Pages: 1
I'm looking to install Devaun on a pair of Lenovo T570 laptops. I run Gentoo on my T580 but have no interest in maintaining that on my wife and daughter's systems. I used Debian until systemd showed up, so I figure it's time to try Devuan.
I used to have a method for installing Debian where I could install a minimalist shell using the network CD/DVD and manually install only the shell utilities I wanted, then install just the very core of KDE/Plasma and then install only the things I wanted there as well. Is this possible in Devuan? Where do I start?
Next up is the network CD image. I can't seem to make it boot with my standard USB drive setup. I run Ventoy and it boots the Debian netinstall, but not the Devuan. It boots Gentoo, System Rescue CD, all kinds of Windows ISOs, and more, but it doesn't like Devuan. Has anybody managed to boot Devuan without wasting a 256GB drive for a netinstall ISO? I don't really have a spare drive and most of my drives are quite large and not suitable for such a tiny ISO.
Devuan is not compatible with Ventoy it seems, have a look at this thread, may be some help:
https://dev1galaxy.org/viewtopic.php?id=7092
Shame that laptop doesn't have an optical drive.
The Devuan net-install works just like the Debian, you can choose to only create a CLI-only iso if desired then install programs after installing/booting it, or at the software section you can choose to add a number of DE's including KDE, but i'm not sure that will give you a core-only KDE, probably installs the whole works, I know if you choose Mate it installs the whole Mate meta-package.
If I want just core stuff, I do the CLI-only, boot that up, then start apt'ing.
Have not used or tested Ventoy myself. You can likely dd the iso manually if you're comfortable using dd.
I use Mintstick typically, it seems to just work with everything so far. Refracta2usb also works great, offering options for multi-boot and persistence that Mintstick does not.
ETA: Welcome to Devuan! It might have some quirks being free of the curse of systemd, but it's well worth the effort in the end, simple and stable. ![]()
https://sourceforge.net/projects/vuu-do/ New Vuu-do isos uploaded October 2025!
Devuan 5 mate-mini iso, pure Devuan, 100% no-vuu-do.
Devuan 6 version also available for testing.
Been finding refracta isos work with ventoy and have used devuan with ventoy in the past???
^^^I'm just going by what others have said, again I have no experience with Ventoy myself.
In point of fact i'm working on my own scripts to make a utility to burn iso's to sticks and create additional partitions, of all of them Refracta2usb is the most complete and works the best to do all the things. I'm working on something in between it and Mintstick in terms of functionality. It's tough messing with USB's sometimes, fine line between success and disaster when working with all the things necessary to make it happen.
Here's a daedalus (stable) mini.iso, a.k.a. business card iso. Network install only, no wireless for the install. This one should boot for you.
https://pkgmaster.devuan.org/devuan/dis … t/mini.iso
It's also possible to use the live isos to do a debootstrap install.
Hello.
I'll put in my three cents and say that this is not a minimal system installation, because Plasma does not fall into the understanding of minimalism.
If you want to install Devuan and have a REALLY MINIMAL system, then you should use debootstrap mechanism.
More info here
https://www.debian.org/releases/stable/ … 03.en.html
It is a minimalist way of getting a graphical installation on the computer without all the extras that get pulled in by the meta package method of installing and is what I do every time as well. Which is obviously his goal when doing such he did not say he wants next to nothing installed.. Your understanding of what he wants in a minimal install is totally wrong for this situation.
Hello.
The system installation method I proposed is correct, because it allows you to install a COMPLETELY MINIMAL CLI system. By the way, the author's desire to install a minimal system and install a monstrous KDE environment on it (with its own packages) is more than strange. Do CLI programs that take up about two dozen megabytes on the disk matter if he plans to install Kde, which takes up almost one gigabyte of disk space?
Like stopAI, I don't understand why you want a small CLI core with a bloated KDE. I use dwm as my window manager, which is really lightweight and efficient. Ultra minimalist, it takes a bit of time to master. But if you want to offer a simple and efficient window manager to your family, jwm is really efficient and minimalist. Jwm is used in Puppy Linux. Devuan with jwm might be a good minimalist window manager for you.
I'll try to expain for you folks who aren't getting it. If you install a desktop environment from the installer iso, it uses a metapackage such as task-xfce-desktop or other desktop, which pulls in all parts of the chosen DE plus all other desktop applications. Trying to remove some parts of that will often result in the whole desktop being removed.
If you start with a minimal system, you can add the parts of the desktop that you want along with the specific applications that you want and have a leaner system than you would get with the task-* package.
Example: How do you install kde without getting libreoffice or gimp? Partial answer: You don't install task-kde-desktop.
$ apt depends task-kde-desktop
task-kde-desktop
Depends: tasksel (= 3.73devuan1)
Depends: task-desktop
Depends: kde-standard
|Depends: lightdm
|Depends: slim
Depends: sddm
Recommends: kdeaccessibility
Recommends: orca
Recommends: gimp
Recommends: libreoffice-writer
Recommends: libreoffice-calc
Recommends: libreoffice-impress
Recommends: libreoffice-plasma
Recommends: libreoffice-kf5
Recommends: libreoffice-help-en-us
Recommends: mythes-en-us
Recommends: hunspell-en-us
Recommends: hyphen-en-us
Recommends: print-manager
|Recommends: <time-daemon>
chrony
ntpsec
openntpd
Recommends: ntpsec-ntpdateOffline
Fighting about minimalism is hairsplitting. The OP obviously wants to setup a system according to his wishes and considerations without all that stuff that is pulled in by the task*-Packages. I use this approach myself which is some sort of minimalism in the wider sense. Install a cli from the netinstall, and then install the DE I prefer currently which is Cinnamon, and the packages I need. I could help doing this, also with Mate. Not with other DE's, no experience.
Daedalus doesn't boot from Ventoy, so a bootable separate stick is required.
@fsmithred, @rolfie : thanks, I get it ! it was unclear to me but with your insights I understand better.
I got busy and just got back to this project and I must say that I am surprised by the number of responses. Thank you to everybody who responded!
First, @fsmithred got it right. I am not talking a pure minimalist system in the sense of Puppy Linux or something. I want KDE/Plasma, but I only want what I use. I don't want endless dependencies for software I will never touch. I didn't mean a minimalist XFCE or LXDE setup with bare minimum CLI.
I'll try the ISO that @fsmithred shared also. I do like Ventoy because when it works, it works perfectly, but it doesn't seem to like the latest System Rescue CD or Devuan. Heck, it even boots my completely custom Windows 10 PE home-brew setup without a hitch. I have all of my Microsoft ISOs on a Ventoy drive as well as my Linux ISOs, minus Devuan.
Again, thanks for the help and I will be moving forward with this shortly, using the advice gathered here.
(slightly off-topic, I know)
The excalibur (testing) netinstall iso should boot from ventoy.
I did confirm today the published daedalus netinstall iso will not boot form ventoy.
However there have been some changes to installer-iso project (https://git.devuan.org/devuan/installer-iso), if you build a new daedalus netinstall iso it will boot from ventoy. Just another option to put out there.
maybe not so useful maybe is.
what i do for my setup is to do a netinstall and then run this script https://github.com/eylles/devuan-script … ll-list.sh
it defines some lists of packages to install for a minimal setup, you can create a config file to append to or override the lists of packages.
as for custom iso creation, another tool to consider is the cubic tool which is a GUI iso remaster tool that can remaster ubuntu and debian isos (including devuan) however it can't run on devuan as it uses systemd-nspawn, but according to https://github.com/PJ-Singh-001/Cubic/issues/363 it should be possible to modify the script to use chroot instead.
Pages: 1
