is perfect.
Have a good day.
#14 2025-10-06 18:42:45
igorzwx
What is wrong with youtube-dl?
$ youtube --version
2025.09.29
$ apt-cache search python-is-
python-is-python3 - symlinks /usr/bin/python to python3
#15 2025-10-06 19:12:12
kapqa
nothing wrong, but thought that one is @dead longtime ago since it seemed riddled with legal battles or what
https://ytdl-org.github.io/youtube-dl/
EDIT> last time i tried , it was superslow downloading everything at around kbps speeds.
#16 2025-10-06 19:51:37
igorzwx
This one works without problems:
youtube-dl nightly builds
_https://github.com/ytdl-org/ytdl-nightly
#17 2025-10-07 09:44:05
kapqa
only recently started having problems with youtube
at one point it even started to translate automatically without my consent, even when like native language being played.
but for the moment it subsided<
sometimes yt-dlp give also issues altesly , so could update to newer version
yt-dlp --update-to nightly
#18 2025-10-07 12:00:07
igorzwx
Try Firefox Nightly
_https://firefox-source-docs.mozilla.org/setup/linux_build.html
sudo apt update && sudo apt install curl python3 python3-pip git watchman
# reduce chance of builds failung during linking due to running out of memory
  export LDFLAGS+=" -Wl,--no-keep-memory"
# .mozconfig
# For very old computers -j2
mk_add_options MOZ_MAKE_FLAGS=-j2
ac_add_options --enable-project=browser
ac_add_options --with-app-name=antifox
ac_add_options --prefix=/usr
ac_add_options --enable-audio-backends=alsa
$ antifox --version
Mozilla Firefox 145.0a1
