#1 2025-05-08 16:14:03
deepforest
[SOLVED] Upgrade Daedalus to Ceres - error
Did replace daedalus to ceres at sourses.lst
apt full-upgrade
but
Fetched 3,012 MB in 4min 21s (11.5 MB/s)
Reading changelogs... Done
apt-listchanges: Mailing root: apt-listchanges: news for devuan
Extracting templates from packages: 100%
Preconfiguring packages ...
setting xserver-xorg-legacy/xwrapper/allowed_users from configuration file
(Reading database ... 323483 files and directories currently installed.)
Preparing to unpack .../base-files_13.7devuan1_amd64.deb ...
* The base-files package cannot be installed because
* /bin is a directory, but should be a symbolic link.
* Please install the usrmerge package to convert this system to merged-/usr.
* For more information please read https://wiki.debian.org/UsrMerge.
dpkg: error processing archive /var/cache/apt/archives/base-files_13.7devuan1_amd64.deb (--unpack):
 new base-files package pre-installation script subprocess returned error exit status 1
root@devuan:/home/freeartist-devuan# apt full-upgrade
and
root@devuan:/home/freeartist-devuan# apt install usrmerge
  gir1.2-gtk-2.0 libgtk2.0-dev
  usrmerge
0 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.
Need to get 13.3 kB of archives.
After this operation, 41.0 kB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged daedalus/main amd64 usrmerge all 37~deb12u1 [13.3 kB]
Fetched 13.3 kB in 0s (34.3 kB/s)
Selecting previously unselected package usrmerge.
Preparing to unpack .../usrmerge_37~deb12u1_all.deb ...
Unpacking usrmerge (37~deb12u1) ...
Setting up usrmerge (37~deb12u1) ...
FATAL ERROR:
Both /bin/xdotool and /usr/bin/xdotool exist.
You can try correcting the errors reported and running again
/usr/lib/usrmerge/convert-usrmerge until it will complete without errors.
Do not install or update other Debian packages until the program
has been run successfully.
E: usrmerge failed.
dpkg: error processing package usrmerge (--configure):
 installed usrmerge package post-installation script subprocess returned error exit status 1
 usrmerge
smile
pyzNi 3.14zDa! smile
#2 2025-05-08 22:55:42
RedGreen925
Re: [SOLVED] Upgrade Daedalus to Ceres - error
I have both and it works fine.
root@9600k:~# ll /bin/xdotool
84 -rwxr-xr-x 1 root root 85376 Apr  6 12:26 /bin/xdotool*
root@9600k:~# ll /usr/bin/xdotool
84 -rwxr-xr-x 1 root root 85376 Apr  6 12:26 /usr/bin/xdotool*
That said it appears only the /usr/bin/xdotool is listed in the package.
root@9600k:~# dpkg -L xdotool
/usr
/usr/bin
/usr/bin/xdotool
/usr/share
/usr/share/doc
/usr/share/doc/xdotool
/usr/share/doc/xdotool/README
/usr/share/doc/xdotool/changelog.Debian.gz
/usr/share/doc/xdotool/changelog.gz
/usr/share/doc/xdotool/copyright
/usr/share/doc/xdotool/examples
/usr/share/doc/xdotool/examples/ffsp.sh
/usr/share/man
/usr/share/man/man1
/usr/share/man/man1/xdotool.1.gz
So I would use rm /bin/xdotool as root and see if it will complete once you use the /usr/lib/usrmerge/convert-usrmerge as it suggests after removing the file it complains about.
Once done do the apt autoremove to get rid of the usrmerge it is not needed once done.
root@9600k:~# apt policy usrmerge
usrmerge:
  Installed: (none)
  Candidate: 39+nmu2
  Version table:
     39+nmu2 950
        950 http://de.deb.devuan.org/merged excalibur/main amd64 Packages
        600 http://de.deb.devuan.org/merged unstable/main amd64 Packages
Edit: Though now reading it again and checking it appears it completed almost three years ago for me and the /bin is now the symbolic link it is supposed to be, never seen that problem in my install notes when I check those.
root@9600k:~# ll /
total 2097236
      0 lrwxrwxrwx   1 root root          7 Aug 28  2022 bin -> usr/bin/
snip....
#3 2025-05-08 23:18:57
Yep.
Best policy: Install usrmerge first before you do anything else. And best to reboot too.
Then switch sources.list to excalibur, update, then upgrade and just let it run, it's gonna be 900+ packages.
#4 2025-05-09 03:13:18
deepforest
Its works!
Thanks a lot to you @RedGreen925 @greenjeans all kind mans:)
smile
#5 2025-05-09 04:09:08
RedGreen925
You are welcome good to see you got it sorted.
#6 2025-05-09 16:24:33
I would have started with ls -li /bin/xdotool /usr/bin/xdotool and checked the inode numbers were different. If two files in the same filesystem have the same inode number they are really the same file, possibly hard linked, possibly one part of one path is a link to part of the other path.
Eg if /bin is a symlink to /usr/bin then everthing in one is really the same file as in the other.
I'd also have moved /bin/xdotool to somewhere else in case it really turned out to be needed. Probably after diff /bin/xdotool /usr/bin/xdotool as well.
