#1 2025-05-11 07:45:12
Aergan
[SOLVED] Chimaera 4.0 i386 Netboot Install Issue
When using PXE for Netboot installations, Chimaera 4.0 i386 cannot locate kernel modules in the archive
Download Installer Components
No kernel modules found
No kernel modules were found. This is probably due to a mismatch between the kernel used by this version of the installer and the kernel version available in this archive.
You should make sure that your installation image is up-to-date, or - if that's the case - try a different mirror, preferably deb.devuan.org
Non-working:
https://pkgmaster.devuan.org/devuan/dis … oot.tar.gz
https://pkgmaster.devuan.org/devuan/dis … t/mini.iso
The full CD media for netinstall is working:
https://files.devuan.org/devuan_chimaer … nstall.iso
The same images work for Netbooting i386 Beowulf and Deadalus:
PXE Menu
LABEL Devaun_Beowulf_i386
    MENU LABEL Devaun Beowulf (3.1) Network Installer (i386)
    KERNEL pxechn.c32 devaun/beowulf/pxelinux.0
LABEL Devaun_Chimaera_i386
    MENU LABEL Devaun chimaera (4.0) Network Installer (i386)
    KERNEL pxechn.c32 devaun/chimaera/pxelinux.0
LABEL Devaun_Daedalus_i386
    MENU LABEL Devaun Daedalus (5.0) Network Installer (i386)
    KERNEL pxechn.c32 devaun/daedalus/pxelinux.0
(Corrected spelling)
#2 2025-05-11 08:49:32
Re: [SOLVED] Chimaera 4.0 i386 Netboot Install Issue
If you would spell it correctly it might work ?
#3 2025-05-11 08:57:54
Aergan
Corrected spelling and no, same issue sadly.
#4 2025-05-11 10:29:10
(I guess you didn't pick up spelling of both chimaera and devuan smile
Yes there is the problem that netboot has packaged kernel 5.10.0-22-686 (Debian package version 5.10.178-3) while the current chimaera repository sports kernel 5.10.0-32-686 (Debian package version 5.10.223-1).
But the distributed kernel + initrd.gz pair up in that version.
Which kernel + initrd do you use?
#5 2025-05-11 10:41:12
Aergan
I am using:
This is extracted onto a directory on my PXE server
Which file contents appears to be the same as:
https://pkgmaster.devuan.org/devuan/dis … ller/i386/
#6 2025-05-11 11:17:47
Hmm. at the point of loading "components" could you use Alt-F2 to check which linux version (uname) is in play?
#7 2025-05-11 11:49:05
Aergan
Reports 5.10.0-22-686
#8 2025-05-11 12:48:09
Yes that's the kernel version of the tar.gz. And the running system (unpacked initrd) probably has /lib/modules/5.10.0-22-686 with 687 kernel modules, but the problem seems to be that the "Download installer components" step looks online for more modules for that kernel, which it won't find.
Thanks. Yes, it would be good if that netboot could be updated to align kernel versions.
There's no easy way to come forward while waiting. Basically you'll need the kernel from kernel-image-5.10.0-32-686-di to replace "linux" from the tar.gz, and then those 687 modules to pack into the initrd.gz. All that from
http://deb.devuan.org/merged main/debian-installer
(plus a depmod run)...
EDIT: actually you might get away with just unpacking kernel-image-5.10.0-32-686-pae-di_5.10.223-1_i386.udeb and nic-modules-5.10.0-32-686-pae-di_5.10.223-1_i386.udeb (or without pae) into a directory tree. Then move /boot/vmlinuz to be your debian-installer/i386/linux and copy in /lib/modules/5.10.0-32-686-pae into an unpacked initrd tree. chroot into that to run "depmod 5.10.0-32-686-pae" before packing it up again, to become your debian-installer/i386/initrd.gz. Doing only that makes it work for "standard" network devices. I can drop a detailed command sequence if you wish.
#9 2025-05-11 23:30:46
Updated chimaera netboot available:
#10 2025-05-11 23:35:58
Aergan
Many thanks - I'll give that a go tomorrow 👍
#11 2025-05-12 23:59:07
Aergan
That's all working now, many thanks!
