#1 2025-05-25 18:05:37
webman
Looking for the "right way" to install xfce4
Hi!
Alter I installed xfce4 (apt install xfce4), I tried to start ist using
>startxfce4
got the message 'xinit' not found.
That is strange, because -- on debian's -- I never used another way.
Any hints would be great.
It doesn't change, after I discovered, that xfce4 does not come with
lightdm, I installed that. xfce4 starts, when I invoke lightdm.
So: How to start it?
- using startxfce4 --or--
- lightdm
Thanks,
Manfred
#2 2025-05-25 19:34:05
Re: Looking for the "right way" to install xfce4
The way to start a "graphical desktop" is personal taste.
I remember being very annoyed years ago, when an installation defaulted to a graphical login screen - this is wrong !!11!
These days, I don't want to type in a text console start[x,lxde,kde,...].
#3 2025-05-26 00:48:02
sagemage
without lightdm i think you would startxfce4 like so inside the .xinitrc file in the home directory.
exec dbus-launch --exit-with-session startxfce4
You would need to make sure you have xinit and dbus-x11 installed also.
with lightdm you would need the lightdm greeter.
apt install lightdm-gtk-greeter
then reboot
