#1 2025-04-04 20:32:06
klein
[SOLVED] install password
good day all
i have searched and it is asking me for devuan login: then it ask for a password: i tried toor
devuan_daedalus_5.0.0_amd64_minimal-live.iso
thank you in advance.
#2 2025-04-04 20:44:05
Re: [SOLVED] install password
use the live for testing if it suits you.
if you want to install it onto your disk use the normal installers, e.g. the netinstall.
#3 2025-04-04 21:19:54
klein
i was trying to just install the base so i could build openbox on it
#4 2025-04-04 21:20:41
klein
so your telling me there is no password for this iso ?
#5 2025-04-04 23:06:47
login:password on the live isos:
devuan:devuan
root:toor
also, sudo with no password is enabled.
#6 2025-04-04 23:19:51
klein
thank you fsmithred, too use to booting gui.iso's.
does this iso have an install file ?
i just found this in the release notes.
User name: devuan        Password: devuan
Admin name: root        Password: toor
