#1 2025-03-01 09:42:28
unixuser
[SOLVED] dpkg error while update
I got this error :
 /tmp/apt-dpkg-install-NFWtHn/8-libc6_2.41-2_i386.deb
Error: Sub-process /usr/bin/dpkg returned an error code (1)
so I deleted /tmp/files, did a "apt --fix-broken install"
Gave me this :
dpkg: error processing archive /var/cache/apt/archives/libc6_2.41-2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/lintian/overrides/libc6', which is different from other instances of package libc6:i386
So I stopped before a disaster and come here to get help
#2 2025-03-01 11:37:49
Re: [SOLVED] dpkg error while update
Probably it gets sorted with an initial
dpkg -i --force-overwrite /var/cache/apt/archives/libc6_2.41-2_i386.deb
or if you use --force-all rather than --force-overwrite.
Thereafter follow up with a new
apt-get -f install
But you should have a live disk at hand, just in case things go badly.
#3 2025-03-01 13:12:15
unixuser
OK done,
apt-get -f install
with no problem, I did fear a lot while this comp is full a important data for me.
Thanks
#4 2025-03-01 13:27:41
hacksenwerk
What did you fear? Dataloss? If so do redundant backups! hmm
I learned a lot from the nerds and geeks of the devuan community and I still do.
So for all my How Tos credits are going out especially to fsmithred, gnarface, rrq and all the others who are so kind and patient with wildchild hacksenwerk.
#5 2025-03-01 14:18:49
In addition to backing up your data, you probably should think about moving it to a system that has continued support for the kernel and maybe a system that isn't changing as rapidly as ceres.
Which kernel are you using? Did you manage to get the last one before they removed the 32-bit kernels from ceres? I believe that was 6.10.9. Do you have an alternate strategy for dealing with kernel patches? If so, those of us with old machines would like to know more.
#6 2025-03-01 16:18:56
unixuser
Sorry to disappoint you, but I'm using 64bit kernel :
Linux tinpatrick 6.12.16-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.16-1 (2025-02-22) x86_64 GNU/Linux
I think this 32bit lib is used for steam...
Yes, I really need to backup my stuff...
