#1 2025-06-09 19:31:14
unixuser
how to specify an hexadecimal offset to dd ?
Hi there,
does someone know how to specify an offset to dd ? I am trying to extract some bits from a firmware (some .data)
Thanks and hf!
#2 2025-06-09 20:00:20
Re: how to specify an hexadecimal offset to dd ?
man dd
#3 2025-06-09 23:32:36
Use the shell phrase $((0x100)) to specify offset value 256; and similarly $((0x35feed63)) for offset value 905899363.
The parameters would be skip=?? for the infile and seek=?? for the outfile. The value is in block size counts.
#4 2025-07-04 13:01:53
unixuser
@rolfie, I think you should have at least read it once before saying this, then, you'd know that it doesn't mention hexadecimal notation.
To have all options : check out the source code.
@ralph.ronnquiest, thanks, very appreciated, I still working on it. dd is powerful but a bit esoteric to use.
